New additions to my dashboard.
A little problem with the Formula 1 Race Weekend Tracker:
Script Error
⚠️ Error: Failed to fetch F1 calendar: 403 Forbidden
at Test.js:17:9
at process.processTicksAndRejections (node:internal/process/task_queues:103:5)
at async HomeyScriptApp.runScript (/app/app.js:364:22)
at async /app/lib/flow/actions/RunCodeAction.js:25:7
{"message":"Failed to fetch F1 calendar: 403 Forbidden"}
While wandering around, i noticed that the save & load buttons disappear when opening the responsive demo dashboard.
Apparently, it also happens when opening the ‘regular’ demo dashboard.
I get it that the demo-dashboard should not be overwritten, but it’s a little annoying that you can’t load another dashboard or save it under another name to use it as a development-starter…
You can “overwrite” the demo dashboard. The actual demo dashboard is secretly saved in another location, so if you save a file as “demo” that will become the new demo file. You can also save a file as “factorydefault” and every time you reset the canvas, that will be the default. If you delete this file the original default file is restored.
The reason the demo doesn’t have the save button, media gallery, etc. is that those are Homey-only functions, and the demo needs to be able to run online too. So the demo uses a “Simulation” platform to show simulated values. If you set this to Homey, you’ll see the full dashboard-specific Homey functionality.
Hi all, is there a way to display the electricity pricing per quarter in a nice bar graphic covering the whole day or the last 24 hours?
Something like this?
Keywords:
- data (dutch energy): Enever.nl for electricity (per hour or 15 minutes) and gas (per day)
- script calculating the lowest en highest day prices
- script creating (animated) svg with colorized columns
- in my case: Homey Zonneplan app displaying costs per day, month, year
Exactly! But then just the graph (I’m using Zonneplan also).
What do you need from my keywords list in my previous message?
I’ve made a short tutorial how you can create a graph with energy prices previously:
Well, the graph by quarter and the legenda. I’m not using gas, so just electricity…
Nice, I will give this a try. Thx!
@Amersfoort Yes, please. This one is way more appealing than the default ones.
How to show the electricity 15 minute prices:
- generate an Enever token on Enever.nl
- define this key in script below in the “const ENEVER_TOKEN”
- define in Dashboard Studio and image with width 1890px and height 1240px. If other size needed, change “const CANVAS_BREEDTE” and “const CANVAS_HOOGTE” in script below
- flow:
- copy this script in Homey script card
- copy the name of the Dashbaord Studio variabele (second card) in the Data Source
- execute flow (every day at 3pm)
Any questions:
- Claude AI is a great scripting help
- Ask (me) in this post.
Have fun.
* Homey Script: Stroomprijzen ophalen (Enever) en tekenen als SVG
* WAT DOET HET SCRIPT?
* Haalt zelf de kwartierprijzen van elektra op bij enever.nl en geeft een
* SVG-staafgrafiek terug voor Dashboard Studio. Er is geen invoer uit een
* Advanced Flow meer nodig (args wordt niet gebruikt) en er worden geen
* gasprijzen verwerkt.
* RETURN
* Een string met de SVG (in een <div>), direct bruikbaar als tag.
* Bij een fout wordt een fout gegooid, zodat de flow dit meldt.
* LOGICA IN HET KORT
* 1. Bepaal het huidige kwartier in de tijdzone Europe/Amsterdam.
* 2. Haal de prijzen op bij Enever (prijsZP, resolutie 15 minuten) en
* bewaar alleen de records van vandaag en later, met het kwartier
* (0-95) direct afgeleid uit het tijdstip in de data.
* 3. Toon alleen de data vanaf 2 uur geleden (8 kwartieren) en later.
* 4. Bereken per dag de drempels voor de kleur van de balken:
* groen = één van de 20 goedkoopste kwartieren van die dag
* oranje = één van de 20 duurste kwartieren van die dag
* donkergroen = alles daartussen
* grijs = kwartieren in het verleden
* 5. Schaal de Y-as op even getallen (rasterlijn per 2 cent, label en
* tick-mark per 4 cent), met 5% extra ruimte boven en onder.
