For this field an iphone numpad keyboard appears and for region Norway it shows only comma.
Hi @MichalLam, thanks for checking! I’ve fixed the iPhone decimal input issue for the next release. You’ll be able to type 0,25 in Safety margin and any other PELS setting that takes decimals.
PELS 3.51: Metering sockets, shared Zaptec installations and smarter mode changes
Use a metering socket as a device’s power meter
This has been a frequently requested item. I had several attempts at this one, but most solutions either felt quite awkward or felt like a reimplementation of Virtual Devices within the Settings UI. I am fairly happy with how this one turned out.
You can now pick a metering socket for a device directly: open the device in PELS, expand External sensors and choose the socket under Power source. PELS reads the socket’s power for the device, keeps controlling the device itself, and never switches the socket. How it works
Thanks to @Felix_oslo and others for asking for this.
Secondary on/off switches
Related to this, devices with more than one switch, such as a spa with a main switch and a separate heating switch, can now be limited through the switch you choose under Setup. PELS leaves the other switches alone. Choose which switch PELS uses
Devices that need a socket or a switch before PELS can use them are listed under Needs setup in Devices and in first-run setup. Set up walks you through the socket and the switch, and shows the latest power reading before you add the device. Set up a device that needs a meter or switch
Turn off unmetered devices as a last resort
An on/off device without any metering can be turned off as a last resort. It is always a last resort, because without metering PELS cannot know whether turning the device off helps, nor whether it is safe to turn it back on. To use it, enter the most the device can draw, and PELS turns it off only when there is nothing else left to limit. Last-resort control
Zaptec chargers on a shared installation
Zaptec recommends putting chargers on one supply into one installation, which shares the available current between the cars. PELS now controls such an installation as one load when every charger in it is managed: it sets the installation’s current through one charger, steps it down before pausing anything, and pauses and resumes the chargers together. The chargers share one priority in Modes. If you set the current with a Flow, each charger keeps its own switching and your Flow. Several chargers on one installation
Have devices ready when the mode changes
A scheduled mode change can now have your heaters ready on time. Turn on Have devices ready by then on a mode schedule under Settings > Schedules, and heaters with a higher temperature in the new mode start early, so they reach it when the mode changes. This works much like Tibber’s night and day modes, where Tibber anticipates when to start heating to reach the target temperature. Moving from night to day mode this way has the bathroom and the water heater ready for your morning routine.
The Smart tasks engine is underneath, so it uses cheap hours and respects your limits the same way. Smart tasks shows the plan and when each heater starts.
Also new since 3.40
- Norway: Usage > Monthly capacity shows your estimated capacity tier for the month, and can suggest a Hard cap that keeps you in it.
- Missing hours in the history can be recovered from the whole-home meter’s Insights, under Settings > Advanced > Data management.
- Homey’s timeline tells you when power readings stop and PELS limits your devices to stay safe, and again when they return.
PELS documentation · PELS in the browser · PELS in the Homey App Store
Hello again,
The app has been working great after following your advise.
I was wondering if it would make sense to add an option for two more thresholds: very expensive and very cheap? So that I/we can control devices futher when prices are more extreme. Maybe trigger prompts like “cheap/expensive to turn on [unmanaged device] now/next hour”.
Also, is there an option to force an amount of cheap/expensive hours per day, say “minimum 5 cheap hours” so that the 5 cheapest hours gets extra usage, like for heating in colder months.
Thanks for the great support!
Glad the price adjustments are working for you.
Both ideas have come up before, especially since Piggy Bank had those options. I’m still unsure how much they’d save in practice. A minimum of five cheap hours, for example, could mean adjusting the heating on days when prices are close together and giving up some comfort for very little saving.
If you know when you’ll need the heat, I’d expect a Smart Task to be more useful. You can set a target temperature and a time, and PELS will pick the cheapest available hours to get there. On days you won’t use the room, you can skip the task and leave it at its lower setpoint.
If you want to try a fixed number of hours, PELS already has Flow cards that let you control a device during the X cheapest hours before a given time.
I’m open to adding both options. I just want to make sure they have the desired effect.
Hi Ole, I also sent this through the app’s “Report a problem” (reference c18b99f6-81d7-4202-a6ad-084f89a2a105).
Thanks for PELS - smart tasks with 15-minute prices work nicely with our OCPP Bridge charger.
Two questions:
- Is there, or could there be, a rule “never charge the car from the home battery”? With a hybrid inverter and a house battery, the battery covers the car whenever the grid is not used, so a cheap-hours plan can still empty the house battery into the car. We would like the car to charge only while the grid (or solar surplus) supplies it - for example: pause the charger while the home battery is discharging into it, and resume in the next planned quarter.
- How does PELS work out the energy for a “charge to 80 % by 06:30” task? For a car at 47 % (Toyota bZ4X, about 71 kWh battery, about 26 kWh from the grid to reach 80 %) PELS planned five quarters (about 12 kWh at 9.7 kW), while about fourteen are needed. No car app reports to PELS here - we send the battery level with the “Report battery level” card. Is there a place to enter the battery size?
Thanks!
Hi @Rrrr,
Thanks for sending the report.
On the first question, there’s no rule in PELS today to prevent the car from using the home battery during a scheduled charge. As far as I tell, it may be possible to implement for your inverter, but it takes some research before I can tell for sure. I’ll look into it. PELS doesn’t discriminate EV chargers from any other energy consumers, but it could be e.g a toggle to not let a smart task run when the battery is discharging or something like this. I need to have a think about how this would best fit the PELS model, but I am confident I can do something that satisfy your requirements. I may send you a DM here on the forum to ask some follow up questions around this, if that’s okay.
On your second question, you’re right that five quarters was too short. PELS learns how much energy the charger uses for each percentage point the car gains. In your case it had very little data and estimated only 10.7 kWh to go from 47% to 80%. There’s no battery-size setting at the moment, but that can be considered. These estimates should get better over time.
It’s worth mentioning that in addition to using battery SoC for smart tasks, you can also use the Add energy task Flow card to ask for 26 kWh by 06:30. That measures the energy delivered through the charger directly. Did the car reach 80% that morning? The report was captured before the task finished.
