Worked like a charm that. Thanks!
I try to add the WPH-01 to homey but it cannot find the button in the plejd Homey app while the button is available in Plejd app. When adding a DIM for example, it finds the button but installs it as a dimmer, which is not working obviously.
I found on GitHub people with same issue. Will this be fixed anytime soon?
Hei
Plejd scene has stopped working. Anyone have any tips to get it working. have tried to restart both the app and the entire homey pro 23.
I’ve got two WRT-01 dimmers that get added as normal buttons. Anyone know why this happens? There’s limited flows for these devices, «a button has been pressed» and «button X has been pressed», where the buttons are left/right up/down, which doesn’t make sense since the buttons is dimmers with only one rotary wheel.
How did you even manage to add them?
My Homey cannot find either WRT-01 or WPH-01 as buttons. They do appear when searching for “Plejd-devices”, but only as lightning devices with the wrong flow cards…
Hi. It seems the last update 9h ago broke the connection to all my devices. Is it something the user needs to do on our side? I tried to restart the app and Homey of course.
I’ve tried to add my buttons and my motion detector. The app finds all the products but when I add them I get a “Connecting to Plejd BLE mesh…” error. So I cant do anything. I’ve tried to restart my Homey, I’ve tried to uninstall and install the Plejd App again.
I have a Homey Pro 2026 and I have the Plejd Gateway as well. When using the official app for Plejd in Homey things are working. I really wanted the buttons and motion detector to work. ![]()
Same for me. All Plejd stopped working after the update. Running latest homey version
Samma här
It works greit for me running;
homey pro 2023 vesion 12.12.0
Plejd 3.5.3
amazing to finally be able to control my shades, thank you.
Have a problem where homey cant find Plejd scenes. So I can’t use double press. Anyone knows what I can try?
I’ve tried to restart and re enter my username and password in the app settings. Have also tried to re install the app.
Report: e1281dd7-cdfd-4cd4-9c34-6bc94708ece6
@Emil_Ohman any idea why the latest updates are breaking the devices for many of us? Anything we need to do on our side?
Here is a report of mine: 9271ebf2-f816-407e-bb23-edc52214a43a
3.5.4 fixed it all, thanks @Emil_Ohman ![]()
I can’t even download this. It says “not compatible with the chosen Homey” but in the description it’s suppose to work. I have a 2026 homey pro.
You likely also have a Homey Cloud instance. When you click Install, choose your Homey Pro from the list.
I have the same problem. Tried to change the password on my Plejd account, update password in Plejd app in Homey. Restart Homey. I have two Plejd systems I administrate if that can be a problem.
Only two options in the “Select scene” field: Everything on, everything off
When I enter a created scene in Plejd, I get no results found.
Homey Pro 2023 v. 13.0.0
Plejd v. 3.5.4
Report: a8b5c242-0787-416c-b7b7-9c32088680a0
Tried to see if having more then one system was the problem, so I moved all but the one I use with the homey over to my installer account. Now with only one system linked to the account, scenes work’s fine.
Thanks! Did the same thing, and now it works! ![]()
@Emil_Ohman possible to add dim/transition from current status? If the light status now is 50% and run a dim flow (100% → 5%) its not that smooth ![]()
Same here! When trying to select scenarios in my Homey flow I didn’t recognize the names. Turns out they were from the Plejd system at my office. After removing the other system the correct scenarios turn up. Any chance this could be fixed so that I can re-add the other system? @Emil_Ohman
Hi, Is it possible to adjust both color temperature and strength of light with this app on LED-75-V2?
