[APP][Pro] Sensibo - Air Conditioning and Quality
New version, v. 1.10.0 with support for Sensibo Pure and Sensibo Room Sensor.
Won’t be released until you have tested :slight_smile:
V. 1.10.1 with a few fixes:
  • Added Control Pure Boost action for Sensibo Pure
  • Options for lights (on, off, dim) are now fetched from remote capabilities
Great app. Will it be made available for Homey Bridge as well?
hi @balmli,
I wonder if Sensibo Air works well? would like to buy if working on homey.
Have you read on the top of this page ?
yes I read it, but it has happened to me in other apps to have the device and it works poorly.
I didn’t want to be spending money and then not being able to use the device on homey.
Will this be available on homey cloud anytime soon?
Hi.
Any plans to support homey bridge?
I want to report a bug and a feature request.
bug:
power state is not working/synced.
In sensibo app the airco is ON (i turned airco on using the sensibo app) but in homey it is OFF
Waiting for hours it stays off…
I tried the syncpower state flow card and set it to ON state, nothing happens, in Homey the device states is still OFF, turning it OFF then in the sensibo app the power states it set to OFF.
But the power state in Homey is not updated when the airco is turned on or controlled by the sensibo app, something is going wrong and the de sensibo state is not updated in Homey (anymore).
Only after the app restart in Homey, Homey gave the correct status again.
feature request:
add device button to turn on swing (and lights) mode also fan speed speed, there are flow cards for these options but no device buttons to control it directly.
I hope the bug can be fixed soon.
At least a few of the “buttons” you request are found here:
ok, thx…
Hopefully the reported bug can be fixed in a feature release
Hi Bjørnar, great work on the app. It has been asked earlier, but no clear answer can be found: Are there plans to have an app for the Homey Bridge (not Pro). Homey isn’t very clear on the topic of backwards compatibility of apps.
Thank you.
dit zou ik ook graag willen weten.
alvast bedankt
Thanks for the awesome app. Has been working as intended since first installation.
One thing I’ve noticed though is that the time reported by my Sensibo Ssky seems to be 2h off. If my local time is 16:00, the device reports the time as 14:00. I can’t find any settings to change the time/timezone in either this app or Sensibo’s own app.
It doesn’t affect the function as of now, but I guess that my Insights might look off.
Can you please help me?
That can be related by a major change in SDKv3:
All SDKv3 apps run in the UTC timezone instead of local time.
No, there’s no plans for Homey Bridge.
There’s no support for time in the Homey app, so this must be a question for Sensibo.
Hi All,
I got 3 sensibo airQ’s. Installed 2 of them using the sensibo app and everything is working just fine.
Can’t seem to get them working with Homey though and I’ve followed all the instructions.
Installed APP on Homey
Created an API key
Add device - paste API key
And then no matter what I try it keeps saying that there are no devices to be added. I’ve spent the last hour googling the issue or searching the forums, but I can’t seem to find the answer in any of the recent posts.
Is this a bug? Is the new airQ not supported yet?
Best, Sander
I think i found a bug in the APP.
When you use the card ‘when AC state changed’ is used Homey reacts every few seconds if something is changed, but nothing is changed.
The AC is on and working but the trigger keeps triggering like something has changed.
On what should this trigger card even react, on which AC change should it react?
The “AC state changed” trigger, triggers when the app receives a new set of “AC states”…
And it has the following tokens:
  • status
  • reason
  • failure reason
  • on
  • fan level
  • target temperature
  • mode
  • swing
The app will only trigger once per “ac state”. And the app does not know which, if any, of the tokens that contains information about the actual change.
