[APP][Pro] Ecovacs Deebot (deprecated)
Ok, then let me add a device specific ID. This will need a re-auth for all other users, but this could be the only way to solve it.
My Deebot is the one and only.
Never had another before
Nowhere found an option to release the Homey registration in the Ecovacs Home app
New test version 2.0.3:
  • Changed login, use device specific ID
@Linden85 FYI and test
In Ecovacs app:
  • In main view: bottom right the “me” icon (account)
  • settings
  • account and security
  • device management
  • remove the “Pixel 7”
PS: are you using a kind of VPN? The app uses http://ipinfo.io/json to get the country/continent for login.
Sorry, copy&paste error. I’m testing already the new app and adding the code to the old one.
Next try with v2.0.4 :grin:
Same error
0604c91b-6553-4058-b760-9faee70d914a
Ok, next try v2.0.5. Not good to do changes without being able to test myself.
42d0f13f-85e6-46e8-9db5-f53f8b157bc0
Same…:open_mouth::open_mouth:
:disappointed_face: No idea if it wasn’t the ID. And you removed/readded the device, right?
Yes ..
No, I am not using VPN
Thank you to point me to the device management.
It’ weird. I can switch between protocol and connected devices, but I can’t delete or edit anything
My mobile seems to be confirmed, but avtual device is greyed out and not selectable.
Ronny you did it! At least for me
I installed latest version and my deebot loaded.
Made a short test with start cleaning and return to home which worked fine.. I guess there is no reason why it shouldn’t work in flows
Thanks again for your help and effort.
Goodmorning @RonnyW ,
I see this on the Homey website.
Where can I find the new app ?:slightly_smiling_face:
It’s in review.
Like the ‘old’ app, too, to release a last stable ‘live’ version.
The new app is online! Take a look and see if it fits your needs.
It’s currently focused on the main functionality and settings. Another main goal is better support for newer devices that use a slightly different API, which also requires some additions to the underlying JS module.
Map images are not supported yet. I still have to check what’s possible based on the changed module interface.
New app:
New app topic:
Please use this topic only to report truly urgent bugs. I can only provide basic maintenance support.
@Linden85 FYI :slight_smile:
“Is it an idea to share my vacuum cleaners with you to test?”
Yes, I can try. You can change your password to a temporary one. But you will have to forward the 2FA mails :slight_smile:
Just PM me.
