Good morning,
You are right; I had a diagnostic report generated and then updated the app. It is still crashing with version 1.11.10. My apologies for the confusion. I will update to version 1.11.11 right away and get back to you. Thank you for your response and for the solution to the problem.
I’ve made a new diagnostic report. Still getting stuck, but it feels less frequent than before. Does it happen because I’m using an iPad mini wall-mounted and occasionally checking in from iPhone?
Thanks for confirming the version and sending the new diagnostic report. Sorry to hear the readings are still getting stuck.
I haven’t found anything pointing to your wall-mounted iPad or checking Homey on your iPhone as the cause. Both show the readings already held by Homey, so you shouldn’t need to change how you use them.
I did find a problem where a temporary failure checking the main battery could leave the readings stuck, even once the battery was reachable again. I’ve fixed that, along with a few other connection and recovery issues.
These changes are now in 1.11.14 on Test. I’ve tested the changes here, so hopefully this sorts it out. Let me know how it behaves on your setup.
When convenient, please update and check that Homey shows 1.11.14. Keep your existing devices and 3.84 kWh capacity setting—there’s no need to Repair, remove or re-pair anything. The update briefly restarts the app, so pick a suitable time if you have Flows depending on the readings.
Then just use it normally. If it gets stuck again, please let me know roughly when, which devices stop updating, whether the EcoFlow app is still updating and whether Homey recovers by itself. No need for another large diagnostic report at this stage.
Thanks again for your patience and help testing this.
Thanks, I’ve reviewed your diagnostic report. There is a version mismatch worth checking first: your message says 1.11.19, but the report itself identifies 1.10.3, and its logs show the AC 5000 using the older STREAM device types.
Could you check the installed EcoFlow app version in Homey’s app settings on your Homey Pro 2023, and tell me the device type shown at the bottom of the battery’s settings page? The version on the App Store page can be different from the one currently installed. No need to remove, Repair or re-pair anything, or change MQTT or battery settings.
If the installed app still shows 1.10.3, please let me know before making further changes. I’ll guide you through the Test update and the correct AC 5000 path while keeping your existing devices, history and Flows in place. If it already shows 1.11.19, please send one integration support report from the app settings, after reviewing it, so I can check which driver and connection are actually in use. Please send that report privately rather than posting household diagnostics here.
A further update is now available on Test: 1.11.20. I found another issue where two refreshes running together could interfere with the battery connection checks and leave newer readings marked unavailable. I’ve fixed that and installed this version on my own Homey; readings and counters have continued updating during the initial checks.
When convenient, please update using the Test link and check that the installed version in Homey’s app settings shows 1.11.20:
Keep your existing devices, settings and 3.84 kWh capacity as they are. No removal, re-pairing or Repair is needed. The update briefly restarts the app, so choose a suitable time if your Flows depend on the readings.
Could you let me know whether the readings now keep updating during normal use? If they get stuck again, please note roughly when, which devices stop updating, whether EcoFlow itself is still showing fresh readings, and whether Homey recovers on its own. If practical, tell me before restarting so we don’t lose the useful evidence. No need for another large diagnostic report at this stage.
Hopefully this gets us closer to sorting it on your setup. Thanks again for helping test it.
You were right! I’ve checked the installed app version on my Homey Pro 2023, and it is indeed 1.10.3.
I haven’t changed anything and will wait for your instructions on how to safely update to the latest Test version while preserving my existing devices, history and Flows.
Thanks for checking—that explains the mismatch. Let’s update the existing app first, keeping your current devices in place.
Open the Test link below while signed into the Homey account that owns your Homey Pro 2023. Choose that same Homey and install/update the app. Don’t uninstall the existing app first. The update briefly restarts its readings, so choose a suitable time if you have Flows depending on them. EcoFlow STREAM Series | Homey
Once it finishes, open the EcoFlow STREAM Series app settings in Homey and check that the installed version shows 1.11.20. If it still says 1.10.3, stop there and let me know.
Keep your existing battery devices. An AC 5000 previously added as STREAM Unit or STREAM Home Battery may now show a message explaining that it needs the dedicated 5000 connection. That is expected; the update doesn’t convert its device type automatically. Please don’t delete it or change its Flows yet.
In Homey, go to Devices → + → EcoFlow STREAM Series → STREAM 5000 Series Unit. Sign in with the same EcoFlow app account and region you use for the AC 5000, then select the unit. This uses your EcoFlow app login, rather than Developer API keys. If you already have a device of this exact type, use that one rather than adding a duplicate. If this choice or your battery is missing, stop and tell me what you see.
