[APP][Pro] PV Forecast: solar forecast that measures your roof and learns from your panels
That is great to see, thanks for sharing. Six roof planes is more than I can test on my own roof, so this tells me a lot, and it’s good to see the separate planes staying this close and not just the total.
If you feel like it, I’d like to know what the 7-day accuracy values on the device show.
Hi @weide43,
since you’ve added electricity prices (which is a fantastic improvement!), would you consider supporting external electricity prices from other Homey apps/devices?
Unfortunately, Homey Energy doesn’t yet allow apps to supply custom electricity prices, although Athom is planning to support this:
My suggestion would be to add an External (Flow) price source, with two action cards:
  • Set current electricity price – accepts a numeric price per kWh.
  • Set electricity price schedule – accepts a JSON array of hourly or 15-minute prices for today/tomorrow.
Ideally, import and export prices could be provided separately.
Apps such as Power by the Hour already expose electricity prices and future price schedules through Flow tags, so users could simply pass these values to PV Forecast through Advanced Flows.
PowerByTheHours
Or, maybe even easier, PV Forecast could allow users to select an existing Homey device and its electricity price capability, similar to how you already support selecting inverter and meter devices.
I noticed that your existing Find the cheapest start card already accepts external prices as JSON, so perhaps some of the necessary parsing logic is already there.
The main benefit would be reusing these prices across all PV Forecast functions, including battery planning, EV charging and negative-price handling, rather than only within one Flow calculation.
What do you think? Would this be technically feasible without introducing too much complexity?
On separate topic, also I tried today to set Bojler but getting this error, I believe I have all values correct ?
Hi @Sharkys,
Thanks, both are good points.
External prices: yes, that’s doable, and you’re right that the JSON parsing from Find the cheapest start can be reused. I’m thinking of a price source “From a Flow” with a card that takes the price schedule for today and tomorrow (hourly or per quarter, import and export separately). Then everything that uses prices follows it: the battery plan, car charging, appliances and negative prices. A current-price-only option from a device is easy to add too, but on its own it can’t plan ahead, so the schedule comes first. I’ll put it in the next feature version.
The heat buffer error: your values are fine, I checked them against the app’s own check. What fails is the step where the app makes sure the picked temperature and setpoint belong to that device, and the message didn’t say which part it didn’t like. Version 2.8.5 is live now and names the exact value and what Homey lists for that device. Could you update, try to save once more and post the new message here? And which app is the water heater from?
Thank you :wink:
Now it got saved without problem with the same values, thank you :wink:
Here’s a last-7-day view of my 6 roof planes. Impressive scores!
Note:
  • The 4th plane is a mix of 90° and 80° wall mounted panels
  • The 5th plane (East 90°) is way off because of the low sun angle this time of year, just too much shadows.
EDIT added a graph for the 6th plane (West 90°):
@Sharkys great, thanks for letting me know. If it ever comes back, the new message will say exactly what was missing.
@Peter_Kawa thanks, that’s a lovely set to see, and six planes tell me more than my own two. Planes 1 to 4 are about as close as I hoped.
About plane 5: the app learns its correction per position of the sun in the sky, not per hour of the day. So a fence, a tree or a house that blocks a patch of sky gets learned for exactly that patch. The low November sun moves through a part of the sky the app hasn’t seen much yet, so for now it leans on the neighbouring positions. It should come down over the next weeks without you doing anything, and next autumn it will already know.
Plane 6 looks like the chart was still loading in your screenshot. If it stays empty, could you post the device page or a diagnostics copy?
My pleasure!
Thanks, that makes absolutely much sense. I won’t touch it.
My bad, you’re right.
I also discovered today this particular inverter wasn’t Wifi connected for a few weeks :face_with_peeking_eye: Reconnected, it actually does generate a little bit, see today’s graph:
14-day graph (to complete my initial post):
Hi, was just wondering, if it would help, currently Power by the hour offers following action :
And JSON looks like this :
[5.2409,5.1144,4.9306,4.8121,5.1065,5.1242,4.816,5.0033,5.1916,4.93,4.4764,4.2518,4.8296,4.6667,4.5878,4.07,4.1989,4.2686,4.6777,4.5006,4.7716,5.074,4.9055,5.0813,4.8996,5.6606,6.0377,6.5747,6.1934,6.4302,6.7053,6.6382,6.9175,6.778,6.528,5.8911,5.7891,5.7986,5.0828,4.8597,4.8952,4.7241,4.336,4.0881,4.3147,4.1513,3.8386,3.6601,3.906,3.8954,4.3071,4.5987,5.5947,4.6877,4.1634,4.1424,4.2621,4.5961,5.1097,5.4138,5.4191,5.8231,6.1077,6.1497,5.9088,6.5711,6.8031,6.9512,6.7904,6.9358,7.1938,7.3507,7.1722,7.0821,7.0608,7.0558,6.9724,6.8262,6.809,6.6506,7.2801,6.6731,6.7588,5.8636,6.8403,6.0495,5.8613,5.1136,7.234,7.0555,6.6757,6.3507,6.6722,6.4219,6.4662,6.4405]
@Peter_Kawa good find, and that explains the empty chart. Your 14-day view also shows the expected line kept its normal shape while the inverter was offline, so those weeks didn’t teach the app that plane 6 makes nothing.
@Sharkys yes, that helps, thanks. A plain list of 96 numbers is a day in quarters from midnight, and the app already reads that shape in Find the cheapest start, so the new price source will take it as it is. The plan is one card for today and one for tomorrow: run both from Power by the Hour with its “today” and “tomorrow” choice. “The next hours” has no times in it, so the app can’t tell where it starts; better to leave that one out. Prices are used as they come, without conversion, so keep them in the same currency as the rest of your setup.
