[APP][Pro] Flow Checker
Sorry (posted in wrong group)
Last weeks I get a serie of ‘event broken’ errors in my timeline. Two to three times a week 10-12 at the same time for different flows. Example:
FlowChecker - Event: BROKEN - Flow: Gas Verbruik | Folder: Energie
I can’t find anything wrong in the flows and everything is working as expected. How or where can I check why these events are reported? Is it possible a Power by the Hour trigger (example ‘Price changed’) is causing this (it’s the only similarity between the flows I can find)?
@Marcel_R make sure to disable ‘check flows on startup’ in the app settings. That will likely fix your issue
@martijnpoppen FYI: This are the (yet unchanged) settings:
So, I guess it was already disabled. It’s not a big thing and I can disable the notifications if I don’t want to receive anymore.
I recently migrated from Homey Pro 2018 to 2026 but now I found that I cannot navigate to any broken flows from within the “Broken enabled flow” menu in Flow Checker.
At first, I got a “Homey not found” when I clicked on a link to a broken flow, I then tried removing and re-installing the app but now it says “Unknown route No match for /homeys//flows/20512909-6716-4468-b3c0-2bab06e205e6”.
Any idea on how to solve this?
You should add your Homey Cloud ID between the /homeys/ and /flows/…
You can find this Cloud ID in More->Settings->General in the mobile app under “Homey ID”
The messages “Unknown route No match for /homeys//flows/20512909-6716-4468-b3c0-2bab06e205e6” is because I click on the link to the flow from within the “Broken flow” menu.
Odd, here it does contain the Homey ID, but it’s a ‘foreign’ one. Not belonging to one of my Homeys
Please that is completely unrelated to this app, Sven. The user shouldn’t have to add anything when all’s working as should.
Do the other links (of the non-broken flows) work?
Did you have Flow Checker perform a re-scan to update the prior info (based on your 2018 Homey)?
@AVP can you restart the app and send a diagnostic report? Then I’ll check if the Homey ID is set
Thanks. Here it is.
7effe442-e2ff-4d67-8dcf-e88171b588b9
I did try to run a re-scan after I re-installed the app on my 2026 but that did not help.
However, I just went to my PC (after I restarted the app and sent the diagnostic report) to try your suggestion if the link were working from other tabs in the Flow Checker menu and this gives different results.
The links in “Logic in flows” are working fine but from the links in “Flows with variables” it goes to the homey web app start page.
Odd thing is after testing the above all links to flows work again in the “Flow” tab, maybe it’s a coincidence or the “HomeyID” was initialized after doing the above tests?!
@martijnpoppen please note this.
@AVP i can reproduce the flows with variables issue.
Can you send a new report? In your previous one the homeyID was empty, but as you said it works now, so i expect it’s filled, but good to double check
Sure.
Before app restart.
cfd4fb8f-a1b4-4d8b-b842-e804ab8f9b05
After app restart.
4e437bb1-714c-4ea9-be57-5f1a57a6b6ec
@AVP yes HomeyId is set now. Probably triggered by the re-scan.
For the other issue with the urls I’ll make a fix
I get many messages in my timeline : “Event Broken - Flow: …” . I checked a few of the mentioned flows but can’t find what is wrong with the flows. Any suggestions how to proceed
@Frank_van_de_Schuur did you disable the "check flows on startup " in the app settings? If not please do so that probably fixes it
I noticed a possible issue with the Unused Logic Variables check in Flow Checker.
Logic variables that are not used in a regular or Advanced Flow, but are referenced by their variable ID inside a HomeyScript, are currently reported as unused.
This can result in false positives, because these variables are still actively being used by HomeyScript and should therefore not be considered unused.
@CyberSponk ah yes correct. Homey scripts are not checked.
I’ll check if that can be done!
