[App][Pro] Sofar (Release 1.1.58, Test 1.1.61)
Hello Adrian,
I have a Sofar ESI-12K-T1 three-phase inverter (12 kW) with a 5 kWh battery, and I am using your Sofar Homey app version 1.1.55.
Homey has already created an inverter device named with the inverter serial number (317615…), and this device works correctly and provides several values such as current power, daily production, daily consumption, internal temperature and heatsink temperature.
However, when I try to add the other devices — Battery (Sofar), Grid (Sofar), Home/Inverter and Solar Panel (Sofar) — pairing always returns “Nothing return”.
I would particularly like to retrieve:
  • Battery SOC
  • Battery charge/discharge power
  • Grid import/export power
  • PV power
I have generated a Homey diagnostic report.
Diagnostic code:
dce317a5-ee41-4edc-b50a-db2956ab65a1
Could you please check whether the ESI-12K-T1 is correctly supported by the app, or whether a different register map is required?
Thank you very much for your help.
Good morning,
I have a SOFAR Hybrid Inverter ESI-8K-T1.
I have the app installed and active. I can also see in the app log that the app detects the SOFAR inverter, but unfortunately I am unable to add it to the app.
What am I doing wrong? Does anyone have any idea how I can resolve this or help me get it connected?
My setup consists of:
  • SOFAR Hybrid Inverter ESI-8K-T1
  • 15 kWh battery storage
  • 20 solar panels
Any help would be greatly appreciated.
2026-09-17T04:50:59.676Z
Searching for inverters on the LAN
  • 2026-09-17T04:51:04.796Z
    Found Inverter: IP: 10.10.0.253, S.No: 31xx7289X1
  • 2026-09-17T04:51:04.802Z
    Updated Modbus slave ID to 1
  • 2026-09-17T04:51:04.805Z
    Using Modbus slave ID 1 when registering sensor 31xx7289X1
  • 2026-09-17T04:51:04.807Z
    Checking register 14 for grid frequency:
  • 2026-09-17T04:51:04.826Z
    Returned null.
Checking register 1156 for grid frequency:
  • 2026-09-17T04:51:04.836Z
    Returned null.
Checking register 524 for grid frequency:
  • 2026-09-17T04:51:04.846Z
    Returned null.
Checking register 33282 for grid frequency:
  • 2026-09-17T04:51:04.857Z
    Returned null.
Checking register 609 for grid frequency:
  • 2026-09-17T04:51:04.868Z
    Returned null.
Checking register 1156 for grid frequency using the sofar_ktlx_g profile:
  • 2026-09-17T04:51:04.892Z
    Returned null.
Checking register 552 for grid frequency:
  • 2026-09-17T04:51:04.906Z
    Returned null.
Checking register 79 for grid frequency:
  • 2026-09-17T04:51:04.917Z
    Returned null.
No suitable inverters found
  • 2026-09-17T04:59:39.321Z
    Registering manual sensors from settings
  • 2026-09-17T04:59:39.322Z
    Using Modbus slave ID 1 when registering sensor 31xxxx89X1
  • 2026-09-17T04:59:39.323Z
  • 2026-09-17T04:59:39.343Z
    Returned null.
  • 2026-09-17T04:59:39.353Z
    Returned null.
  • 2026-09-17T04:59:39.363Z
    Returned null.
  • 2026-09-17T04:59:39.372Z
    Returned null.
  • 2026-09-17T04:59:39.380Z
    Returned null.
  • 2026-09-17T04:59:39.389Z
    Returned null.
  • 2026-09-17T04:59:39.398Z
    Returned null.
  • 2026-09-17T04:59:39.408Z
    Returned null.
I will do some searching to see if I can find a register map for your model.
hi Adrian,
if not i i can help you with al the data to add it to the app, no problem to do that.
Hi Adrian, did you find anything about this model / options ?
I have just published a new test version that should have better error logging to provide the reason the requests failed rather than just showing null.
All my searches suggest your inverter should have the same register map as the sofar_g3hyd, so it should be found and the null error message suggest a communications issue rather than a register mismatch.
So, could you install version 1.1.56 and try again.
hi Adrian,
i updated to 1.56 test version, tje log:
2026-09-19T10:52:16.107Z
  • 2026-09-19T10:52:16.109Z
    Using Modbus slave ID 1 when registering sensor 31617289XX
  • 2026-09-19T10:52:16.131Z
    Register 14 (sofar_lsw3): No probe match (No data returned for register 14 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
  • 2026-09-19T10:52:16.132Z
    Returned null.
  • 2026-09-19T10:52:16.144Z
    Register 1156 (sofar_g3hyd): No probe match (No data returned for register 1156 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:16.646Z
    Register 524 (sofar_hy_es): No probe match (No data returned for register 524 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
  • 2026-09-19T10:52:16.648Z
    Returned null.
  • 2026-09-19T10:52:16.659Z
    Register 33282 (solis_hybrid): No probe match (No data returned for register 33282 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:17.164Z
    Register 609 (sun3p): No probe match (No data returned for register 609 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:17.650Z
    Register 1156 (sofar_ktlx_g): No probe match (No data returned for register 1156 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:17.666Z
    Register 552 (deye_sg04lp3): No probe match (No data returned for register 552 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:17.676Z
    Register 79 (deye_sg04lp3): No probe match (No data returned for register 79 (host 10.10.0.253:8899, slave 1, function code 3, received 0 bytes))
    Returned null.
  • 2026-09-19T10:52:17.696Z
  • 2026-09-19T10:52:22.763Z
    Found Inverter: IP: 10.10.0.253, S.No: 316172891xx
  • 2026-09-19T10:52:22.765Z
    Using Modbus slave ID 1 when registering sensor 31617289xx
  • 2026-09-19T10:52:22.766Z
  • 2026-09-19T10:52:22.779Z
  • 2026-09-19T10:52:22.780Z
    Returned null.
  • 2026-09-19T10:52:22.789Z
  • 2026-09-19T10:52:22.790Z
    Returned null.
  • 2026-09-19T10:52:22.798Z
  • 2026-09-19T10:52:22.800Z
    Returned null.
  • 2026-09-19T10:52:22.808Z
  • 2026-09-19T10:52:22.809Z
    Returned null.
  • 2026-09-19T10:52:22.823Z
  • 2026-09-19T10:52:22.824Z
    Returned null.
  • 2026-09-19T10:52:23.326Z
  • 2026-09-19T10:52:23.328Z
    Returned null.
  • 2026-09-19T10:52:23.827Z
  • 2026-09-19T10:52:23.829Z
    Returned null.
