[APP][Pro] Ollama - Use Local LLMs in your Flows
Version 1.1.16
  • Update dependencies
Version 1.2.0
  • NEW: Chat Widget! Chat with any Ollama model, straight from your Dashboards!
Scroll buttons were added because regular scrolling doesn’t work correctly on Dashboards for some reason.
Now available in test:
Version 1.2.1
  • Added support for italic text in the chat widget
Version 1.2.2
  • Added support for nested lists in the Markdown parser
  • Added support for strikethrough text in the Markdown parser
  • Added support for headers in the Markdown parser
  • Added support for code blocks in the Markdown parser
  • Improved italic text detection in the Markdown parser
Version 1.2.3
Thanks for the app — works great with a local Ollama box.
One thing that would help a lot: recent models (Gemma 4, Qwen3-VL, Qwen3.5) have reasoning enabled by default. For automation use cases like “describe who’s at my front door” the reasoning tokens are pure overhead — the flow just needs one short sentence back.
Quick benchmark on my machine, same model, same prompt:
eval count total
default 85 tokens 5.6s
think: false 10 tokens 0.86s
Same answer, 6x faster. With an image attached the difference is even bigger.
Would it be possible to add "think": false as a toggle on the flow card?
I think I’ll disable it on the Flowcards by default, since that would be unnecessary, and make it a toggle on the chat widget. I’ll publish the update soon!
Version 1.2.4
  • Added reasoning toggle to the chat widget
  • Disabled reasoning on Flow cards
Hi @silsil ,
Can you please try the test version?
Works like a charm! My flow now runs in 3s instead of 7s
One more thing: my Ollama instance sits behind a reverse proxy, so it’s reachable over HTTPS instead of plain HTTP on the internet. Would it be possible to add a “Use HTTPS” (or “Use TLS”) checkbox in the settings, next to the IP-adres field?
Happy to test a beta again if that helps.
Version 1.2.5
  • Added protocol selection
Just added it, can you please try the new version? You’ll find the protocol selector in the settings page
Version 1.2.7
  • Added privacy policy
Version 1.2.8
  • Removed privacy policy, not applicable to this app
Version 1.2.9
  • Added Push SDK
