[APP][Pro] Reflexion - Sungrow and other energy devices
There is a compliance check. Check if you have the latest version of Aikion? The compliance check enforced old values after a change in an older version.
Auktion will stop using forced mode entirely soon. It will no longer change the max charge, max discharge registers so the inverter will no longer get stuck in a state where it can’t charge or discharge. This problem can occur if the connection to the inverter is poor and multiple writes of the commands to set the max power levels fail. (We don’t want to update too often and retry too many times).
Check back in a few weeks and try Aikion again. It should handle poor connections best-in-class once this change is in.
This means, for better or worse, we will no longer use the firmware control loop to achieve Zero export for example. Aikion’s built-in control loop will handle all of our “combined EMS modes”.
Den lör 24 okt. 2026 13:50Xander Hoose <notifications@athom.discoursemail.com> skrev:
