[APP][Pro] Niu
@martijnpoppen the app is not updating the data anymore. I wanted to use my scooter this morning and the app says it was 87% charged, but when I turned the switch it was 25%.
Hey @Rens_Hoekema ,
Oh that shouldnt be the case :stuck_out_tongue:
Can you send a diagnostic report?
Is your scooter still available on my account?
@martijnpoppen yes it is: 560f3337-4e69-4a5b-95b6-833b83d3b75a
@Rens_Hoekema
Can you try to login again?
I think the token is expired.
But if you login again it will be refreshed.
When you did that can you send a new report?
I’ll make a fix for the the expiration
Looks like i ts working again, just after I created the diag 1a314f9c-053f-4a58-9a6f-3130e59653a0
Yes works!
Ok then I know enough to fix it :slight_smile:
thx Martijn!
New app update (live: 1.0.14 ):
  • FIX: refresh token when it’s invalid
New app update (live: 1.0.15 ):
  • FIX: refreshToken on error
@Rens_Hoekema
I have the homey pro 2023. Since the current version 10.0.1 I can no longer connect to my NIU scooter N-GTS. It was still working until yesterday.
The error message “Response code 404 (not Found)”
Hey @Christian_Baumann
257dce6b-589b-48f4-b27c-1bd0eb71ef8f
@Christian_Baumann I see a 404 on a API call. As far as I see this is an issue with the API itself. can you check if the app on your phone is working properly?
My normal NIU App is still working normal.
@Christian_Baumann would you mind sharing your NIU temporarily with me so I can debug the app?
I don’t have the test vehicle anymore in my account and I don’t own a NIU myself
What do you need? You have a private Message!
Thanks! :smiley:
New app update (test: 1.1.0 ):
  • NEW: update API to Axios instead of GOT
Really excited to see your App!
Any possibility of the MQi GT EVO being added?
Hello
Replaced Homey 2018 to 2019.
Not sure when lost connection.
Niu app works. Has subscription.
Close it. Update reinstalled app. Check login status. Logged in. Get Token
Deleted the mot working item and search for mew to re-add. Nothing. App dont find M+ Sport
What can be wrong?
