[APP][Pro] Esphome Controller App
Funny, I was looking at Heimdall as well, but then I realised my old Alarm was still working perfectly fine, so I will be using the Konnected Panel as interface to the old alarm.
But even if you have no old Alarm anymore, have you seen the Standalone Alarm System built in the Konnected Panel? Much easier and way more reliable than an app, and you can always interface more stuff on top with Homey, for example I used a cool Read light flashing flow :slight_smile:
Plus that in my House I have two independant Areas in the alarm (Spitted zones I think it is called) and Heimdall cannot do that as far as I could see. That will be my second Konnected panel maybe, if I want to interface the second earea too, but already supported by my old alarm so no rush.
And BTW, I do not have any error in Konnected Web app anymore like you do:
Maybe that was on an older build, or because of the Encryption key?
Off to bed now, it is almost 1am over here in Europe :sleeping_face: More adventures tomorrow…
Haven’t heard of Standalone Alarm System, will have to look into it. Once the final version is published to App Store i will remove them all and see if that fixes the error and then re-add. Hopefully that will resolve it.
Have a good night.
I just noticed you mentioned “Function built in“, indeed, but there are no flows to program at all, the Konnected panel does it all, just need to program it right, then it gets burnt in the firmware and it is rock solid. Then from Homey you can just interface the extra bells and whistles, but alarm all the way to the siren is hardcoded in Konnected itelf, without needing anything to function. Then you don’t rely on a flow that hangs or a firmware update of Homey or whatever may happen on you other 127 devices and 98 flows for your security.
Oh, so i think i understand. I don’t have a “Panel” to interface with the Konnected Pro 12 zone. I was using HA and had automation setup and just did everything on my phone. Well almost everything it really was automated, arm and disarm via google home and would turn on when everyone left and turn off when someone came home. I removed the physical panel when i moved in.
And to not get you confused, the Standlone Alarm System is in the Konnected Setup App and it works just like a good old alarm system, not sure I have seen a manual somewhere but pretty straightforward:
Oh wow i don’t think i have ever seen that or maybe i went directly to SmartThings and then to HA so never really paid attention. Yeah so i dont see that in my Konnected App. Is that a UK thing i wonder?
I see something called Noonlight that is like subscription based.
No not a UK thing, and I live in the Netherlands! Just play with the Konnected app and check the settings:
I think noonlight is a Alarm Service, people who check your house when an alarm is triggered, but no idea, available only in the US, not gonna subscribe anytime soon, by the time they get here, my house would be emptied already :rofl:
Really going to sleep now, good luck for now!
Oh i found it. Yep never even looked at that, lol. Thanks, i will play with it and see what i think. Have a good night! :sleeping_face:
Adding the alarm panel was a great learning experience for me. Thanks to @MarcM feedback, we were able to resolve most of the issues. There are a few minor cosmetic flaws, but I’ll fix those over time. Since I don’t have a Konnected device, we built this entirely based on feedback. @MarcM and I put in a lot of effort. I hope you enjoy using it.
@Peter_Kawa I’m curious to know if the test version works for you as well. Did it cause any issues on your device? By the way, thank you for your donation.
@ugrbnk
Update 2:
Another detail: I think the used capability for soil moisture, measure_humidity.soil
should be changed to the standard capability
measure_moisture
I know it’ll be a breaking change, but I don’t mind
TY!
Update1:
I found a little glitch with the “Turned on/off for x [unit]” trigger flow cards for the 3 switches:
the switch names are missing:
The switches:
Yes everything is OK now on v1.0.113, @ugrbnk Thanks!
I will correct your notifications in beta 1.0.119 and send them..
@Peter_Kawa I have similar small glitch here as well but on the Alarm Panel, my 3 outputs do not have a name so a bit tricky to find out which is which:
But @ugrbnk no big deal, I can wait to get that fixed :slight_smile:
Just a question @Jon_Johnson , and probably a dumb one, but how do you get all your sensors showing information on the tile?
There is an option in the Web version.
@ugrbnk, I had previously abandoned using Homey as I required support for the Konnected Alarm Panel Pro but could never get it to identify with the other ESPHome app. I just loaded your app version 1.0.92 from the Homey app and it recognizes my alarm panel but exhibits a number of the issues outlined earlier in this feed. Is it possible to get the newer version of the app to test/evaluate. Having support for the Alarm Panel would be great news. Thanks for your work on this.
Sorry, it didn’t change for existing devices, and the 3 switches are not added when deleting and adding the devices again.
I have to apologise for update nº2 in my previous post: this is not related.
(I was testing a soil sensor for a different app :face_with_peeking_eye::woozy_face: )
Hello, please use version 1.0.120, which is the test version.
Dear Homey and Konnected fans!
I am glad to let you know that the new ESPHome Controller app from Uğur BENEK @ugrbnk now fully supports the Konnected Alarm Panel 12 zones:
  • Full support for the 12 Zones, 3 Outputs and even the Restart button
  • Support for Konnected new Standalone Alarm System mode and probably also Alarm System Interface mode, will confirm when my interface modules arrive
  • Encryption and Alarm codes supported
  • All Flow cards implemented
You can find the new app at ESPHome Controller | Homey and huge thank to @ugrbnk for his hard work and dedication on this (45 test builts in 7 days!).
Thanks. I was able to install the test version and get everything configured. Now I just have figure out how to configure my Ring Keypad and an alarm application similar to what I’m using currently with Smartthings. panel/dashboard to utilize.
MarcM, I just got my Konnected Alarm Panel Pro configured with Ugur’s application. I’m curious as to the process for using the Konnected Standalone Alarm system with Homey. Also, do you use a physical keypad? I currently use the Ring Keypad V2 with Smartthings Home Monitor interfacing to the Konnected Alarm Panel Pro. Any guidance is appreciated. Thanks.