Leave battery settings, MQTT settings and Energy settings unchanged, and allow a few minutes for normal reports. Please tell me whether the new unit shows battery level, battery power and state. If it stays blank, send one Copy integration support report from the EcoFlow app settings by private message after reviewing it. Never send passwords, API keys or tokens.
The separate Unit monitor lets us check the correct connection before changing your existing setup. Your old device’s history and Flow references stay with that old device; they don’t transfer automatically to the new monitor. We can review those together once readings work. Please leave STREAM 5000 Home Battery and its Energy pairing for a separate step so we don’t introduce a second battery contributor during this check.
Thanks—the screenshot helps. I’ve just checked on my local test rig and confirmed that STREAM 5000 Series Unit is available. Your screenshot is still showing the older device list.
Please close the pairing screen, fully close and reopen the Homey app on your iPad, then check again. In Dutch, the option is called STREAM 5000-serie-unit.
If it’s still missing, please try through my.homey.app, selecting the same Homey Pro 2023. That will help us check whether the iPad is showing an outdated list.
No need to restart Homey, uninstall anything or remove your existing devices. If neither screen shows it, let me know and we’ll investigate further.
I forgot to mention that the iPad app kept onmentioning the wrong battery. But the solution was to do it through the my.homey.app site. That one worked right away.
Thank you so much for your help, this is really appreciated !!!
I’m very busy myself at the moment, but I’m still following this topic. What’s the current status—can we control the EcoFlow STREAM AC5000 using IF/THEN yet?
I see that some thorough testing has already been done, but from my quick read-through, I’m not yet sure if it’s actually working.
I’d like to mention that it is significantly more stable than before. When switching to the official EcoFlow iPhone app, the community app in Homey does lose its live readings, but they eventually recover; if it takes too long, I simply restart the app. No more freezes on its own.
Yes, there’s now a first IF/THEN option for the STREAM 5000 / AC 5000 in Homey Test 1.11.25. Getting to this point with the IF/THEN scenarios has been a huge piece of work. A lot of it has gone into checking what the EcoFlow API can actually do and how Homey should handle a request when the outcome is uncertain.
The new THEN card is called Request installation backup reserve (no confirmation). It lets a Flow request a change to the backup reserve percentage. It’s off by default and needs EcoFlow Developer API keys, an opt-in on the physical battery device, and an installation already in Self-consumption with backup reserve enabled. If your batteries are linked, the request may affect the linked installation.
A successful Flow means EcoFlow accepted the request. Please check the reserve separately in the EcoFlow app to see whether it actually changed. Charge-now, pause and automatic restoration are outside the scope of this build.
If you’re happy to try it, please check you’re on 1.11.25 and start by making sure your existing readings, Flows, history and counters still look right. Keep your existing paired devices. If your setup is already eligible and you can supervise it, try one small reserve change in a manually run Flow. Keep it separate from schedules, retries and other battery actions. If the result is uncertain or anything unexpected changes, stop and check the EcoFlow app before trying again.
What would help me most is:
Your battery model and firmware, and whether it’s standalone or linked.
Whether monitoring, saved Flows, history and counters still look right.
The reserve before the test, the percentage you requested, and what the EcoFlow app showed afterwards.
What Homey reported and roughly how long any change took to appear in EcoFlow.
Any unexpected changes on linked units or to other battery settings.
Monitoring-only feedback is welcome too, especially if your setup isn’t eligible for the card. Please leave out credentials, serial numbers and raw diagnostic reports.
Quick update: I spotted a bug that could leave the original STREAM Home Battery showing as unavailable after a temporary change in which unit EcoFlow reported as the main one.
The fix is in Homey Test 1.11.26. I checked it on my own Homey Pro and the battery is reporting again, with its counters, history and Flows preserved. If you’re trying the IF/THEN card or checking your readings, please use 1.11.26 and include the version in any feedback.
Thank you for your work on this app. I can see why it would be very time consuming and frustrating to work on an API which is not described or supported by Ecoflow (yet).
But I love the fact that you have the first call back to the battery available. I tested it and it indeed seems to work. I am not sure if I have a use case to alter the back up level, but I appreciate the fact that I am able to change it. Guess we are all looking to control the battery from Homey and in time it will be possible.
Keep up the good work and thank you very very much for all you have done already!
