[APP][Pro] Ollama - Use Local LLMs in your Flows
Homey app for Ollama. It currently supports the ability to generate a response using an installed model and it supports setting a system prompt. It also supports using images with models like qwen2.5vl or gemma3.
First set the IP address and port (default is 11434) of your Ollama instance and your system prompt in the Settings page of the app, and then you can generate messages using Ollama models from your Flows.
The system prompt that the app uses can also be set via a Flow
Make sure the “Expose Ollama to the network“ is turned on in your Ollama instance
Version 1.0.1
  • Added support for setting the system prompt from a Flow
Version 1.0.2
  • Adds support for images
Version 1.0.3
  • Fixes in error handling
  • UX improvements
Version 1.0.5
  • Fixes in README
  • Fixes in app settings page
Submitted to app store
Version 1.0.6
  • Decreased the length of the Flow card names
Version 1.0.7
  • Updated README
I submitted the app for certification. They say that it can take up to 2 weeks
Version 1.0.8
  • Improved settings page
Version 1.0.9
  • Improved autocomplete listeners
Version 1.1.0
  • Added Dutch language
  • Improved errors in the settings page
  • Added a check for the port number range
Version 1.1.1
  • Fixed a typo in the Dutch README
Version 1.1.2
  • Fix error handling
  • Update README
Version 1.1.3
  • Update dependencies
Version 1.1.4
  • Reduce settings page file size
Hi @smarthomesven
This might more concern Ollama itself than your app but maybe you can still help me:
Is it possible to use Athom´s official Homey MCP Server with Ollama?
If so, how is it done?
AFAIK it’s not possible to use MCP servers with Ollama, maybe with an external/thirdparty software but not officially
MCP Servers should be supported in Ollama. Isn´t it what the call tools?
I have seen that you can define tools when making a generation request to the API, but it’'s as far as I know not possible to connect to a MCP server from Ollama.
I’'ve never really used the tools so I don’'t know how it would work from the API