  • 2026-09-19T10:52:23.846Z
  • 2026-09-19T10:52:23.848Z
    Returned null.
kind regards Andre
OK, so the fact that not data is returned means you logger is lot responding. make sure it is on the same IP range as Homey or that a suitable bridge is configured to allow two subnets to talk to each other.
Make sure the logger is configured to enable local access.
Make sure the Modbus ID is set to be the same as you inverters.
UPDATE
Hi Adrian,
Sorry for the amount of information. I’m an RF systems specialist and analyst by profession, so I can’t leave a problem like this alone. To save you reading my earlier messages, here is one consolidated summary.
SHORT VERSION
  1. Via the LSW-3 WiFi logger (port 8899) the connection is accepted, but the logger closes it right after the request (0 bytes), also without Homey involved.
  2. The inverter’s own Ethernet port answers plain Modbus TCP on port 502, and the register map matches your sofar_g3hyd probe: register 1156 returns 5001, which is 50.01 Hz grid frequency (0.01 Hz scale). But the app only probes port 8899, so it cannot use this route. There is no port or protocol setting in the app.
SETUP
  • Inverter: SOFAR Hybrid ESI-8K-T1. Modbus address 001 and baud rate 9600, checked on the inverter display.
  • WiFi logger: LSW-3, firmware LSW3_15_MQTT_270A_1.10, Web Ver 1.0.24, IP 10.10.0.253. Working mode: Data collection. Internal server: TCP-Server, port 8899. Serial port 9600/8/N/1. Inverter brand: Sofar_G3.
  • Inverter Ethernet port: 10.10.0.30 from my DHCP server.
  • Homey, my Linux test PC and both devices are on the same network (10.10.0.x), no VLANs.
HOMEY APP 1.1.56
  • Automatic scan finds the logger at 10.10.0.253 (logger serial number 123456789 as a placeholder). All register probes (sofar_lsw3, sofar_g3hyd, sofar_hy_es, solis_hybrid, sun3p, sofar_ktlx_g, deye_sg04lp3) return 0 bytes with slave ID 1, function code 3.
  • Manual device 10.10.0.30: ECONNREFUSED on 10.10.0.30:8899 for every probe. The Register Log tool gives the same result for 0x0484 and 0x0445 (8 registers).
  • The manual device serial field rejects the inverter’s own serial number, which contains letters. It seems to expect the numeric logger serial number.
  • The Settings tab only has Modbus Slave ID (1) and polling interval.
TESTS FROM A LINUX PC (Homey app not involved)
Logger 10.10.0.253:
  • nc to port 8899 succeeds.
  • mbpoll plain Modbus TCP (slave 1): “Connection reset by peer”, then “Broken pipe”.
  • pysolarmanv5 3.0.6 (Solarman V5, correct logger serial, slave 1, holding register 0x0484): the V5 frame is sent correctly, then the logger closes the connection (“Connection closed on read”). A logger restart did not change this.
Inverter Ethernet 10.10.0.30:
  • nc: port 502 open, port 8899 refused.
  • mbpoll plain Modbus TCP, unit 1, holding register 1156 (0x0484): returns 5001. This is the register your app uses for the grid frequency check on the sofar_g3hyd profile, so the value is 50.01 Hz.
  • mbpoll holding registers 0x0445 to 0x044C: returns a readable ASCII serial number (starts with SH1 and contains 8K), which fits the HYD register map.
CONCLUSION
The network, Modbus address, and baud rate are fine. The WiFi logger firmware (1.10) appears to block local Modbus access on 8899. From what I read, other users report only certain LSW-3 firmware versions work locally. The inverter itself is fully reachable via Modbus TCP on port 502 with the sofar_g3hyd register map.
QUESTIONS
  1. Can the app get a mode for direct plain Modbus TCP to the inverter (IP, port 502, unit ID 1) without a logger serial number? A configurable port would already be enough.
  2. If not, is there a workaround, for example another way to force the port or protocol?
  3. Is there anything else you want me to test? I can read specific registers with mbpoll and send the output.
Thanks a lot for your time and help!
I have published a new version that that should support MODBUS TCP as well.
There’s a new option in the app settings to select V5, Auto, TCP. The default is Auto.
Let me know if it helps.
Also changed the default port plus add options to change them.
Hello Adrian,
If I set it to V5, I can select some options, but it still does not work properly. It is now generating a huge number of log files (see below).
I deleted the logs, stopped and restarted the application, and the log below was generated immediately afterwards. It is now doing this every few seconds.
I get the same behavior both on 10.10.0.30 via the Ethernet connection and on the logger using the SOFAR Wi-Fi dongle at 10.10.0.253.
If I set it to MODBUS TCP, it appears to work, but I still get a huge number of log files and errors.
Below is the log from the MODBUS TCP configuration. The log file is growing rapidly, effectively doubling every one to three seconds.
V5 LOG2026-09-21T16:42:16.970ZConnection closed
  • 2026-09-21T16:42:16.973Z
    Connection error: Error: connect ECONNREFUSED 10.10.0.253:502
  • 2026-09-21T16:42:16.974Z
    send_request error Connection error to 10.10.0.253:502 (ECONNREFUSED)
  • 2026-09-21T16:42:16.976Z
    send_request: slave = 1, start = 1050, end = 1050, fc = 3
  • 2026-09-21T16:42:16.978Z
    Connection closed
  • 2026-09-21T16:42:16.981Z
  • 2026-09-21T16:42:16.982Z
  • 2026-09-21T16:42:16.984Z
    send_request: slave = 1, start = 1056, end = 1056, fc = 3
