I’m developing a Homey app for Philips HomeID appliances. The app is still under active development, and I’d like to use this topic to share progress, answer questions and collect feedback from other device owners.
The app currently includes support for espresso machines, air fryers, air purifiers and multicookers. It provides device information and controls where supported, Homey Flow cards, and an espresso dashboard widget.
Testing status: So far, I have only been able to test the app with a Philips 8000 Series espresso machine. The other appliance types—and other models within these categories—have not been tested on real devices yet. Please don’t assume that every listed model or feature will work correctly at this stage. Available functions may also differ by model and firmware.
If you own a compatible HomeID appliance and would like to help, I’d be grateful for your feedback. Please include your exact model number, firmware version, and a description of what works or fails. Screenshots or a Homey diagnostic report can be especially helpful when investigating a problem. Please do not share passwords, verification codes or other account credentials.
With help from users who can test these devices, I’ll do my best to improve compatibility and provide the strongest support possible. I’ll update this first post as testing progresses and more models are confirmed.
Before pairing, please set up your appliance in the official Philips HomeID app. This is an independent community project and is not affiliated with Philips or Versuni.
Thanks for helping make the app better!
PayPal Support: If you like my work and want to buy me a coffee: PayPal.Me
Thanks, Doekse! I’d really appreciate your help testing the HD928X Airfryer. So far, I’ve only been able to test the 8000 Series espresso machine on real hardware, so your feedback would be especially valuable.
I’d also love to hear your UI/UX ideas. Feel free to share them here or send me a message.
I’m open to making the source code public, but I’d like to review and tidy up the repository before committing to that. I’ll post an update once I’ve made a decision.
The PIN verification screen could use the system PIN code template.
The firmware version is currently added as a sensor capability. I think it would make more sense to show this as a static value in the device settings instead.
I’m not entirely sure what the Fahrenheit unit sensor is supposed to represent. If it indicates whether Fahrenheit is being used as the temperature unit, I’m not sure this needs to be exposed as a sensor.
I can also adjust the model and connection values in the device settings, and they’re both shown as text fields. What does changing these values actually do? If they’re just informational, I think they should probably be read-only.
I would suggest moving Preheat to a button, possibly with a state, instead of exposing it as an on/off capability.
Happy to suggest some changes via a PR to the repo!
I updated the development version to use Homey’s own PIN screen, moved the firmware information to read-only device settings, made the model and connection fields read-only, and removed the Fahrenheit display from the sensor view.
The preheat function now appears as a button, but the on/off state is preserved. I’d love to hear your thoughts on the UI/UX, and I’d be happy to review a PR.
The 20-second rapid status update for the Airfryer in pause and setting modes was maintained.
When the cloud connection was lost, the query interval was increased to 5 minutes; when the connection was restored, the rapid update was re-enabled.
Hi, thanks for developing this app! Having native HomeID / Air+ support on Homey without relying on static local IPs and legacy CoAP registers will be huge.
I tried pairing my two newer-generation Philips Air+ purifiers on my Homey Pro (Early 2023) using the current test version of Philips HomeID, and neither device is discovered during pairing (most likely their model IDs aren’t mapped/whitelisted in the purifier discovery list yet). Both are actively connected and working in the official Philips Air+ (HomeID) mobile app on the latest firmware.
Here are the exact details for both models so you can add them:
1. Philips PureProtect 3200 Series
Exact Model:AC3360/11
Firmware: Latest official Air+ / HomeID firmware 0.2.1 (auto-updated)
Supported features in official Air+ app: Power On/Off, Modes (Auto, Sleep, Medium, Turbo, Fur Capture Boost), Display/Light mode (Off, Humidity / AQI ring), Light brightness (Off / Bright), Child lock, Sound/Beep, Timer, and sensors (PM2.5, IAI allergen index 1–12, TVOC, Temperature, Humidity, Pre-filter clean 360h countdown).
2. Philips 4200 Series
Exact Model:AC4220/12
Supported features in official Air+ app: Power On/Off, Modes (Auto, Sleep, Medium, Turbo), Display metric (PM2.5, IAI, GAS, Humidity), Light mode (Off, Humidity, Ambient), Child lock, Sound/Beep, Timer, and sensors (PM2.5, IAI 1–12, TVOC, Temperature, Humidity, Pre-filter clean 720h countdown).
(Side note from local testing on these two models: both use the newer Philips register generation where modes are reported via fan speed codes like "AUTO", "17" for Sleep, "t" for Turbo, while purifier_mode remains null, so the old local CoAP Homey app can read their sensors and toggle light_mode, but cannot control power or fan speed.)
If your app logs raw unmapped payloads from the HomeID cloud during discovery, let me know and I will run the pairing wizard again and send you a Homey Diagnostics Report ID right after—happy to test new builds as soon as you push them!
Hello, thank you for the information you provided. I’ve addressed the issue I identified in the app and added support for the Air+ AC3360/11 and AC4220/12. Could you please install the test version and let me know the results? If you encounter any issues, I’d really appreciate it if you could send me the diagnostic log.
(Just in case it helps: Philips Air+ cloud sometimes reports the CTN/model string without the regional /11 and /12 suffix—just AC3360 and AC4220—or under a separate Air+ IoT device category.)
Let me know as soon as there’s a new build to test!
