I have run a couple more tests and fixed it in this version Mercedes-Benz | Homey
Hey. It work for me, but it seem like the continues refresh are failing. @Stian_Sorbotten could you please confirm my findings as well?
Is there a way to close the panoramic roof blind too when closing the panoramic roof?
Hey @Wouter
Maybe let me investigate it. Do you have the options to create a GitHub issue? Issues ¡ andersdissing/Mercedes-Benz-homey-app ¡ GitHub
Doors, ignition avd perhaps something more still days 6 days.
Engine running days 2 days, but i used the car today. I am not quite sure what the time here mean. Last time the device changed state?
I found a bug where the underlying (WebSocket) connection is not handled properly. This is fixed in 1.1.37: Mercedes-Benz | Homey
I have tested âsyncâ or device refresh this morning, and the connection is now reliable.
Thank you.
Everything work perfect again ![]()
Super. I will move that version to production.
@Wouter, did you manage to create a GitHub issue? Otherwise, please email me at ameq@ameq.dk. We need to work out what you are after, and this forum is not my preferred way of aligning on requirements.
Mercedes-Benz app v1.1.41 â test version out, feedback welcome
Install it here: Mercedes-Benz | Homey
Whatâs fixed
- Homey capabilities such as battery level could go several days without updating. They now follow what the car is actually doing.
- A flow could report that a command worked when the car never carried it out.
Thereâs a new flow card, **Vehicle command failed**, that tells you when that happens and what went wrong.
Please help me test
- Keep an eye on the values Homey shows for your car over a few days - battery level, range, doors, windows, odometer, tyre pressure. Do any of them stop updating or drift away from what the car really shows? If so, which ones, and roughly how long were they stuck?
- Does the charging state match your car â plugged in, unplugged, and while actually charging?
- Add the Vehicle command failed card to a flow and let it run for a few days. Does it ever appear? If it does, what did it say?
- Anything else in the dashboard widget that doesnât match your car.
Thanks! If something looks wrong, a diagnostic report helps me a lot more than a description on its own.
I got an error report this morning. That includes a bug I have not tested for, in essence. The user ended up in a â429 loopâ that froze everything. I have published a new test version (1.1.43) that fixes this by backing off until the Mercedes-Benz backend APIs are available. So when installing the new version, it will take an hour or two for the app to start working normally again.
Get the newest test version here: Mercedes-Benz | Homey
Version 1.1.43 is now live
This version has fixed the non-updated capabilities.
Sorry, I havenât had time to create a github issue.
Iâm getting 429 issues though. I drove the car this afternoon and then again half an hour ago. The app still shows the data from 5 hours ago and as soon as I try to do something with a flow, for example close the roof, I get a 429 error. Iâve been on 1.1.43 since yesterday evening. Iâm using a dedicated Homey user.
Hey @Wouter. Please deactivate the app for a couple of hours then enable the app again.
Version 1.1.44 is live, with additional guardrails to prevent a 429 loop. However, this means that for now, the speed of updating the various capabilities has been reduced.
Note. I got a timeout message after installing the new version, even though I had run the same version in testing over the weekend. My solution was to restart my Homey. However, I think that the disable/enable app should be enough if you experience a 429 error.
Hi
Thanks for the app, it has worked well with my EQC.
Could you add electric consumption since start (kWh/100 km)? The Mercedes API has it as electricconsumptionstart, and mbapi2020 exposes it as âElectric consumption startâ. It looks like the proto already has the consumption units, so perhaps the value is already available.
My plan is to use it to track usable battery capacity over time. After each trip, consumption Ă distance_start gives the energy used. I can then sum the trips between charges and compare that with the drop in battery percentage. For example, 24 kWh used over a 30% drop would indicate roughly 80 kWh usable capacity.
Over many charge cycles, this should give a useful picture of how the battery capacity changes over time. Periods where the car uses energy while parked, such as preconditioning without the cable, are left out.
Hey @TroBil
Thank you for the nicely written post. For a easier workflow when Iâm developing can we move the issue over to GitHub? Issues ¡ andersdissing/Mercedes-Benz-homey-app ¡ GitHub