  • 2026-09-21T16:42:16.986Z
    Connection closed
  • 2026-09-21T16:42:16.989Z
  • 2026-09-21T16:42:16.991Z
  • 2026-09-21T16:42:16.992Z
    send_request: slave = 1, start = 1156, end = 1173, fc = 3
  • 2026-09-21T16:42:16.994Z
    Connection closed
  • 2026-09-21T16:42:16.996Z
  • 2026-09-21T16:42:16.998Z
  • 2026-09-21T16:42:17.000Z
    send_request: slave = 1, start = 1176, end = 1184, fc = 3
  • 2026-09-21T16:42:17.002Z
    Connection closed
  • 2026-09-21T16:42:17.005Z
  • 2026-09-21T16:42:17.007Z
  • 2026-09-21T16:42:17.009Z
    send_request: slave = 1, start = 1187, end = 1195, fc = 3
  • 2026-09-21T16:42:17.011Z
    Connection closed
  • 2026-09-21T16:42:17.021Z
  • 2026-09-21T16:42:17.022Z
  • 2026-09-21T16:42:17.023Z
    send_request: slave = 1, start = 1199, end = 1199, fc = 3
  • 2026-09-21T16:42:17.026Z
    Connection closed
  • 2026-09-21T16:42:17.030Z
  • 2026-09-21T16:42:17.032Z
  • 2026-09-21T16:42:17.033Z
    send_request: slave = 1, start = 1412, end = 1417, fc = 3
  • 2026-09-21T16:42:17.035Z
    Connection closed
  • 2026-09-21T16:42:17.038Z
  • 2026-09-21T16:42:17.039Z
  • 2026-09-21T16:42:17.041Z
    send_request: slave = 1, start = 1476, end = 1476, fc = 3
  • 2026-09-21T16:42:17.043Z
    Connection closed
  • 2026-09-21T16:42:17.046Z
  • 2026-09-21T16:42:17.048Z
  • 2026-09-21T16:42:17.049Z
    send_request: slave = 1, start = 1540, end = 1546, fc = 3
  • 2026-09-21T16:42:17.053Z
    Connection closed
  • 2026-09-21T16:42:17.056Z
  • 2026-09-21T16:42:17.057Z
  • 2026-09-21T16:42:17.058Z
    send_request: slave = 1, start = 1668, end = 1691, fc = 3
  • 2026-09-21T16:42:17.061Z
    Connection closed
  • 2026-09-21T16:42:17.064Z
  • 2026-09-21T16:42:17.065Z
  • 2026-09-21T16:42:17.067Z
    No Data
  • 2026-09-21T16:42:17.069Z
    Connection closed
  • 2026-09-21T16:42:27.091Z
    Get Data
  • 2026-09-21T16:42:27.093Z
    send_request: slave = 1, start = 1028, end = 1028, fc = 3
  • 2026-09-21T16:42:27.099Z
  • 2026-09-21T16:42:27.101Z
  • 2026-09-21T16:42:27.103Z
    send_request: slave = 1, start = 1048, end = 1048, fc = 3
  • 2026-09-21T16:42:27.106Z
    Connection closed
  • 2026-09-21T16:42:27.110Z
  • 2026-09-21T16:42:27.111Z
  • 2026-09-21T16:42:27.113Z
  • 2026-09-21T16:42:27.115Z
    Connection closed
  • 2026-09-21T16:42:27.119Z
  • 2026-09-21T16:42:27.120Z
  • 2026-09-21T16:42:27.121Z
  • 2026-09-21T16:42:27.124Z
    Connection closed
  • 2026-09-21T16:42:27.126Z
  • 2026-09-21T16:42:27.129Z
  • 2026-09-21T16:42:27.130Z
  • 2026-09-21T16:42:27.133Z
    Connection closed
  • 2026-09-21T16:42:27.135Z
  • 2026-09-21T16:42:27.138Z
  • 2026-09-21T16:42:27.139Z
  • 2026-09-21T16:42:27.141Z
    Connection closed
  • 2026-09-21T16:42:27.154Z
  • 2026-09-21T16:42:27.157Z
  • 2026-09-21T16:42:27.158Z
  • 2026-09-21T16:42:27.160Z
    Connection closed
  • 2026-09-21T16:42:27.168Z
  • 2026-09-21T16:42:27.170Z
  • 2026-09-21T16:42:27.171Z
  • 2026-09-21T16:42:27.174Z
    Connection closed
  • 2026-09-21T16:42:27.177Z
  • 2026-09-21T16:42:27.180Z
  • 2026-09-21T16:42:27.182Z
  • 2026-09-21T16:42:27.184Z
    Connection closed
  • 2026-09-21T16:42:27.188Z
  • 2026-09-21T16:42:27.189Z
  • 2026-09-21T16:42:27.190Z
  • 2026-09-21T16:42:27.193Z
    Connection closed
  • 2026-09-21T16:42:27.195Z
  • 2026-09-21T16:42:27.199Z
  • 2026-09-21T16:42:27.200Z
  • 2026-09-21T16:42:27.202Z
    Connection closed
  • 2026-09-21T16:42:27.206Z
  • 2026-09-21T16:42:27.207Z
  • 2026-09-21T16:42:27.209Z
  • 2026-09-21T16:42:27.210Z
    Connection closed
  • 2026-09-21T16:42:27.213Z
  • 2026-09-21T16:42:27.215Z
  • 2026-09-21T16:42:27.216Z
    No Data
  • 2026-09-21T16:42:27.217Z
    Connection closed
  • 2026-09-21T16:42:37.220Z
    Get Data
  • 2026-09-21T16:42:37.222Z
  • 2026-09-21T16:42:37.228Z
  • 2026-09-21T16:42:37.231Z
  • 2026-09-21T16:42:37.234Z
  • 2026-09-21T16:42:37.236Z
    Connection closed
  • 2026-09-21T16:42:37.240Z
  • 2026-09-21T16:42:37.241Z
  • 2026-09-21T16:42:37.244Z
  • 2026-09-21T16:42:37.246Z
    Connection closed
  • 2026-09-21T16:42:37.256Z
  • 2026-09-21T16:42:37.258Z
  • 2026-09-21T16:42:37.260Z
  • 2026-09-21T16:42:37.263Z
    Connection closed
MODBUS TCP:
2026-09-21T16:55:14.038Z
  • 2026-09-21T16:55:14.039Z
    Using Modbus slave ID 1 when registering sensor 3161728911
  • 2026-09-21T16:55:14.040Z
    Checking register 14 for grid frequency (modbus_tcp protocol):
  • 2026-09-21T16:55:14.044Z
    send_request: slave = 1, start = 14, end = 14, fc = 3
  • 2026-09-21T16:55:14.054Z
    Register 14 (sofar_lsw3): Error reading - MODBUS TCP exception response (function code 131, exception code 2)
    Returned null.
  • 2026-09-21T16:55:14.055Z
    send_request: slave = 1, start = 1156, end = 1156, fc = 3
  • 2026-09-21T16:55:14.058Z
    Connection closed
  • 2026-09-21T16:55:14.061Z
    Register 1156 buffer: [19, 133]
    Register 1156 readInt16BE(0) = 4997
  • 2026-09-21T16:55:14.062Z
    Register 1156 (sofar_g3hyd): Raw value = 4997, Hz = 49.97
    Frequency 49.97 is good - MATCHED sofar_g3hyd
    send_request: slave = 1, start = 1540, end = 1540, fc = 3
  • 2026-09-21T16:55:14.064Z
    Connection closed
  • 2026-09-21T16:55:14.066Z
    Register 1540 buffer: [15, 132]
  • 2026-09-21T16:55:14.067Z
    Register 1540 readInt16BE(0) = 3972
    Register 1540 reports battery voltage raw value 3972. Confirming sofar_g3hyd profile.
