[APP][Pro] Piggy Bank
Thanks for the kind words @Lillevik.
Devices that get the warning you specified may work, and if they do then it’s nothing to worry about. It’s just a warning I added to make sure that everyone understand that there is a legit reason for any problem that may occur.
In order to remove the warning you need to
  1. Go to the app settings and
  2. Click the “Help” menu
  3. Select the menu choice “The app cannot find my device”
  4. Click “Report a problem”
  5. Click “Select report” and select “Experimental unit is working” (or other report type if applicable)
  6. Click “Select unit” and select the Philips Hue device / other unsupported devices
  7. Click “Generate report”
  8. Click “Send”
    Once I get the device report I will add the device type to the list of supported devices and, if applicable, fix any problems controlling the devices.
Though, using piggy to control led-lights might not be very desirable as blinking lights are both annoying and have little effect on the power used, so in a general context it’s not something I would recommend.
