Restarted the app and after that did not help restarted homey…. Wonder if I am the only one….
4a2e50ca-9aef-442a-b818-9640fdccb6ef
If you need it for trouble shooting
I just installed the version 6.3.0 on my HP23 and did also a restart and my 3 devices what i use with the PBTH app are still working.
Before the restart they also worked.
Restart was only to test if they were still working after the restart.
On my HP19 i am still on an older version.
Just need to be patient……it took nearly 1,5 hours to get most working again. Just a few left to fix,
Edit… all good again…. Just needed to wait for it……
No problem here (except I couldn’t enter a comma on the phone, needed to copy&paste it). Prices didn’t change, which was expected as we don’t have negative prices at the moment. I’ll check again after the regular price update at noon and report back if something broke.
As soon as we have negative prices again I’ll also report back, although I don’t expect to see those before summer.
This seems to be a bug in the smartphone app. Was already mentioned on January 1st (Link). I’ve created a ticket but haven’t received any feedback yet. Can you please also create a ticket?
The average price this month is calculated on a rolling daily basis. So it will start working correctly 1st of March, and the app needs to be running every day from then on (and receive correct prices for the day).
Thanks #Dijker, that’s was I was looking for. Homeyscript is i.m.o. a big advantage to use Homey and works very good, but the documentation on github is not very helpfull. Someone should write a manual / ebook about Homeyscript. Would gladly pay a price for that
Someone who knows if this is possible? What I want to achieve is the following:
I have a kWh meter that tracks my entire consumption and feed-in.
I have created a virtual device that reflects the value of the kWh meter and adds the value of the PV installation to it. This way, I know the net consumption in my home. This value is only in watts and doesn’t keep track of anything else. I actually want to know what my net consumption per day, week, and year is.
I tried creating a PBTH virtual device that reflects this value, but then I get very high values.
I have asking about this here now a few times now and have not got any answers. I having big issues with all my different PBBTH units measures negative numbers. I have testet different things a couple of weeks and found this. I have tracked the value that gets sent to PBTH and its calculated correct but never starts at 0. By midnight the shelly device or Pulse sends 0 but it does not start the next day a zero.
Please se this image. It resets every midnight but never back to zero.
What am I missing here? I really need help, been on this for quite some time now.
Thanks, yes hopefully
This example is from the Tibber Pulse using manual updates via Flow. Where I have set up that if the value from Pulse is negative then set it to zero, but the registered value in PBTH is negative anyway. The same happens with direct update from Tibber Pulse to PBTH.
I use the Consumption sine midnight from Tibber Pulse, I think that is kWh.
This is the Flow (Sorry for the swedish). But as you can see in the insight, it tracs the consumption correct but never reaches 0. So the cost is never correct.
Sinds the last update v6.3.1 Dap price TTF Leba energy gas dont work. I have restart the app but no price. The rate puts Homey in a good position in the device. So I miss that overview of a day. Homey2019