  • 2026-09-21T16:55:14.068Z
    Successfully registered inverter with profile: sofar_g3hyd
  • 2026-09-21T16:55:14.070Z
    Connection closed
  • 2026-09-21T16:55:14.085Z
  • 2026-09-21T16:55:14.092Z
    ************** App has initialised. ***************
  • 2026-09-21T16:55:14.119Z
    2026-09-21T16:55:14.119Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
  • 2026-09-21T16:55:14.125Z
    2026-09-21T16:55:14.125Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
  • 2026-09-21T16:55:14.130Z
    2026-09-21T16:55:14.129Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
  • 2026-09-21T16:55:14.134Z
    2026-09-21T16:55:14.133Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
  • 2026-09-21T16:55:14.327Z
    Get Data
  • 2026-09-21T16:55:14.329Z
  • 2026-09-21T16:55:14.332Z
    2026-09-21T16:55:14.332Z [log] [ManagerDrivers] [Driver:battery] [Device:45998752-8325-4df2-a5a5-0bbdf60f7b49] BatteryDevice has been initialized
  • 2026-09-21T16:55:14.336Z
    2026-09-21T16:55:14.335Z [log] [ManagerDrivers] [Driver:summary] [Device:24057194-b6ef-46fd-9c89-c083bccada2d] StationDevice has been initialized
  • 2026-09-21T16:55:14.341Z
  • 2026-09-21T16:55:14.343Z
    Connection closed
  • 2026-09-21T16:55:14.348Z
    2026-09-21T16:55:14.348Z [log] [ManagerDrivers] [Driver:solar_panel] [Device:b3a229a3-2ce6-4050-8315-3877011e39ee] SolarPanelDevice has been initialized
  • 2026-09-21T16:55:14.351Z
  • 2026-09-21T16:55:14.354Z
    Connection closed
  • 2026-09-21T16:55:14.358Z
  • 2026-09-21T16:55:14.360Z
    Connection closed
  • 2026-09-21T16:55:14.364Z
  • 2026-09-21T16:55:14.366Z
    Connection closed
  • 2026-09-21T16:55:14.372Z
  • 2026-09-21T16:55:14.375Z
    Connection closed
  • 2026-09-21T16:55:14.378Z
  • 2026-09-21T16:55:14.380Z
    Connection closed
  • 2026-09-21T16:55:14.384Z
  • 2026-09-21T16:55:14.386Z
    Connection closed
  • 2026-09-21T16:55:14.388Z
  • 2026-09-21T16:55:14.390Z
    Connection closed
  • 2026-09-21T16:55:14.393Z
  • 2026-09-21T16:55:14.394Z
    Connection closed
  • 2026-09-21T16:55:14.397Z
  • 2026-09-21T16:55:14.398Z
    Connection closed
  • 2026-09-21T16:55:14.401Z
  • 2026-09-21T16:55:14.403Z
    Connection closed
  • 2026-09-21T16:55:14.468Z
    Inverter data: : 3161728911, {
    “Inverter_status”: “grid-connected”,
    “Ambient_temperature”: 36,
    “Heatsink_Temperature”: 37,
    “Internal_Temperature”: 36,
    “Grid_Voltage”: 227.20000000000002,
    “Grid_Current”: 1.29,
    “Grid_Frequency”: 49.97,
    “Grid_Power”: 610,
    “Consumption”: 610,
    “PV1_Voltage”: 322.90000000000003,
    “PV1_Current”: 0.47000000000000003,
    “PV1_Power”: 150,
    “PV2_Voltage”: 310,
    “PV2_Current”: 0.34,
    “PV2_Power”: 100,
    “PV_Power”: 200,
    “Battery_Power”: -450,
    “Battery_Charge”: 99,
    “Battery_SOH”: 100,
    “Battery_Voltage”: 396.6,
    “Battery_Current”: -1.17,
    “Battery_Temperature”: 40,
    “Battery_Cycles”: 15,
    “Daily_Production”: 30.59,
    “Battery_Charge_Today”: 6.04,
    “Battery_Discharge_Today”: 3.35,
    “Battery_Charge_Total”: 190,
    “Battery_Discharge_Total”: 159.4,
    “Import_Today”: 0.14,
    “Export_Today”: 16,
    “Total_Import”: 34.9,
    “Total_Export”: 484.40000000000003,
    “Consumed_Today”: 9.73,
    “Total_Consumption”: 390.6,
    “Total_Generation”: 960.4000000000001,
    “Daily_Battery_Charge”: 6.04,
    “Total_Battery_Charge”: 190,
    “Daily_Battery_Discharge”: 3.35,
    “Total_Battery_Discharge”: 159.4
  • 2026-09-21T16:55:14.494Z
    Connection closed
  • 2026-09-21T16:55:14.566Z
    2026-09-21T16:55:14.565Z [log] [ManagerDrivers] [Driver:grid] [Device:6684f325-2492-469f-a3c5-83c566e1daf1] GridDevice has been initialized
  • 2026-09-21T16:55:19.145Z
    Found Inverter: IP: 10.10.0.253, S.No: 3161728911
  • 2026-09-21T16:55:19.147Z
  • 2026-09-21T16:55:24.479Z
    Get Data
  • 2026-09-21T16:55:24.481Z
  • 2026-09-21T16:55:24.491Z
  • 2026-09-21T16:55:24.492Z
  • 2026-09-21T16:55:24.493Z
  • 2026-09-21T16:55:24.495Z
    Connection closed
  • 2026-09-21T16:55:24.498Z
  • 2026-09-21T16:55:24.499Z
  • 2026-09-21T16:55:24.500Z
  • 2026-09-21T16:55:24.502Z
    Connection closed
  • 2026-09-21T16:55:24.504Z
  • 2026-09-21T16:55:24.505Z
  • 2026-09-21T16:55:24.506Z
  • 2026-09-21T16:55:24.508Z
    Connection closed
  • 2026-09-21T16:55:24.511Z
  • 2026-09-21T16:55:24.512Z
  • 2026-09-21T16:55:24.513Z
  • 2026-09-21T16:55:24.515Z
    Connection closed
  • 2026-09-21T16:55:24.518Z
  • 2026-09-21T16:55:24.519Z
  • 2026-09-21T16:55:24.521Z
  • 2026-09-21T16:55:24.523Z
    Connection closed
  • 2026-09-21T16:55:24.526Z
  • 2026-09-21T16:55:24.527Z
  • 2026-09-21T16:55:24.529Z
  • 2026-09-21T16:55:24.530Z
    Connection closed
  • 2026-09-21T16:55:24.533Z
  • 2026-09-21T16:55:24.534Z
  • 2026-09-21T16:55:24.535Z
  • 2026-09-21T16:55:24.537Z
    Connection closed
  • 2026-09-21T16:55:24.540Z
  • 2026-09-21T16:55:24.541Z
  • 2026-09-21T16:55:24.542Z
  • 2026-09-21T16:55:24.544Z
    Connection closed
  • 2026-09-21T16:55:24.546Z
  • 2026-09-21T16:55:24.548Z