* 6. Teken de balken met een groei-animatie en markeer het huidige kwartier
* met "Nu" en de actuele prijs in de kleur van de bijbehorende balk.
* LAYOUT
* - Canvas 1890 x 1240 px, Y-as 120 px van de linkerrand.
* - 15 px ruimte boven de hoogste waarde.
* - 5 px ruimte tussen de buitenste balken en de randen.
* - "Nu", de indicatorlijn en de prijs krijgen hun kleur via een inline
* style, omdat de CSS van het dashboard het fill-attribuut kan overschrijven.
* GEHEUGENBEHEER
* - Alleen de records vanaf vandaag worden bewaard, niet de volledige
* 30 dagen uit de API.
* - De SVG wordt opgebouwd in een array en pas aan het eind met één join()
* samengevoegd.
* - De dagdrempels worden per datum één keer berekend.
* - Min/Max-prijs worden met een lus bepaald, zonder extra array.
* - Zodra gegevens niet meer nodig zijn (response, ruwe JSON, overzicht)
* worden ze op null gezet. Alle grote variabelen zijn 'let' en worden in
* 'finally' nogmaals op null gezet, ook bij een fout, omdat de garbage
* collector van Homey Scripts niet altijd tijdig opruimt.
* LET OP
* De Enever-token staat in de variabele ENEVER_TOKEN in de configuratie.
// CONFIGURATIE
// Persoonlijke Enever API-sleutel.
const ENEVER_TOKEN = "Here your Enever api key";
// Enever API: prijsZP = prijs inclusief btw (Zonneplan-tarief), 15 = kwartierprijzen.
const ENEVER_URL = "https://enever.nl/apiv3/stroomprijs_laatste30dagen.php?token=" + ENEVER_TOKEN + "&price=prijsZP&resolution=15";
// Landinstelling en tijdzone voor het bepalen van "nu".
const LAND_INSTELLING = "nl-NL";
const TIJDZONE = "Europe/Amsterdam";
// Afmetingen van het canvas en de marges (in pixels).
const CANVAS_BREEDTE = 1890;
const CANVAS_HOOGTE = 1240;
const MARGE_LINKS = 120; // ruimte voor Y-as, labels en tick-marks
const MARGE_RECHTS = 5;
const MARGE_BOVEN = 15; // extra ruimte boven de hoogste waarde
const MARGE_ONDER = 120; // ruimte voor tijdlabels en "Nu"-indicator
// Ruimte tussen de buitenste balken en de assen (in pixels).
const MARGE_BUITENSTE_BALK = 5;
// Balkbreedte als deel van de breedte van één tijdslot, met een ondergrens.
const BALK_BREEDTE_FACTOR = 0.65;
const MINIMALE_BALK_BREEDTE = 3;
// Aantal kwartieren (2 uur) dat in het verleden nog getoond wordt.
const KWARTIEREN_TERUGKIJKEN = 8;
// Aantal goedkoopste/duurste kwartieren per dag voor de groene/oranje kleur.
const AANTAL_KWARTIEREN_LAAG_HOOG = 20;
// Animatie: alle balken zijn samen binnen 4 seconden klaar.
const TOTALE_ANIMATIETIJD = 4.0;
const ANIMATIEDUUR_PER_BALK = 0.8;
// Kleuren van de balken.
const KLEUR_VERLEDEN = "#666666";
const KLEUR_LAAG = "#00ff00";
const KLEUR_HOOG = "#ff5e00";
const KLEUR_NORMAAL = "#167d10";
// HULPFUNCTIES
* Geeft het huidige uur en de huidige minuut in de tijdzone Europe/Amsterdam.
