It will not work
Why not?
If there was another way it would be listed in the thread
An Android emulator is quite easy to manage
@duckert , get an emulator for your OS and you’ll find all the info you need.
Don’t forget to set a static IP for your Robovac, as I did
Hi, im trying these both methods in the first post but the old version of the app doesnt see my RobovacG30 as online. readded it and all.
the firmware is:
wifi: 1.1.51
MCU: 1.3.19
new version of the app (2.6.0) shows the device as online but doenst show the deviceID and or localkey. (also nothing via the adb command)
i have found the DeviceID but missing the Localkey, any clues or hints for me?
Hey @matrover ,
I do have another APK which you can try: https://www.apkmirror.com/apk/anker/eufyhome/eufyhome-2-3-2-release/eufyhome-2-3-2-android-apk-download/download/
In the new app they indeed removed the Localkey/deviceId
With version 2.3.2 you should be able to do it with the ADB debugging
Thnx for your swift reply (as always :))
But didnt work, it still doenst find my vacuum (the ios app and newest android app do), it has an fixed ip. funny thing is that the settingspage of the robot states its connected to my wifi:
made a video:
Ah
And what if you remove the fixed IP. And try again?
Is your firmware up to date?
And again @martijnpoppen to the rescue!
Fixed it by sharing the robovac with another account, there it appeared online and got the required information! (I can reproduce this working myself)
App works great! Donated a few beers, thanks again!
hi i did all the steps from above but i can’t get my Eufy robot to work,
it states a warning: connection timed out.
could you help me try to fix this >?
kind regards roy
well @martijnpoppen as far as i know yeas i used the android emulator with the latest version of your eufy app copied the information, evertime it was the same [fixed] ip i used another email to share the device same ip, maybe a bit random but i coupled Alexa to the eufy home account could this be a problems ?
@Roy Hmm in that case it should work.
Can you provide me with a diagnostic report?
I’ll have a look what goes wrong from the Homey app.
You can do that via
More - apps - eufy home - settings wheel right top - send diagnostic report
Hi Martijn,
I have ordered the Eufy X80 hybrid, will arrive tomorrow, it is their this week released latest robot vacuum with mop capability. Would it be possible to support that robovac as well, if I can do anything for you let me know.
Ron
New app update (test: 1.2.0 ):
- NEW: Add Eufy Robovac X-Series
CC: @Ron_Meijsen added it to the test version of the app.
Will probably go live tomorrow or monday. But you can use the test version to check it out
Hi martijn
Ik gaf aan dat het de x80 hybrid was maar op de site zie ik x8 hybrid. Maak dat iets uit voor de app?
Als het goed is komt die vanavond binnen. Dus van het weekend testen
Ron
Ron
