Connect your Lepro lights to Homey
If any device that you use is missing, please let me know.
Hi Sven!
I’m considering buying the Lepro N1 AI Smart Rainbow Neon LED Strip (10m) for my son’s music studio.
Will this model work with your Homey Pro app, or could you add support for it?
I would like to control the power, brightness and RGB colors directly from Homey.
Thanks for your great work!
Hi @Tore_Grotte ,
Yes, I can definitely add support for it. Do you already have the device? This is needed before I can add support for it
Hi Sven!
Thank you for offering to add support for the Lepro N1 if I purchased the device. I really appreciate your willingness to help!
I just wanted to give you a quick update. After looking into different LED strips, I ended up ordering a different product instead.
I purchased a 14-meter Tuya WiFi RGB Neon LED Strip for my son’s music studio.
Since this one uses Tuya WiFi rather than Lepro, I assume it would need a different integration in Homey.
I didn’t want you to spend time developing support for the Lepro N1 when I won’t be purchasing that model after all.
Thank you again for your kindness and willingness to help. I really appreciate developers like you who make Homey even better!
Best regards,
Tore
Hi Sven. I’d like to kindly request support for the BG1 light device. Thanks in advance
@Lariosax Can you try the new test version?
Hi Sven, unfortunately I am having trouble logging into the app on Homey. When I try to sign in, the application fails to authenticate my credentials.
The application uses the EU API when I try to log in,:
Could you please add support for api-na-iot.lepro.com ? Thank you for your support!
