[APP][Pro] SONOFF Zigbee
Thanks ! Which app do you refer to ? The Sonoff app ?
The SONOFF Zigbee Smart Water Valve works with the “Official” Sonoff App by StyraHem Sweden.
Hi, does anybody know if the new Sonoff Hydro One, which can be pre-ordered (delivery starting 30th of April), will also be supported by the app soon?
Only the developers of the two Homey Sonoff apps are able to answer this question.
I’m testing this devices from Sonoff:
MINI-ZBDIM-E:
MINI-ZBDIM:
I can add it via “Zigbee Device” but there are not available in the Sonoff Zigbee App or the official one. So I’m limited with params like choosing de type of switch (for MINI-ZBDIM).
Is there a plan to update Sonoff Zigbee App ?
Thank you !
Hello, I’m in Spain and the Sonoff brand is becoming very popular.
However, the app for Homey is very limited.
The developers should add many more items from the Sonoff catalog.
I hope you’ll work on this soon, because Homey software deserves it.
Have You contacted “StyraHem Sweden” via th contact link provided on the App page directly?
I’m prety sure that’s the best/fastest way to get support You need.
I have the SWV - ON / OFF working so good enough seems to have some flow data as well..
Mainly been working on the > SNZB-01M
just got it working with some claude assistance using specifically: se.styrahem.sonoff.zigbee (community, by StyraHem/JohanBendz) data.
Status
:white_check_mark: Working — custom driver built and sideloaded. All 16 Flow triggers functional. > for me at least..
only tested 1 button
single click and double click but flows are built…
need to upload my mess for them to review..
As it is basically just an OnOff device, it should work with the generic Homey zigbee driver.
(Add device > at the next screen, below the “Technology” tab, select “Zigbee”)
I actually bought it and tried.
It can not be added as an old SWV and needs to be added as a other zigbee device.
I do not have any data I can use. the old valve at least had a counter and a flow meter.
But here comes the catch. It shuts off every 10 minutes!
Even when my flows work perfectly, it shuts itself off everytime.
no setting I can find to change it, and I don’t think I can acces it through te ewelink app without their bridge.
Not too pleased with it to be honest.
I have contacted styrahem but they haven’t responded yet.
@B_Cogs Do you still get water flow and water use values? I used the SWV last spring and summer and I was getting all the values. I then removed the valve from my tap and stored it without batteries over winter. When I installed it a week ago, I noticed that while I can still control the on/off function, I do not get the water flow or water use values anymore. I tried reinstalling the app (the official one), removing and re-adding the device, re-adding it very close to Homey and then moving the valve, adding one extra node just behind a wall (ikea inspelning outlet). None of this helped. I’m on the latest version of the Sonoff app and latest Homey firmware, using Homey pro 2023.
I Bought 4 of the Sonoff SWV to build a watering system for the garden this summer. I havent managed to add a single one to my Homey Pro (Early 2023). Running the latest software on both Homey and the Sonoff app, also tried the experimental version but to no avail. Tried adding them close to the Homey and close to other Zigbee nodes but with same result every time. The pairing process times out. Tried at least 30 times. After trying to pair them they show up as an Unknown node when I check Zigbee devices in Developer Tools. They get an IEEE- and a network adress but nothing else and I cant ping or interview them, and when I restart the Homey they disapear from the list.
I can see in the thread that a lot of people have managed to pair them in Homey. Please tell me how!
I also have reached out to StyraHem but havent heard anything back yet.
To save the projekt I bought a Sonoff Zigbee gateway and connected them through that, so now I can set up watering flows in the iphone eWeLink app.
Tried adding them to the Homey with the eWeLink Homey app, but they can just be added with the Generic device option and then you dont get any data or funcionality in Homey, although I managed to put togther a flow to open and close the waterflow at least, but with no feedback in Homey if it is working or not. That I have to check in the eWeLink app so I think I will just use this to manage the watering for now, but Im not really pleased with the solution!
You can also use the status received triggers to get feedback if the command has executed
Strange that you cannot add it to Homey. I used the official app, pressed the on/off button on Sonoff SWV for 5-10sec until it started blinking and it would immediately get added to Homey. I still do not get any water flow rate or water use data even though I was getting it last year.
Hi everyone,
I am currently planning a full-house migration from Samsung SmartThings to Homey Pro. I am very impressed by Homey’s local processing capabilities, but I have one critical bottleneck I need to resolve before I commit to the move.
My entire house is equipped with Sonoff ZBM5 wall switches (1, 2, and 3-gang versions). I have read through this thread and noticed others are struggling with native multi-gang support. Before I finalize my Homey Pro order, I was hoping to get a clearer picture of the current state of support for these devices:
  • Is there currently a stable, native driver in the Sonoff Zigbee app that correctly handles the 1, 2, and 3-gang ZBM5 switches as individual, controllable entities?
  • If not, is there a recommended “best practice” for someone in my position, or would you strongly advise me to wait until native support is tested and verified? Given that these are my main smart devices throughout the house, I want to ensure my lighting remains rock-solid during the transition.
I am fully prepared to provide device fingerprints/interviews if that helps the developers add support. Any insights from those of you already managing ZBM5 switches would be greatly appreciated, as this is the deciding factor for my move to Homey Pro.
Thanks,
Michael
I think connecting them to a Sonoff ZBbridge might work, it connects to Homey via the eWeLink app and you should be able to add any device using the generic device driver
Hi @smarthomesven,
Thank you for the suggestion.
I am planning to keep my SmartThings hub for a while longer as I work toward moving everything over to Homey for an all-in-one setup. However, I would prefer to avoid adding ZBbridges or any extra hardware to make this transition work.
If anyone still wonders or would like native support on the new Hydro One/Duo water valves.
Styrahem replied to me.
There is a crowdfund going to pay for hardware, support en runningcost of the integration.
When the goal of 750€ is reached, development commences.
https://ko-fi.com/styrahem/goal?g=6
What the heck!?
@Doekse, do you know if that’s okay?
Edit
In general, I’m in favor of providing financial support to great, motivated app developers. I myself have donated about 225 € to various app developers over the past few years. But I think it’s pretty cheeky to demand a specific amount before continuing to develop the app.
Oh man.
I’ll have a chat with them
