Can you share what you did to get the ratgdo board to work in homey?. I have been messing with the thing for months, and still nothing, When I try to configure it in ESPHome Controller, it is asking for an encryption key. Asking chat gpt leads me to think I need a custom yaml file to flash to the board. What were you able to do? I reached out to ugrbnk and he suggested I reach out to you. tyia
There’s a ratgdo device in Esphome Controller Now. Did you upgrade the ratgdo to the latest firmware?
Hi @ugrbnk - first of all I wanted to say that this has been working fantastically with my Neewer lights! Thank you!
I am now attempting to add control of a USB hub using a remote control wired to the GPIO pins. I can add the first button, but I don’t get the choice of multiple buttons like I do on the lights after your fix. Is there a fix that needs replicating to that device type? Thanks!
Oh and I notice the device add jumps the first page where there are multiple devices - that’s a great usability improvement ![]()
Here is my current yaml
esphome:
friendly_name: Studio Control
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "**********"
ota:
- platform: esphome
password: "**********"
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Esp-Studio Fallback Hotspot"
captive_portal:
external_components:
- source: **********
refresh: 0s # Recommended to ensure your fixes are pulled immediately
components: [ neewerlight_ble, neewerlight ]
esp32_ble_tracker:
### Commented out after initial detection:
#neewerlight_ble:
#text_sensor:
# - platform: ble_scanner
# name: "BLE Devices Scanner"
### Added the following blocks with the detected
### mac addresses:
ble_client:
- mac_address: **********
light:
- platform: neewerlight
name: "NW660 RGB Light 1"
ble_client_id: nw660_ble_1
color_interlock: true
gamma_correct: 1.0
default_transition_length: 0s
name: "NW660 RGB Light 2"
ble_client_id: nw660_ble_2
gamma_correct: 1.0
# --- GPIO Outputs (PC817 LED side) ---
output:
- platform: gpio
pin:
number: GPIO16
mode: OUTPUT
- platform: gpio
pin:
number: GPIO17
mode: OUTPUT
- platform: gpio
pin:
number: GPIO18
mode: OUTPUT
- platform: gpio
pin:
number: GPIO19
mode: OUTPUT
# --- Momentary Button Actions ---
button:
- platform: template
on_press:
- output.turn_on: opto_pair_usb
- delay: 250ms
- output.turn_off: opto_pair_usb
on_press:
- output.turn_on: opto_next_usb
- delay: 250ms
- output.turn_off: opto_next_usb
on_press:
- output.turn_on: opto_usb_1
- delay: 250ms
- output.turn_off: opto_usb_1
on_press:
- output.turn_on: opto_usb_2
- delay: 250ms
- output.turn_off: opto_usb_2
Thanks for all your work!
The “EspHome Device” seems to connect fine, it shows a red triangle when I turn my ESP32 off, and triangle disappears when turned on.
But device does not show any sensor values, only “Signal Strength” which is “-” (and updated “56 years ago"
) despite being WiFi-connected). Do I need anything extra in my .yaml for the sensor?
sensor:
- platform: hx711
dout_pin: 14
clk_pin: 23
gain: 128
update_interval: 1s
unit_of_measurement: “kg”
Unfortunately for my issue, it still jumps past the stage to select a specific entity of type button. I note that entity key has now appeared as a config param when adding a button though - don’t think that was there before.
I’ll make a correction for that.
I’m correcting it.
I can confirm that the adding works when entity key is manually specified, so (as I’m sure you’ve already deduced) it looks like it’s just the discovery logic. Thanks!
@clindh @MarkT ESPHome Controller | Homey
@clindh Thank you for your donation.
Happy to confirm the discovery now works as expected - great stuff @ugrbnk! A complete non-rush but at some point it would be great to be able to add multiple devices at once, or for the app to remember the IP and encryption key, or similar so it is quicker to add multiple entities.
But fantastic that it now does discovery for buttons too
Thank you again!
The suggestion to add multiple devices and remind users of connection details makes a lot of sense from a user experience perspective. However, since Homey’s core pairing infrastructure is currently built around a single device addition onboarding procedure, allowing multiple selections in the interface would require an infrastructure update.
Yes, I tried to link my device to that option in Esphome Controller. That is where I was asked for IP address, encryption key and password. The encryption key is what I don’t have.
Yes, I updated my device to the latest firmware dated 2026.2.22
The last few commands in the log are:
11:43:19 [W] [ratgdo_secplus2:438]
Not connected to GDO, ignoring command: GET_OPENINGS
11:43:19 [D] [ratgdo_secplus2:215]
Query paired devices of type: ALL
11:43:19 [D] [ratgdo_secplus2:426]
Send command: GET_PAIRED_DEVICES, data: 000000
Not connected to GDO, ignoring command: GET_PAIRED_DEVICES
Query paired devices of type: REMOTE
Query paired devices of type: WALL_CONTROL
11:43:46 [I] [safe_mode:071]
Boot seems successful; resetting boot loop counter
There’s no longer an encryption key or password. I didn’t enter any–just the ip address.
v1.0.146 — Stability & Bug Fixes
• Fixed critical ReferenceError in garage door driver that blocked all state updates
• Fixed memory leak in 7 drivers caused by event listeners stacking on reconnection
• Fixed lock driver: lock/unlock commands were silently failing (missing lockCommand)
• Fixed light brightness scaling (0–1 Homey value was not converted to 0–255 for ESPHome)
• Fixed Flow card error reference causing incorrect diagnostic messages
• Improved connection pool logging consistency
• Removed unreachable code blocks and unused variables for cleaner internals
Do you think it will be possible to see also Weight in Insight, when using ESP32Home Device?
Were you referring to a separate temperature and humidity sensor, or to the ESP board that’s part of your weight sensor?
Sorry my brain is malfunctioning, I ment Weight (post updated)
