[APP][Pro] Flow Checker
Will check!
Hi Martijn,
Thank you.
Will the fix be on the official version?
@Domenico_Etere yes!
New app update (:green_square: LIVE: 1.37.0.):
Changelog:
NEW:
1. NEW: timeout on flowcard to prevent flowcard errors
FIXES:
1. FIX: performance issues with a lot of flows
2. FIX: performance issues when a lot of variables needs to be checked
3. FIX: conditions and action cards not properly working
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - Flow Checker - settings wheel right top - send diagnostic report (add your email to the description)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select Flow Checker - Click on send diagnostic report (add your email to the description)
You can install this version by clicking the link (version number) above and press install
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → Flow Checker | Homey
@Domenico_Etere see above :slight_smile:
Hi Martijn,
Just tried but I still see an error in “There are disabled flow” flowcard. The error is: Flow Card not registered (type: condition, id: condition_DISABLED)
the diagnostic report: d542ee83-d1d0-423a-a3f2-a240a8f32df7
Sorry, I see the error: Cannot read properties of undefined (reading ‘settings’)
the new diag rep: dcde5fc2-097b-4479-a945-48a9328a549b
let me know and thank you for the support
@Domenico_Etere thanks will check.
The registered error I can’t reproduce , the other one I’ll check
The registered error was when I installed the new version 1.37.0 by Homey APP Store.
The other (Cannot read properties of undefined (reading ‘settings’)) was after I’ve installed the APP by link you provided here
V 137 is working perfectly, no timeouts, no false alerts,
great work!!
Hi After the latest update flow checker marks all my flows with “Event: BROKEN”.
d9df3227-e680-45f0-a29a-6e1300d49344
@Philipp_sch will check!
Pls, Is it possible to have the previous old version in the mean time you fix the errors in the new one?
Thanks a lot for the help
@Domenico_Etere no not possible. Too much changes to go back to that
I had the same. Probably “Run flow check after start of app” has to do with it.
New app update (:green_square: LIVE: 1.37.1):
Changelog:
NEW:
1. None
FIXES:
1. FIX: condition cards
2. FIX: disable CHECK_ON_STARTUP for all
@Domenico_Etere @Philipp_sch see update above with fixes
Same error: Cannot read properties of undefined (reading ‘settings’) in flowcard “There are disabled flow”.
Diagnostic report: a2b8f5a5-cdad-497e-8db7-4b8cbc2a7360
pls let me know
@Domenico_Etere I don’t see this error in the logs (never did) also I can’t reproduce this
Can you share a screenshot where you see this?
Hi Martijn, here the error:
the new diagnostic: db859cd8-e23d-4d06-9ed2-4bef9e7e8861
