I’ll look into it on my end and keep you posted. I might try setting up a log session for analysis.
To make the house look occupied and hopefully keep potential burglars away, I’ve added the following features to my existing setup:
- The blinds were opened and closed room by room, and if there are multiple blinds in a room, they were opened and closed with a random delay of 2–5 seconds to make it look as though they were being opened and closed manually at the push of a button.
- In the evening, the blinds were not closed all the way or all blinds to the same position, but randomly to a position between e.g. 9 and 15%, so that it would look even more like the blinds were being closed by a person rather than by an automated system.
- The roller shutters were not always opened or closed at exactly the same time or in response to the same solar event, instead they were opened and closed at slightly different times each day due to a time delay ranging from 0 to 20 minutes. Of course, the triggering factor was still based on a specific time, a solar event, or the brightness.
Would it be possible for you to add these features?
I have just completed an update, and it is now being published. Once it has been approved, I will go through the wizard again and try to incorporate your request.
Hi @Roy_PEDRINIS, I’ve noticed a few issues in the app’s Settings section.
When I try to add roller shutters and entrances, it doesn’t work. As soon as I scroll to the bottom, the screen scrolls back up:
Of course, I don’t know if you can fix this problem yourself or if it’s a general display issue with the Homey smartphone app.
I hope you understand the problem… ![]()
Thanks for the feedback; I’ll fix this issue sometime this week. Please make sure you’re using the latest version
I believe Homey will be releasing the first official version this week.
Hi Roy, thanks for the additions and the individuell lux-sensor for each blind.
Can you please add for each individuell lux value, triggers, too.
Not all of my sensors have the same trigger values. ![]()
Thanks
Started the first test, working as advertised for now. very cool!
I have two units, a blind and an awning one. the latter I dont want to drive in the winter against glaring, but do want to do that in the summer. is that distinction possible? The former should continue to work as currently, anti blinding throughout the year.
thanks!
Hello, thank you for the feedback. I can certainly add this feature and include it in the new version. ![]()
Hello, thank you for this feedback. I will look into what I can do to make improvements, while maintaining a certain logic of automation and intelligence.
Hello, thank you for this feedback. Indeed, this could be an improvement for the retractable awnings. I will see if I can include it in the next update or the one after that.
The update has just been completed.
I cant find the app anymore. has it been removed?
I still see it here..(?)
