@MichalLam Thanks a lot for the report, it pointed straight at a bug! PELS dropped the charger all the way to 6 A because another device was waiting to turn back on, ignoring that your charging task outranks it. 12 A would have been enough. That is fixed in 3.30.4, and 3.30.5 also lets the charger climb back up faster after a limit. Thanks again!
@MichalLam Thanks for the report.
The pause came from your smart task. The car was slightly ahead of schedule, and the night grid tariff from 22:00 is cheaper, so the task moved the last few minutes of the 21:00 hour there. Charging is still booked through the night.
The card should have said “Waiting for cheaper hours” the whole time, but it switched to just “Off” after half a minute. Will fix the text in the next version.
Still a lot of feature requests coming in … so I give you PELS 3.32: Main fuse protection and several home batteries
Calling this protection isn’t quite right, since PELS works from meter readings and can’t stop a fuse from tripping the way the fuse itself does. But it’s what people call it when they ask for it, so the name is about the feature being recognisable. What it does is ease the problems of a main fuse that is undersized for what the whole home can draw.
Enter your connection, such as 3x25 A, under Main fuse on Limits & safety. When your meter reports phases, PELS keeps L1, L2 and L3 each under the fuse by limiting the devices on the full phase, in your priority order. That includes chargers, heaters and charging or discharging a home battery. Overview shows the load on each phase, and Usage lists recent phase peaks. PELS reads three-phase chargers directly and learns which phase other devices are on, or you can set it on the device page.
Several home batteries
This is for homes where several batteries have been running on their own. Two batteries planned separately get in each other’s way: one discharges while the other charges, and both chase the same cheap hour. You can now turn on Plan charging with PELS on each battery, and PELS plans them together in your priority order. The battery higher in the list goes first, and the next one covers what is left. No battery charges from another. If they sell stored energy, they share the lowest export limit set on any of them.
As always, send a diagnostics report if something seems off, or a feature request if there’s something you’d like added.
Store link remains: PELS Energy Manager | Homey
Hi @Felix_oslo,
Sorry for going quiet on this one. I haven’t forgotten your Sensibo question, but I haven’t found a good way to build it into PELS and there have been so many other user requests coming in lately so this got sort of … starved.
What you could do is follow the virtual thermostat guide, with a few changes since nothing measures the heat pump:
- Add On/off to the virtual thermostat, and wire it to the Sensibo’s Turn on and Turn off.
- Since the virtual device has the proper onoff capability, you should be able to set Energy used when on in its Homey Energy settings to what the heat pump normally draws. Then you don’t need the Power capability or the power Flow from the guide.
The Sensibo also reports the room temperature, so you can copy that into the virtual thermostat and pass its target on to the Sensibo, as in the guide. Then PELS can handle the temperature per mode for it too.
Would this work for you?
Hi, can an override function be added to the smart task function?
I.e. I get guest for a weekend and want them to be able to adjust the heater temperature for their room manually if they so choose. Then I can set that device as override for a selected time (i.e. 48 hours).
In this time the setpoint can be adjusted on the device itself, and also from Homey app. When the override time is over it reverts back to its normal PELS control.
Hi @luguber
Thanks for the clear description. A guest stay is a common enough use case to support well, I think.
What PELS already can do is this: Temporarily change one heater's temperature with Homey Flows | PELS
For your case:
- When the guests arrive: a Flow with Set what happens when the temperature of [heater] changes outside PELS: Keep the new temperature. From then on, PELS doesn’t touch that heater’s temperature, so the guests can set it on the thermostat or in the Homey app (I guess guests would not be allowed into the app directly though). This only affects temperature control, so PELS can still turn the heater off if the house goes over the capacity limit.
- When the stay ends: a second Flow that starts at the date and time you want, with the same card set to Return to mode target. PELS then takes the heater back and sets it to the target for the current mode.
You can put a 48-hour delay in the first Flow instead, but a Homey restart cancels a long delay. With a second Flow at a set time, the handover ends even if Homey restarts in between.
The setting is also in the device’s Setup in PELS, as “When the temperature changes outside PELS”. It isn’t under smart tasks, which is probably why it was hard to find.
Thanks again for writing it up, and let me know how it works for the guests.
Hi, thanks. Yes, set from the Homey app was intended for me and not the guests, for my other use case.
I can do it with flows as you suggest. It would just be more convenient to set and forget this from i.e. the smart task widget. Then I can do it quickly from the phone app, and won’t need to make or edit any flows.
The other use case is for the children rooms. I don’t want the kids to be able to change the temp on the device itself, but some times I’d like to easily increase (or decrease) temperature for one night.
But no need to spend time on this if you don’t think it will benefit others as well.
I can also creat a virtual device and use it to toggle “guest mode” on my devices fom the phone app.
Thanks for clarifying. This may make more sense now.
I just want to make sure I understand your use case correctly. Is it either
- A one-off change to tonight’s Smart task from the smart task widget?
- Or a change to the room’s temperature itself for the current mode directly from a widget?
Both are probably doable.
Hi, its a change to room temperature for the cuurent mode directly from the widget.
It should then also ignore price and mode change during the override window.
So that when you i.e increase by one degree, it start immediately, and is ignorent of any other changes during the override window you set.
Thanks for clearing that up. I see something like this:
- You set a temperature override on a device, e.g. +1° on the current mode, for a time window you choose.
- It takes effect right away. During the window it ignores price adjustments and mode changes. Power limits still apply.
- The device page/overview shows “Override · until 21:30”, and you can end it early from there. (Similar to how smart task already does it)
- When the window ends, PELS goes back to the normal mode temperature.
- Later, overrides could also be scheduled to repeat, e.g. weekdays 06–07, only in the modes you choose. This isn’t necessary for your use cases right now, I think, but others have asked for something similar instead of creating modes that are 95% similar.
I’d like to start with this feature only being available through the settings UI/webapp in the short term. Adding widgets absolutely makes sense, but they require more thorough reviews from Athom that has started to take days to complete and that holds up other releases, so I’d like to batch those.
Does this sound good?
Yes, this sounds perfect!