  • 2026-09-21T16:55:24.549Z
  • 2026-09-21T16:55:24.551Z
    Connection closed
  • 2026-09-21T16:55:24.595Z
  • 2026-09-21T16:55:24.596Z
  • 2026-09-21T16:55:24.597Z
  • 2026-09-21T16:55:24.599Z
    Connection closed
  • 2026-09-21T16:55:24.607Z
  • 2026-09-21T16:55:24.608Z
  • 2026-09-21T16:55:24.609Z
  • 2026-09-21T16:55:24.610Z
    Connection closed
  • 2026-09-21T16:55:24.613Z
  • 2026-09-21T16:55:24.614Z
  • 2026-09-21T16:55:24.615Z
    No Data
  • 2026-09-21T16:55:24.616Z
    Connection closed
  • 2026-09-21T16:55:34.636Z
    Get Data
  • 2026-09-21T16:55:34.637Z
  • 2026-09-21T16:55:34.643Z
  • 2026-09-21T16:55:34.644Z
  • 2026-09-21T16:55:34.646Z
  • 2026-09-21T16:55:34.648Z
    Connection closed
  • 2026-09-21T16:55:34.652Z
  • 2026-09-21T16:55:34.653Z
  • 2026-09-21T16:55:34.654Z
  • 2026-09-21T16:55:34.655Z
    Connection closed
  • 2026-09-21T16:55:34.659Z
  • 2026-09-21T16:55:34.660Z
  • 2026-09-21T16:55:34.661Z
  • 2026-09-21T16:55:34.663Z
    Connection closed
  • 2026-09-21T16:55:34.665Z
  • 2026-09-21T16:55:34.666Z
  • 2026-09-21T16:55:34.667Z
  • 2026-09-21T16:55:34.669Z
    Connection closed
  • 2026-09-21T16:55:34.671Z
  • 2026-09-21T16:55:34.672Z
  • 2026-09-21T16:55:34.673Z
  • 2026-09-21T16:55:34.675Z
    Connection closed
  • 2026-09-21T16:55:34.678Z
  • 2026-09-21T16:55:34.679Z
  • 2026-09-21T16:55:34.680Z
  • 2026-09-21T16:55:34.682Z
    Connection closed
  • 2026-09-21T16:55:34.684Z
  • 2026-09-21T16:55:34.685Z
  • 2026-09-21T16:55:34.686Z
  • 2026-09-21T16:55:34.687Z
    Connection closed
  • 2026-09-21T16:55:34.690Z
  • 2026-09-21T16:55:34.691Z
  • 2026-09-21T16:55:34.692Z
  • 2026-09-21T16:55:34.694Z
    Connection closed
  • 2026-09-21T16:55:34.698Z
  • 2026-09-21T16:55:34.699Z
  • 2026-09-21T16:55:34.701Z
  • 2026-09-21T16:55:34.702Z
    Connection closed
  • 2026-09-21T16:55:34.713Z
  • 2026-09-21T16:55:34.714Z
  • 2026-09-21T16:55:34.715Z
  • 2026-09-21T16:55:34.718Z
    Connection closed
  • 2026-09-21T16:55:34.720Z
  • 2026-09-21T16:55:34.721Z
  • 2026-09-21T16:55:34.722Z
  • 2026-09-21T16:55:34.724Z
    Connection closed
  • 2026-09-21T16:55:34.727Z
  • 2026-09-21T16:55:34.728Z
  • 2026-09-21T16:55:34.729Z
    No Data
  • 2026-09-21T16:55:34.730Z
    Connection closed
  • 2026-09-21T16:55:44.756Z
    Get Data
  • 2026-09-21T16:55:44.757Z
  • 2026-09-21T16:55:44.764Z
  • 2026-09-21T16:55:44.765Z
  • 2026-09-21T16:55:44.767Z
  • 2026-09-21T16:55:44.769Z
    Connection closed
  • 2026-09-21T16:55:44.772Z
  • 2026-09-21T16:55:44.773Z
  • 2026-09-21T16:55:44.774Z
  • 2026-09-21T16:55:44.776Z
    Connection closed
  • 2026-09-21T16:55:44.779Z
  • 2026-09-21T16:55:44.780Z
  • 2026-09-21T16:55:44.781Z
  • 2026-09-21T16:55:44.783Z
    Connection closed
  • 2026-09-21T16:55:44.785Z
  • 2026-09-21T16:55:44.786Z
  • 2026-09-21T16:55:44.787Z
  • 2026-09-21T16:55:44.789Z
    Connection closed
  • 2026-09-21T16:55:44.792Z
  • 2026-09-21T16:55:44.793Z
  • 2026-09-21T16:55:44.794Z
  • 2026-09-21T16:55:44.795Z
    Connection closed
  • 2026-09-21T16:55:44.799Z
  • 2026-09-21T16:55:44.800Z
  • 2026-09-21T16:55:44.801Z
  • 2026-09-21T16:55:44.803Z
    Connection closed
  • 2026-09-21T16:55:44.805Z
  • 2026-09-21T16:55:44.806Z
  • 2026-09-21T16:55:44.807Z
  • 2026-09-21T16:55:44.809Z
    Connection closed
  • 2026-09-21T16:55:44.812Z
  • 2026-09-21T16:55:44.814Z
  • 2026-09-21T16:55:44.816Z
    Connection closed
  • 2026-09-21T16:55:44.820Z
  • 2026-09-21T16:55:44.821Z
  • 2026-09-21T16:55:44.822Z
  • 2026-09-21T16:55:44.824Z
    Connection closed
  • 2026-09-21T16:55:44.826Z
  • 2026-09-21T16:55:44.827Z
  • 2026-09-21T16:55:44.828Z
  • 2026-09-21T16:55:44.829Z
    Connection closed
  • 2026-09-21T16:55:44.833Z
  • 2026-09-21T16:55:44.834Z
  • 2026-09-21T16:55:44.835Z
  • 2026-09-21T16:55:44.837Z
    Connection closed
  • 2026-09-21T16:55:44.844Z
  • 2026-09-21T16:55:44.845Z
  • 2026-09-21T16:55:44.846Z
    No Data
  • 2026-09-21T16:55:44.848Z
    Connection closed
  • 2026-09-21T16:55:54.873Z
    Get Data
  • 2026-09-21T16:55:54.874Z
  • 2026-09-21T16:55:54.881Z
  • 2026-09-21T16:55:54.883Z
  • 2026-09-21T16:55:54.884Z
  • 2026-09-21T16:55:54.886Z
    Connection closed
  • 2026-09-21T16:55:54.888Z
  • 2026-09-21T16:55:54.889Z
  • 2026-09-21T16:55:54.890Z
  • 2026-09-21T16:55:54.892Z
    Connection closed
  • 2026-09-21T16:55:54.894Z
  • 2026-09-21T16:55:54.896Z
  • 2026-09-21T16:55:54.897Z
  • 2026-09-21T16:55:54.898Z
    Connection closed
  • 2026-09-21T16:55:54.901Z
  • 2026-09-21T16:55:54.903Z
  • 2026-09-21T16:55:54.904Z
  • 2026-09-21T16:55:54.906Z
    Connection closed
  • 2026-09-21T16:55:54.908Z
  • 2026-09-21T16:55:54.909Z
  • 2026-09-21T16:55:54.910Z
  • 2026-09-21T16:55:54.912Z
    Connection closed
  • 2026-09-21T16:55:54.915Z
  • 2026-09-21T16:55:54.916Z
  • 2026-09-21T16:55:54.917Z
  • 2026-09-21T16:55:54.919Z
    Connection closed
  • 2026-09-21T16:55:54.921Z
  • 2026-09-21T16:55:54.922Z
  • 2026-09-21T16:55:54.923Z
  • 2026-09-21T16:55:54.925Z
    Connection closed
  • 2026-09-21T16:55:54.929Z
