Native Homey support to connect locally to Lutron RA3 devices.
In test currently - Lutron RA3 | Homey
@alistair the app did not pick up the accurate state of my devices after first connecting to the Lutron bridge. For example, my guest bedroom shows all the devices as on in the device tile. All those devices are actually off. Image attached.
Once I toggle it it in either Homey or the Lutron App, the device tile shows the right state.
FEATURE REQUEST - Add shades as supported devices.
@fxl90 huh - I’ve been using this a fair bit in my own home and haven’t run into this. I wonder if it’s a “first run” issue. Next time you restart Homey, can you see if the status is correctly reflected?
Either way - I’ll see if I can track down the bug, but more data helps ![]()
Sent diagnostics report b2a73a15-a075-4963-8eb1-1ec293ae85b1
@fxl90 I tracked down the bug and fixed it I believe! Updated version in test.
After 5 attempts to get this past the Homey review people, and they keep rejecting it for problems with the readme - I’m not going to release this further.
I’ll leave the version in test as long as it’s allowed.
I think if you remove the “Flow cards” part and the “What you can control” part, it will get approved. The Flow cards and devices are already visible in the App Store page, so that’s likely why Athom is rejecting it
Test versions are always available, they never get blocked or rejected