* Gebruikt formatToParts, zodat het scheidingsteken (: of .) niet uitmaakt.
function bepaalHuidigeTijd(huidigMoment) {
const tijdFormatter = new Intl.DateTimeFormat(LAND_INSTELLING, {
hour: "numeric", minute: "numeric", hour12: false, timeZone: TIJDZONE
const tijdDelen = tijdFormatter.formatToParts(huidigMoment);
let uur = 0, minuut = 0;
for (let i = 0; i < tijdDelen.length; i++) {
if (tijdDelen[i].type === "hour") uur = parseInt(tijdDelen[i].value, 10);
if (tijdDelen[i].type === "minute") minuut = parseInt(tijdDelen[i].value, 10);
return { uur: uur, minuut: minuut };
* Berekent de kleurdrempels van één dag uit de prijzen van die dag.
* laag = prijs van het 20e goedkoopste kwartier (of het duurste als er minder zijn)
* hoog = prijs van het 20e duurste kwartier (of het goedkoopste als er minder zijn)
* Let op: '||' is bewust behouden uit het origineel, zodat een prijs van exact 0
* zich hetzelfde gedraagt als voorheen.
function berekenDagDrempels(dagPrijzen) {
dagPrijzen.sort((a, b) => a - b);
return {
laag: dagPrijzen[AANTAL_KWARTIEREN_LAAG_HOOG - 1] || dagPrijzen[dagPrijzen.length - 1],
hoog: dagPrijzen[dagPrijzen.length - AANTAL_KWARTIEREN_LAAG_HOOG] || dagPrijzen[0]
// HOOFDPROGRAMMA
// Alle grote variabelen zijn 'let' zodat ze in 'finally' op null gezet kunnen worden.
let apiResponse = null;
let eneverJson = null;
let prijsRecords = null;
let dagPrijzenPerDatum = null;
let weergaveData = null;
let drempelsPerDatum = null;
let svgRegels = null;
let svgTekst = null;
try {
// Stap 1: huidig moment, kwartier en datum bepalen
const huidigMoment = new Date();
const cacheBusterId = huidigMoment.getTime(); // unieke naam voor CSS-klassen en lettertype-URL
const huidigeTijd = bepaalHuidigeTijd(huidigMoment);
// Kwartierindex binnen de dag: 0 = 00:00, 1 = 00:15 ... 95 = 23:45
const huidigeKwartierIndex = (huidigeTijd.uur * 4) + Math.floor(huidigeTijd.minuut / 15);
// Datum van vandaag als jjjj-mm-dd (en-CA geeft dit formaat)
const vandaagDatumSleutel = huidigMoment.toLocaleDateString("en-CA", { timeZone: TIJDZONE });
// Stap 2: prijzen ophalen bij Enever
apiResponse = await fetch(ENEVER_URL);
if (!apiResponse.ok) {
throw new Error("Enever API gaf een foutmelding: HTTP " + apiResponse.status);
eneverJson = await apiResponse.json();
apiResponse = null; // response-object is niet meer nodig
if (!eneverJson || !Array.isArray(eneverJson.data) || eneverJson.data.length === 0) {
throw new Error("Geen data ontvangen van Enever API.");
// Stap 3: records van vandaag en later bewaren
// Formaat van item.datum: "YYYY-MM-DD HH:MM:SS". Het kwartier volgt direct
// uit uur en minuut, dus er hoeft niet meer geteld te worden.
