[APP][Pro] Support for ONVIF compatible cameras (Release 2.0.70, Test 2.0.76)
Hi paul_hemel
Same here.
Maybe that can @Adrian_Rockall change?
I have homey pro 2023 mit 13.2.0-rc.5 And the app version 2.0.65.
iPad air gen5 with version 26.4.2
I’m not sure I have any control over that. All the app does is tells Homey how to get the feeds and the Homey UI deals with displaying it.
Ok thanks for letting it know, when I start the Homey iPad app, the stream gives this error.
When press play, it shows the stream :+1:
(camera is set to h.265)
Changed camera to H.264, now the error is gone.
Is H.265 not supported?
No, Homey doesn’t seem to support H265.
@Adrian_Rockall So do you think we should report this to Athom, or will you handle it?
If you could report it as I can’t replicate the problem, so if they ask questions I will have to come back to you, which will just add a delay.
I made a ticket for this (Your request (150506))
Ok, thank you :+1:t3:
In my case it’s fixed in the latest Homey App update :grin:
Hoi Adrian, there are many flowcards missing such as person detected, vehicle detected and more. Now my flows are corrupt and don’t work anymore. Please, can you fix it?? Thanx.
I have no idea. What happened to loose them?
Have you checked the Advanced settings to make sure the capabilities are enabled?
That solves the problem, but how is that possible? All the capabilities are disabled suddenly?
But thanx anyway.
That’s the bit I can’t answer. The new version disables capabilities that are not reported as supported when a device is added, but that should be the only time.
I just noticed the same thing, I’m missing them also.
They were also deactivated in my Advanced settings, why always! Previously, they were active for months.
When you activated them in the advanced settings, did the Flow cards come back?
Yes, they’re back
It’s strange as the only time the capabilities should be removed is during the onAdded event and that should only fire when a device is first added to Homey.
Hello, thank you for this app
Recently I have a Comelit CCTV system with NVR and 2 IP cameras. I was able to add the cameras to the app but unfortunately I can only view images and the movement functions do not work.
It also takes at least 15 seconds before there is an image when opening the camera. I also can’t view the images outside my wifi network Is this something that can be solved or is it because comelit is not supported. I’m completely new to the CCTV and ONVIF. So maybe it’s something simple that I’m missing.
Which Homey do you have?
The still image should be visible when away from your network as it comes from the camera to Homey and then from Homey/Athom servers to your phone.
I have a Homey Pro 2023. If I turn off wifi, the stream is gone.
