Data Pulse (available in Homey App Store)
Know when your Homey data stops arriving.
Formerly Data Watchdog
Starting with v0.1.2, the app was renamed to Data Pulse to better reflect its focus on data freshness and reliable delivery. Existing monitors, devices and Flows remain compatible.
Data Pulse monitors the Homey data sources that matter to you and warns when expected activity or fresh data stops arriving.
The important difference is that Data Pulse does not assume that an unchanged measurement means something is wrong. A temperature can stay at 21.3 °C for hours while the sensor is working perfectly.
Instead, you choose what actually counts as proof that a source is still alive and delivering correctly.
How does it work?
Data Pulse supports three monitoring methods:
Device activity
Checks whether Homey has seen the device recently.
This works well for devices that regularly report activity even when their measurements do not change.
Last data received
Uses a field whose value itself contains the time when fresh data was received.
For example, an integration may expose a last updated or last received timestamp that moves forward every time new data arrives.
A normal measurement such as temperature, CO₂ or power usage is not treated as a timestamp, and Homey’s lastUpdated metadata is not used as a substitute.
Flow confirmation
A Homey Flow explicitly tells Data Pulse that an update was successfully delivered.
This is useful for integrations or custom sources where you know exactly when delivery succeeded.
The confirmation should follow a real successful update. A repeating timer by itself is not proof that the source is working.
Simple setup
Adding monitors is deliberately kept compact:
Add monitor → choose a method → select one or more devices → set the timing → add monitors
The selected devices can share the same timing, while individual devices can still be adjusted when necessary.
Nothing is monitored automatically. You decide which sources are important enough to watch.
Incidents and recovery
Data Pulse does more than report individual stale sources.
If several monitored sources from the same integration stop reporting around the same time, they can be correlated into one integration incident.
Recovery is also handled deliberately: fresh updates must remain stable before an incident is closed. This helps avoid repeated stale/recovered notifications when a source is unstable.
Homey Flows
Data Pulse provides Flow cards for individual sources, integration incidents and general Data Pulse incidents.
For example:
WHEN
- Data Pulse incident started
- Data Pulse incident recovered
- Monitored source stopped updating
- Monitored source recovered
You decide what happens next: push notification, Timeline message, another Flow, or nothing at all.
There are also conditions and actions for checking monitored sources and for explicitly confirming successful delivery.
Local test source
Data Pulse includes an optional Data Pulse Test Source (simulation).
It can safely generate test updates locally so you can verify:
- stale detection
- recovery
- notification Flows
- Device activity
- Last data received
- Flow confirmation
It does not control or modify your production devices.
Data Pulse or Device Watchdog?
Data Pulse is deliberately focused on selected data sources and explicit evidence that data is still arriving.
If you are looking for broad, automatic device-health monitoring across your Homey, Device Watchdog may be a better fit.
The two apps approach reliability from different directions: Data Pulse is evidence-first and opt-in, while Device Watchdog is designed for broader automatic device monitoring.
Supported Homeys
Data Pulse requires a local Homey running Homey 12.9.0 or later.
The Homey App Store determines compatible Homey models from the app’s local platform and minimum Homey version.
Homey Cloud is not supported.
Privacy and local operation
Data Pulse runs locally on your Homey.
There is no Data Pulse cloud backend and no external service collecting your device data.
The app uses Homey’s local API to inspect the devices and integrations required for the monitors you configure.
Because of this, the app requires the homey:manager:api permission.
Available in the Homey App Store
Data Pulse is now available in the Homey App Store.
Current public release: v0.1.4
Source code and documentation
Data Pulse is developed publicly on GitHub:
The repository contains the source code, user guide, architecture documentation, self-test documentation and issue tracker.
The software is licensed under GPL-3.0-only. The Data Pulse name and visual branding remain separate from the software license.
Feedback and support
Questions, experiences and ideas are very welcome in this topic.
For reproducible bugs or technical issues, GitHub Issues is the best place:
Data Pulse is built around real-world use, so practical feedback is especially useful.
Support development
Data Pulse is a free community project developed in my spare time.
If you find it useful and would like to support the time and resources that go into development, testing and maintenance, a donation is always appreciated.
Support Arrow87:
Donations are completely optional and do not unlock features or support.
