[APP][Pro] Flexit GO - Better indoor climate
I’ve tested the new Stop ventilation function, and it works perfectly. I was also able to start the ventilation again by setting the fan mode back to Normal.
Thanks for implementing this so quickly!
Thanks for testing. I’ll request certification and then it will go live as soon as Homey reviewes it.
Hi Ole Markus, and thanks for a great app.
Would you consider flow actions for turning free cooling on and off? Today it can only be changed in the device settings, and neither flows nor HomeyScript are allowed to change device settings. That means it can’t be automated.
My use case is seasonal. My Nordic S3 had an extract setpoint of 20 °C and an outdoor limit of 10 °C. Through September that kept the unit in free cooling almost around the clock, on high ventilation with bypassed heat recovery, and the house ended up at 20 °C. I’d like a flow that allows free cooling May–September and turns it off the rest of the year.
I’ve opened a small pull request for it: Add flow actions for turning free cooling on and off by torp93 · Pull Request #97 · olemarkus/com.barelysufficient.flexit · GitHub
It adds “Turn free cooling on” and “Turn free cooling off”. Both call the existing `Registry.setFreeCoolingEnabled`, so they use the same verified write and settings sync as the device setting, on both BACnet and cloud. Two new tests; `npm run validate` passes. Happy to adjust anything.
Thanks for this. I merged your PR and released this to testing. It should be released live early next week.
