[App][Pro] Sofar (Release 1.1.58, Test 1.1.61)
@Adrian_Rockall 60hz - now 60.05Hz
hi,
yes 60hz, may vary to 60.06hz this morning
I have just checked and the app should accept up to 65Hz and I see from the log that you are using an older version. Could you install the test version as that should fix the issue.
i only find version 1.1.24 on homey app store
Did you follow the link above?
hello @Adrian_Rockall ,
i have installed the 1.1.28 test version and * 2025-04-17T22:12:49.737Z Frequency 59.95 is not valid
60.01 is not valid also
  • 2025-04-17T22:12:44.070Z
    ************** App has initialised. ***************
  • 2025-04-17T22:12:44.084Z
    2025-04-17T22:12:44.084Z [log] [ManagerDrivers] [Driver:battery] BatteryDriver has been initialized
  • 2025-04-17T22:12:44.089Z
    2025-04-17T22:12:44.089Z [log] [ManagerDrivers] [Driver:grid] GridDriver has been initialized
  • 2025-04-17T22:12:44.093Z
    2025-04-17T22:12:44.093Z [log] [ManagerDrivers] [Driver:solar_panel] SolarPanelDriver has been initialized
  • 2025-04-17T22:12:44.097Z
    2025-04-17T22:12:44.097Z [log] [ManagerDrivers] [Driver:summary] InverterDriver has been initialized
  • 2025-04-17T22:12:49.248Z
    Found Inverter: IP: 192.168.0.38, S.No: 2768796139
  • 2025-04-17T22:12:49.252Z
    Checking register 14 for grid frequency:
  • 2025-04-17T22:12:49.257Z
    send_request: start = 14, end = 14, fc = 3
  • 2025-04-17T22:12:49.532Z
    No MODBUS data to process data
  • 2025-04-17T22:12:49.538Z
    Returned null.
Checking register 1156 for grid frequency:
  • 2025-04-17T22:12:49.542Z
    send_request: start = 1156, end = 1156, fc = 3
  • 2025-04-17T22:12:49.729Z
    Data received: {
    “type”: “Buffer”,
    “data”: [
    23,
    107
  • 2025-04-17T22:12:49.737Z
  • 2025-04-17T22:12:49.739Z
    Returned null.
Checking register 524 for grid frequency:
  • 2025-04-17T22:12:49.741Z
    send_request: start = 524, end = 524, fc = 3
  • 2025-04-17T22:12:49.904Z
  • 2025-04-17T22:12:49.908Z
    Returned null.
Checking register 33282 for grid frequency:
  • 2025-04-17T22:12:49.909Z
    send_request: start = 33282, end = 33282, fc = 3
  • 2025-04-17T22:12:50.136Z
  • 2025-04-17T22:12:50.140Z
    Returned null.
  • 2025-04-17T22:12:50.142Z
    send_request: start = 609, end = 609, fc = 3
  • 2025-04-17T22:12:50.350Z
  • 2025-04-17T22:12:50.354Z
    Returned null.
No suitable inverters found
I have published a new test version that fixes a silly mistake with the range checking.
Hi @Adrian_Rockall ,
1.1.29 accept now 60hz +/- and i could install the 4 devices.
The app seem not to receive the voltage.
Br
Which voltage?
I can see the grid voltage, the PV voltages and the battery voltage in the log.
@Adrian_Rockall
sorry, i meant the battery voltage…and the inverter status.
BR
@Adrian_Rockall how the add this widget please ?
If you mean the dashboard widget, then open the dashboard, select the edit :pen:, tap on the +, then select the Apps tab and find the Sofar widget. In the customise screen select the devices for each category and save it. Finally click on Done.
@Adrian_Rockall
Sorry to make your precious time lost, i have found dashboard/widget on fone; i were looking for it on PC webpage. i could instal your sofar widget and it’s marvellous.
Unfortunately, Athom haven’t made dashboards work with the web app, which is very disappointing.
And no Windows desktop app neither
Grazie per l’app prima di tutto, vorrei chiedere se ci fosse una possibilità di escludere i valori fuori scala. nel mio insight trovo (forse a causa della connessione del logger con il wifi o altro) dei valori completamente errati che rovinano le statistiche. vedi allegato.
grazie.
It’s difficult to know what are bad values. I could put a setting for a limit.
I understand, actually setting some parameter ceiling could eliminate a lot of the problem Maybe even a value discard time setting. thanks for the support.
Hi, i have installed version 1.1.29 today and my app stop working.
  • 2025-05-12T17:33:21.391Z
    Found Inverter: IP: 192.168.1.133, S.No: 2734238489
  • 2025-05-12T17:33:21.398Z
  • 2025-05-12T17:33:26.515Z
    Returned null.
  • 2025-05-12T17:33:30.352Z
    Frequency 49.94 is good
  • 2025-05-12T17:33:30.357Z
    Found inverter
  • 2025-05-12T17:33:39.443Z
    Missing one or more of Frequency = 49.96, Consumption = 0, Grid_Voltage = 239, Total_Import = 0
  • 2025-05-12T17:33:52.116Z
    Missing one or more of Frequency = 49.95, Consumption = 0, Grid_Voltage = 239, Total_Import = 0
  • 2025-05-12T17:34:04.824Z
    Missing one or more of Frequency = 49.99, Consumption = 0, Grid_Voltage = 239.3, Total_Import = 0
  • 2025-05-12T17:34:17.361Z
  • 2025-05-12T17:34:29.740Z
    Missing one or more of Frequency = 50.01, Consumption = 0, Grid_Voltage = 239.10000000000002, Total_Import = 0
  • 2025-05-12T17:34:55.932Z
    Missing one or more of Frequency = 49.97, Consumption = 0, Grid_Voltage = 239.4, Total_Import = 0
  • 2025-05-12T17:35:08.249Z
    Missing one or more of Frequency = 49.96, Consumption = 0, Grid_Voltage = 239.60000000000002, Total_Import = 0
  • 2025-05-12T17:35:22.973Z
    Missing one or more of Frequency = 49.97, Consumption = 0, Grid_Voltage = 239.3, Total_Import = 0
  • 2025-05-12T17:35:37.581Z
    Missing one or more of Frequency = 49.93, Consumption = 0, Grid_Voltage = 238.70000000000002, Total_Import = 0
  • 2025-05-12T17:35:54.120Z
    Missing one or more of Frequency = 49.95, Consumption = 0, Grid_Voltage = 239.10000000000002, Total_Import = 0
  • 2025-05-12T17:36:17.011Z
    Missing one or more of Frequency = 49.97, Consumption = 0, Grid_Voltage = 239.10000000000002, Total_Import = 0
@Adrian_Rockall Thanks to your work we’ve been using your app for over a year.
About 6 days ago, the app lost contact with our inverter (but the inverter is posting readings to sofarman online. The app icon does not show offline, just 0 in the power readings, also the logger is 6 days old.
How to debug this?
e2039dcd-a124-43f7-9566-e677e8b32f41
