andi i get this on the data site of audi:
what do I do?
Hi Patrick
This (EU Data Act) is not related to the myAudi App - If related to the “VW Group Vehicles” app, please use:
BTW: I sent you a PM
aah, yes, was installing that one, to have next to this one. but if solved through your new implementation, then won’t need it anymore ![]()
Ahh, sorry guys… you are right !
I see all the information and it gets updated but I can’t turn on the climatisation.
I restored my homey, it had automatically updated to the newest test version, and I did not even have to do a repair!
Today I was able to start climatisation again with your app…
are others also experience massive and longer disconnects to the cloud of the MyAudi app (so not the homey app, but the audi server connection. consequence is that many of my flows get impacted due to that. Just checking if it is mainly on my side or if it is general issue
Hi @Andi
new question. climitization button works, but the other two get a failure (start heating and set the temp):
any idea?
Hi Patrick - Could you please test it with the next TEST version: myAudi | Homey
thans @Andi installed the test version, didnt take yet. anything I need to do ?
Your flow sends window heating, the temperature and climatisation to the car at the same moment. The car usually processes only one remote command at a time, so the others are refused. Please run them one after another with a delay of about 30 seconds: first set the temperature, then start climatisation. Window heating usually runs together with climatisation if it’s enabled in the climate settings, so you may not need that card at all.
What’s the error message on the flow card?
Thanks for the screenshot, that confirms it: your Q8 doesn’t accept changing the temperature on its own. Audi refuses that request (HTTP 502), even in the cleaned-up form. Starting climatisation works, though.
I’ve just released version 1.1.4 as a test version with two changes for you:
The card “Start pre-climatisation at temperature” now sends the temperature together with the start command in a single request, which your car accepts. Please replace “Set the temperature …” + “Start climatisation” with this one card.
Commands to the car are now sent one after another automatically, so you no longer need the 30-second delays in your flow.
The separate “Set the temperature” card will keep failing on your car, because that’s Audi’s side. Its error message now points to the right card.
Could you let me know whether climatisation at your chosen temperature and the window heating work with 1.1.4?
chosen temp works, the window heating does not, but i think it is not present. removed it
thanks!!
Beste Andi, vraag over opzetten van een flow met de myAudi app. Ik probeer een advanced flow op te zetten die mijn Audi EV laat laden gedurende de 6 goedkoopste uren op een dag. Qua logica lukt dat. Zodra de laadkabel is aangesloten doe ik een check op de dynamische tarieven. Als dat niet in de goedkoopste uren valt roep ik de kaart aan die het laden stopt, met daarna een wacht timer van 60 minuten. Echter, het laden wil niet stoppen. Ik zie in de app van Audi wel dat het wordt geprobeerd, maar dat lukt uiteindelijk niet. Weet je hier wellicht een oplissing voor?
Hi Andi , I have a Audi Etron , I am missing the Then card : Loading with example 6 Amp - 16 amp …
Hi Danny,
There is a card “Set max charging current”, but it only shows up when your car reports that setting to the app. Audi’s API also doesn’t allow a free choice of amps: depending on the model it’s either “maximum”/”reduced”, or a few fixed steps (for example 5, 10, 13 or 32 A). Values in between, like 6–16 A in 1 A steps, can’t be set through Audi’s API.
To check what your e-tron supports, could you open the app settings (Apps → myAudi → Configure app), run the API Helper and post the part under “chargingSettings”? Please leave out your VIN. Then I’ll see whether I can add the card for your car.
in the Audi App, There is no option to set
these parameters
