[APP][Pro] Plejd - Smart lighting for everyone (Community)
Question, i have a lot of plejd devices, and some thermostats as well. These have power consumption, but when i set ut the consumption on them they always report as ON (On should be when it actually have initiated the floor warming) would this be possible (youll loose standby on consumption i guess but)
hello,
All of my Plejd devices has become unavailable in Homey, and even if I try to re-add them they still remain unavailable?
Analytics code: dee5b50f-51a1-4519-bf0e-e5ae33f3d22e
Would be very thankful for some help!
Same here. Removed my other Plejd system. Then the scenarios at home re-appeared .
I have several HeatIt thermostats in my house and I’m satisfied with them. Now I’m going to renovate to bedrooms and will install thermostats on those. My electrician recommends Plejd thermostats since the HeatIt is a bit more expencive.
Anyone with experience with the Plejd ones? Do they work as well as HeatIt?
All my lights in the house is connected to Plejd so I like the system. Just doesn’t know how the thermostats is. I don’t own the gateway from Plejd. Is that necessary for the thermostat to work properly in Homey?
I rely like Plejd thermostat. So would definitely choose Plejd. The only downside is that Plejd don’t have energy monitoring.
Thanks for reply. Do they support integration with Homey without the gateway, or do you need that to get full potential?
I use it without the gateway
Plejd Room support – PR for simultaneous group dimming
Controlling several Plejd devices from Homey (for example with the < group > app) sends one BLE command per device. This causes a visible sequential dimming effect, since each light updates one after another instead of at the same time.
I’ve submitted a PR that adds a Plejd Room driver. It does not require any new grouping in Homey — it reads the Room exactly as it is already configured in the Plejd app/bridge setup, and pairs that Room as a single dimmable light in Homey. One command is sent to the Room’s own mesh address, and Plejd handles all outputs in that Room internally, the same way it does when you dim the Room from the Plejd app itself.
Tested on Homey Pro (Early 2019), firmware 13.5.1, with five LED-75 in one Room. On/off and dimming work, all outputs update at the same time, and the status in Homey follows without delay.
PR: Add Plejd room driver by jjrckd · Pull Request #100 · emilohman/homey-plejd · GitHub
Feedback and testing from others would be very welcome.
Big thank you for contributing! Room support has been released today in version 3.6.0.
Nice! Thank you for the excellent app and making it even remotely possible for me to contribute:)
