Heatpump Smart Control v1.8.3 – Major Homey App Update
A major new version of Heatpump Smart Control is here!
Version 1.8.x introduces optional local Modbus support, improved energy monitoring and several reliability improvements.
New: Combined Modbus + Eplucon API Device
Users can now choose between two device types:
Eplucon API: The existing cloud-based integration, fully supported.
Modbus + API: A combined Homey device using local Modbus measurements alongside Eplucon API functionality.
With Modbus, technical data such as temperatures, compressor speed, pump status, pressures and operating modes is retrieved directly from the heat pump.
The Eplucon API remains responsible for room thermostat control and setpoint adjustments.
Modbus is completely optional. Existing API-only installations continue working as before.
Improved Energy Monitoring
The five virtual energy meters (Heating, Cooling, Hot Water, Boost and Standby) now automatically select the most appropriate data source.
Local Modbus operating data is preferred when available.
Automatic fallback to Eplucon API data.
Physical electricity meters remain the source for actual power consumption (W and kWh).
Improved Settings and Diagnostics
Automatic detection of the installed device type.
Separate connection indicators for Modbus and Eplucon API.
Clearer information about active measurement sources.
Improved sensor configuration and diagnostics.
Simplification and Reliability
Compatibility
Existing Eplucon API users do not need additional hardware or configuration.
Modbus users can use a single combined device instead of installing separate API and Modbus devices.
Please note: The Eplucon cloud connection is still required for thermostat control. Local Modbus measurements remain available independently of the cloud connection.
When replacing an existing Homey device, check any Flows referencing the previous device, as Homey does not automatically transfer device references.
Version 1.8.3
This release brings Heatpump Smart Control closer to a local-first integration, while preserving compatibility with existing Eplucon installations.
Thanks to everyone testing the app and sharing suggestions!