  • 2026-09-21T16:55:54.930Z
  • 2026-09-21T16:55:54.931Z
  • 2026-09-21T16:55:54.933Z
    Connection closed
  • 2026-09-21T16:55:54.935Z
  • 2026-09-21T16:55:54.936Z
  • 2026-09-21T16:55:54.937Z
  • 2026-09-21T16:55:54.939Z
    Connection closed
  • 2026-09-21T16:55:54.943Z
  • 2026-09-21T16:55:54.945Z
  • 2026-09-21T16:55:54.946Z
  • 2026-09-21T16:55:54.948Z
    Connection closed
  • 2026-09-21T16:55:54.952Z
  • 2026-09-21T16:55:54.953Z
  • 2026-09-21T16:55:54.954Z
  • 2026-09-21T16:55:54.956Z
    Connection closed
Not sure whether you are aware, but please consider using the following options when posting logs, code, etc., to increase readability of your post:
  • Preformatted text option to keep the output in the original format and presented in a scrollable window. This reduces the length of your post.
  • Hide details option, to collapse/hide the entire interview output. Clicking the collapsed item will show the interview output again.
I will need to check as it’s strange it reads OK during discovery and then fails when added. I wonder if it switches back to V5. I had no way to test the TCP connection so it’s possible I have missed something.
Good morning Adrian,
If I can provide any support by doing certain things or sending log files, that is absolutely no problem, Andrian. I’d be more than happy to help.
I’m actually interested in seeing if I can develop something similar to an EMS (Energy Management System) that would also make it possible to send commands to the Sofar.
In the Netherlands, the net metering scheme will be abolished as of January 1, 2027, and you will have to pay when feeding electricity back into the grid.
What I ultimately want to achieve is for the system to monitor my dynamic energy contract and make decisions based on the current electricity prices. For example, if electricity prices are low and there is little or no solar energy available, it could charge the battery from the grid and then use that stored energy during the evening when electricity prices are higher.
That way, the system could automatically optimize when to charge and discharge the battery based on electricity prices and solar production.
I have published a new test version.
It seems for TCP it requires a persistent connection, whereas V5 needs a new connection for each request. So I think the TCP mode was blocking due to too many connection requests.
Hi Adrian,
I have updated to test version 1.59.
I am currently testing Solarman V5 on IP address 10.10.0.253, but this does not seem to be working correctly. As far as I can see, I am only getting error messages.
Also, as far as I can tell, the system has not received any updates from the Sofar app to Homey for about 20 hours.
I’ll take some screenshots of how the app is currently configured.
Update: now i cant add them anymore (screenschot)
SOLARMAN V5
* 2026-09-22T15:06:57.200Z
* 2026-09-22T15:06:57.231Z
2026-09-22T15:06:57.231Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
* 2026-09-22T15:06:57.237Z
2026-09-22T15:06:57.237Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
* 2026-09-22T15:06:57.242Z
2026-09-22T15:06:57.242Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
* 2026-09-22T15:06:57.247Z
2026-09-22T15:06:57.247Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
* 2026-09-22T15:06:57.382Z
Get Data
* 2026-09-22T15:06:57.383Z
No inverters found
* 2026-09-22T15:06:57.388Z
Restarting inverter scan because no inverters are currently registered
* 2026-09-22T15:06:57.390Z
2026-09-22T15:06:57.390Z [log] [ManagerDrivers] [Driver:battery] [Device:45998752-8325-4df2-a5a5-0bbdf60f7b49] BatteryDevice has been initialized
* 2026-09-22T15:06:57.394Z
2026-09-22T15:06:57.394Z [log] [ManagerDrivers] [Driver:summary] [Device:24057194-b6ef-46fd-9c89-c083bccada2d] StationDevice has been initialized
* 2026-09-22T15:06:57.400Z
2026-09-22T15:06:57.400Z [log] [ManagerDrivers] [Driver:grid] [Device:6684f325-2492-469f-a3c5-83c566e1daf1] GridDevice has been initialized
* 2026-09-22T15:06:57.403Z
2026-09-22T15:06:57.403Z [log] [ManagerDrivers] [Driver:solar_panel] [Device:b3a229a3-2ce6-4050-8315-3877011e39ee] SolarPanelDevice has been initialized
* 2026-09-22T15:07:02.245Z
* 2026-09-22T15:07:02.248Z
* 2026-09-22T15:07:02.250Z
Checking register 14 for grid frequency (solarman protocol):
* 2026-09-22T15:07:02.255Z
* 2026-09-22T15:07:02.269Z
Connection ended
* 2026-09-22T15:07:02.272Z
Connection closed
* 2026-09-22T15:07:02.274Z
Register 14 buffer: []
* 2026-09-22T15:07:02.276Z
* 2026-09-22T15:07:02.277Z
Returned null.
* 2026-09-22T15:07:02.279Z
* 2026-09-22T15:07:02.296Z
Connection ended
* 2026-09-22T15:07:02.299Z
Connection closed
* 2026-09-22T15:07:02.301Z
Register 1156 buffer: []
* 2026-09-22T15:07:02.303Z
* 2026-09-22T15:07:02.305Z
Returned null.
* 2026-09-22T15:07:02.306Z
send_request: slave = 1, start = 524, end = 524, fc = 3
* 2026-09-22T15:07:02.316Z
Connection ended
* 2026-09-22T15:07:02.318Z
Connection closed
* 2026-09-22T15:07:02.319Z
Register 524 buffer: []
* 2026-09-22T15:07:02.320Z
Returned null.
* 2026-09-22T15:07:02.322Z
send_request: slave = 1, start = 33282, end = 33282, fc = 3
* 2026-09-22T15:07:02.342Z
Connection ended
* 2026-09-22T15:07:02.345Z
Connection closed
* 2026-09-22T15:07:02.348Z
Register 33282 buffer: []
* 2026-09-22T15:07:02.350Z
* 2026-09-22T15:07:02.351Z
Returned null.
* 2026-09-22T15:07:02.352Z
send_request: slave = 1, start = 609, end = 609, fc = 3
* 2026-09-22T15:07:02.361Z
Connection ended
* 2026-09-22T15:07:02.362Z
Connection closed
* 2026-09-22T15:07:02.363Z
Register 609 buffer: []
* 2026-09-22T15:07:02.364Z
* 2026-09-22T15:07:02.365Z
Returned null.
* 2026-09-22T15:07:02.366Z
* 2026-09-22T15:07:02.375Z
Connection ended
* 2026-09-22T15:07:02.378Z
Connection closed
* 2026-09-22T15:07:02.379Z
* 2026-09-22T15:07:02.381Z
* 2026-09-22T15:07:02.382Z
Returned null.
* 2026-09-22T15:07:02.383Z
send_request: slave = 1, start = 552, end = 552, fc = 3
* 2026-09-22T15:07:02.400Z
Connection ended
* 2026-09-22T15:07:02.404Z
Connection closed
* 2026-09-22T15:07:02.406Z
Register 552 buffer: []
* 2026-09-22T15:07:02.408Z
* 2026-09-22T15:07:02.409Z
Returned null.
* 2026-09-22T15:07:02.410Z
send_request: slave = 1, start = 79, end = 79, fc = 3
* 2026-09-22T15:07:02.418Z
Connection ended
* 2026-09-22T15:07:02.420Z
Connection closed
* 2026-09-22T15:07:02.421Z
Register 79 buffer: []
* 2026-09-22T15:07:02.422Z
* 2026-09-22T15:07:02.424Z
Returned null.
* 2026-09-22T15:07:07.390Z
Get Data
* 2026-09-22T15:07:07.393Z
No inverters found
* 2026-09-22T15:07:07.394Z
Scanner restart skipped due to cooldown (49990ms remaining). Requested reason: Restarting inverter scan because no inverters are currently registered
But why are you trying the V5 when it seems the TCP method works for you?
I have tried all the available options, but unfortunately, nothing seems to work since this version.
Please see below for the results of two tests One test with the IP address manually set to 253. One test with the IP address removed.
Could you please have a look at the log files?
With Manual IP:
  • 2026-09-23T05:50:16.048Z
  • 2026-09-23T05:50:16.049Z
  • 2026-09-23T05:50:16.050Z
  • 2026-09-23T05:50:16.054Z
  • 2026-09-23T05:50:16.066Z
  • 2026-09-23T05:50:16.068Z
    Register 14 (sofar_lsw3): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.069Z
  • 2026-09-23T05:50:16.077Z
  • 2026-09-23T05:50:16.078Z
    Register 1156 (sofar_g3hyd): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.084Z
  • 2026-09-23T05:50:16.085Z
    Register 524 (sofar_hy_es): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
  • 2026-09-23T05:50:16.086Z
    Returned null.
  • 2026-09-23T05:50:16.087Z
  • 2026-09-23T05:50:16.092Z
  • 2026-09-23T05:50:16.093Z
    Register 33282 (solis_hybrid): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.094Z
  • 2026-09-23T05:50:16.100Z
    Register 609 (sun3p): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
  • 2026-09-23T05:50:16.101Z
    Returned null.
  • 2026-09-23T05:50:16.105Z
  • 2026-09-23T05:50:16.106Z
    Register 1156 (sofar_ktlx_g): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.111Z
    Register 552 (deye_sg04lp3): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.112Z
  • 2026-09-23T05:50:16.115Z
  • 2026-09-23T05:50:16.116Z
    Register 79 (deye_sg04lp3): Error reading - Connection error to 10.10.0.253:502 (ECONNREFUSED)
    Returned null.
  • 2026-09-23T05:50:16.128Z
  • 2026-09-23T05:50:16.134Z
  • 2026-09-23T05:50:16.150Z
    2026-09-23T05:50:16.150Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
  • 2026-09-23T05:50:16.154Z
    2026-09-23T05:50:16.154Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
  • 2026-09-23T05:50:16.158Z
    2026-09-23T05:50:16.158Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
  • 2026-09-23T05:50:16.161Z
    2026-09-23T05:50:16.161Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
  • 2026-09-23T05:50:21.168Z
  • 2026-09-23T05:50:21.169Z
  • 2026-09-23T05:50:21.171Z
  • 2026-09-23T05:50:21.173Z
  • 2026-09-23T05:50:21.182Z
  • 2026-09-23T05:50:21.184Z
  • 2026-09-23T05:50:21.185Z
    Returned null.
  • 2026-09-23T05:50:21.186Z
  • 2026-09-23T05:50:21.192Z
  • 2026-09-23T05:50:21.194Z
  • 2026-09-23T05:50:21.195Z
    Returned null.
  • 2026-09-23T05:50:21.196Z
  • 2026-09-23T05:50:21.200Z
  • 2026-09-23T05:50:21.201Z
  • 2026-09-23T05:50:21.202Z
    Returned null.
  • 2026-09-23T05:50:21.203Z
  • 2026-09-23T05:50:21.206Z
  • 2026-09-23T05:50:21.208Z
    Returned null.
  • 2026-09-23T05:50:21.209Z
  • 2026-09-23T05:50:21.213Z
  • 2026-09-23T05:50:21.214Z
  • 2026-09-23T05:50:21.215Z
    Returned null.
  • 2026-09-23T05:50:21.216Z
  • 2026-09-23T05:50:21.220Z
  • 2026-09-23T05:50:21.221Z
  • 2026-09-23T05:50:21.222Z
    Returned null.
  • 2026-09-23T05:50:21.224Z
  • 2026-09-23T05:50:21.228Z
  • 2026-09-23T05:50:21.231Z
  • 2026-09-23T05:50:21.232Z
    Returned null.
  • 2026-09-23T05:50:21.233Z
  • 2026-09-23T05:50:21.238Z
  • 2026-09-23T05:50:21.239Z
  • 2026-09-23T05:50:21.240Z
    Returned null.
Manual IP remove:
  • 2026-09-23T05:51:59.550Z
  • 2026-09-23T05:51:59.563Z
  • 2026-09-23T05:51:59.568Z
  • 2026-09-23T05:51:59.584Z
    2026-09-23T05:51:59.584Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
  • 2026-09-23T05:51:59.588Z
    2026-09-23T05:51:59.588Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
  • 2026-09-23T05:51:59.592Z
    2026-09-23T05:51:59.592Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
  • 2026-09-23T05:51:59.596Z
    2026-09-23T05:51:59.596Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
  • 2026-09-23T05:52:04.644Z
  • 2026-09-23T05:52:04.650Z
  • 2026-09-23T05:52:04.653Z
  • 2026-09-23T05:52:04.658Z
  • 2026-09-23T05:52:04.669Z
  • 2026-09-23T05:52:04.671Z
    Returned null.
  • 2026-09-23T05:52:04.673Z
  • 2026-09-23T05:52:04.679Z
  • 2026-09-23T05:52:04.680Z
  • 2026-09-23T05:52:04.681Z
    Returned null.
  • 2026-09-23T05:52:04.682Z
  • 2026-09-23T05:52:04.687Z
  • 2026-09-23T05:52:04.688Z
  • 2026-09-23T05:52:04.689Z
    Returned null.
  • 2026-09-23T05:52:04.690Z
  • 2026-09-23T05:52:04.696Z
  • 2026-09-23T05:52:04.697Z
    Returned null.
  • 2026-09-23T05:52:04.698Z
  • 2026-09-23T05:52:04.705Z
  • 2026-09-23T05:52:04.706Z
  • 2026-09-23T05:52:04.707Z
    Returned null.
  • 2026-09-23T05:52:04.708Z
  • 2026-09-23T05:52:04.719Z
  • 2026-09-23T05:52:04.721Z
  • 2026-09-23T05:52:04.722Z
    Returned null.
  • 2026-09-23T05:52:04.723Z
  • 2026-09-23T05:52:04.748Z
  • 2026-09-23T05:52:04.750Z
  • 2026-09-23T05:52:04.751Z
    Returned null.
  • 2026-09-23T05:52:04.753Z
  • 2026-09-23T05:52:04.760Z
  • 2026-09-23T05:52:04.762Z
    Returned null.
when adding:
Kind regards,
It looks like the V5 protocol is try to use port 502 but that is the normal one for TCP.
In the app settings could you make sure the V5 port number is 8899.
Hi Adrian,
in the app is 8899
i have it now on MODBUS TCP but nothing…
LOG:
LOG MODBUS
  • 2026-09-23T09:50:23.697Z
  • 2026-09-23T09:50:23.698Z
  • 2026-09-23T09:50:23.700Z
  • 2026-09-23T09:50:23.703Z
  • 2026-09-23T09:50:23.713Z
  • 2026-09-23T09:50:23.714Z
    Returned null.
  • 2026-09-23T09:50:28.719Z
    Connection timeout
  • 2026-09-23T09:50:28.723Z
    Register 1156 (sofar_g3hyd): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
  • 2026-09-23T09:50:28.724Z
    Returned null.
  • 2026-09-23T09:50:28.725Z
  • 2026-09-23T09:50:33.734Z
    Connection timeout
  • 2026-09-23T09:50:33.736Z
    Register 524 (sofar_hy_es): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
  • 2026-09-23T09:50:33.738Z
    Returned null.
  • 2026-09-23T09:50:33.739Z
  • 2026-09-23T09:50:38.768Z
    Connection timeout
  • 2026-09-23T09:50:38.769Z
    Register 33282 (solis_hybrid): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
  • 2026-09-23T09:50:38.770Z
    Returned null.
  • 2026-09-23T09:50:38.771Z
  • 2026-09-23T09:50:43.790Z
    Connection timeout
  • 2026-09-23T09:50:43.793Z
    Register 609 (sun3p): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
    Returned null.
  • 2026-09-23T09:50:43.794Z
  • 2026-09-23T09:50:48.817Z
    Connection timeout
  • 2026-09-23T09:50:48.820Z
    Register 1156 (sofar_ktlx_g): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
    Returned null.
  • 2026-09-23T09:50:48.821Z
  • 2026-09-23T09:50:53.824Z
    Connection timeout
  • 2026-09-23T09:50:53.827Z
    Register 552 (deye_sg04lp3): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
  • 2026-09-23T09:50:53.828Z
    Returned null.
  • 2026-09-23T09:50:58.855Z
    Connection timeout
  • 2026-09-23T09:50:58.858Z
    Register 79 (deye_sg04lp3): No probe match (Connection timeout: no response from 10.10.0.30:502 after 5000ms)
    Returned null.
  • 2026-09-23T09:50:58.875Z
  • 2026-09-23T09:50:58.881Z
  • 2026-09-23T09:50:58.896Z
    2026-09-23T09:50:58.896Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
  • 2026-09-23T09:50:58.901Z
    2026-09-23T09:50:58.901Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
  • 2026-09-23T09:50:58.905Z
    2026-09-23T09:50:58.905Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
  • 2026-09-23T09:50:58.908Z
    2026-09-23T09:50:58.908Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
  • 2026-09-23T09:51:03.993Z
  • 2026-09-23T09:51:03.995Z
  • 2026-09-23T09:51:03.996Z
  • 2026-09-23T09:51:03.998Z
  • 2026-09-23T09:51:04.006Z
  • 2026-09-23T09:51:04.008Z
  • 2026-09-23T09:51:04.010Z
    Returned null.
  • 2026-09-23T09:51:04.011Z
  • 2026-09-23T09:51:04.016Z
  • 2026-09-23T09:51:04.017Z
  • 2026-09-23T09:51:04.018Z
    Returned null.
  • 2026-09-23T09:51:04.019Z
  • 2026-09-23T09:51:04.024Z
  • 2026-09-23T09:51:04.026Z
  • 2026-09-23T09:51:04.027Z
    Returned null.
  • 2026-09-23T09:51:04.028Z
  • 2026-09-23T09:51:04.033Z
  • 2026-09-23T09:51:04.034Z
  • 2026-09-23T09:51:04.035Z
    Returned null.
  • 2026-09-23T09:51:04.036Z
  • 2026-09-23T09:51:04.041Z
  • 2026-09-23T09:51:04.042Z
  • 2026-09-23T09:51:04.044Z
    Returned null.
  • 2026-09-23T09:51:04.045Z
  • 2026-09-23T09:51:04.050Z
  • 2026-09-23T09:51:04.051Z
  • 2026-09-23T09:51:04.052Z
    Returned null.
  • 2026-09-23T09:51:04.053Z
  • 2026-09-23T09:51:04.058Z
  • 2026-09-23T09:51:04.060Z
    Returned null.
  • 2026-09-23T09:51:04.061Z
  • 2026-09-23T09:51:04.067Z
  • 2026-09-23T09:51:04.068Z
  • 2026-09-23T09:51:04.069Z
    Returned null.