prijsRecords = [];
dagPrijzenPerDatum = {};
const apiItems = eneverJson.data;
for (let i = 0; i < apiItems.length; i++) {
const datumTijdTekst = apiItems[i].datum;
const itemDatum = datumTijdTekst.substring(0, 10);
// Tekstvergelijking werkt correct bij het formaat YYYY-MM-DD
if (itemDatum < vandaagDatumSleutel) continue;
const uurNummer = parseInt(datumTijdTekst.substring(11, 13), 10);
const minuten = parseInt(datumTijdTekst.substring(14, 16), 10);
// Prijs per kWh (incl. btw) omrekenen naar centen, afgerond op 1 decimaal
const prijsInCenten = Number((Number(apiItems[i].prijsZP) * 100).toFixed(1));
prijsRecords.push({
datum: itemDatum,
kwartierIndex: (uurNummer * 4) + Math.floor(minuten / 15),
prijs: prijsInCenten
// Prijzen per dag verzamelen voor de kleurdrempels
if (!dagPrijzenPerDatum[itemDatum]) dagPrijzenPerDatum[itemDatum] = [];
dagPrijzenPerDatum[itemDatum].push(prijsInCenten);
// De volledige API-data is nu verwerkt
eneverJson = null;
if (prijsRecords.length === 0) throw new Error("Geen stroomprijzen vanaf vandaag gevonden.");
// Chronologisch sorteren: eerst op datum, dan op kwartier
prijsRecords.sort((a, b) => (a.datum < b.datum ? -1 : (a.datum > b.datum ? 1 : a.kwartierIndex - b.kwartierIndex)));
// Stap 4: kleurdrempels per dag (over alle kwartieren van die dag, dus ook het verleden)
drempelsPerDatum = {};
for (const datum in dagPrijzenPerDatum) {
drempelsPerDatum[datum] = berekenDagDrempels(dagPrijzenPerDatum[datum]);
// Stap 5: alleen data vanaf 2 uur geleden tonen, en min/max prijs bepalen
weergaveData = prijsRecords.filter(kwartier => !(
kwartier.datum === vandaagDatumSleutel && kwartier.kwartierIndex < huidigeKwartierIndex - KWARTIEREN_TERUGKIJKEN
const aantalRecords = weergaveData.length;
if (aantalRecords === 0) throw new Error("Geen stroomprijzen na filtering.");
let minimalePrijs = Infinity;
let maximalePrijs = -Infinity;
for (let i = 0; i < aantalRecords; i++) {
const prijs = weergaveData[i].prijs;
if (prijs < minimalePrijs) minimalePrijs = prijs;
if (prijs > maximalePrijs) maximalePrijs = prijs;
// Stap 6: schaling van de grafiek
const grafiekInhoudHoogte = CANVAS_HOOGTE - MARGE_BOVEN - MARGE_ONDER;
const nulLijnY = CANVAS_HOOGTE - MARGE_ONDER; // onderkant van de grafiek
// 5% marge over het verschil tussen min en max
const prijsBereikSpan = (maximalePrijs - minimalePrijs) || 1;
const berekendMinimum = minimalePrijs < 0 ? minimalePrijs * 1.05 : minimalePrijs - (prijsBereikSpan * 0.05);
const berekendMaximum = maximalePrijs + (prijsBereikSpan * 0.05);
// Afronden naar even getallen voor schone Y-aslijnen
const yAsMinimum = Math.floor(berekendMinimum / 2) * 2;
const yAsMaximum = Math.ceil(berekendMaximum / 2) * 2;
const prijsBereik = (yAsMaximum - yAsMinimum) || 1;
// Positie van de 0-lijn: bij negatieve prijzen ligt die boven de onderkant
const yNulPositie = minimalePrijs < 0
? nulLijnY - (((0 - yAsMinimum) / prijsBereik) * grafiekInhoudHoogte)
: nulLijnY;
// Horizontale indeling: elk record krijgt een even breed tijdslot
const beschikbareBreedte = CANVAS_BREEDTE - MARGE_LINKS - MARGE_RECHTS;
const tijdSlotBreedte = beschikbareBreedte / aantalRecords;
const balkBreedte = Math.max(MINIMALE_BALK_BREEDTE, tijdSlotBreedte * BALK_BREEDTE_FACTOR);
// Zorgt voor exact 5 px tussen de eerste balk en de Y-as
const eersteKolomMarge = MARGE_BUITENSTE_BALK + (balkBreedte / 2);
// Stap 7: SVG opbouwen in een array (geen string-concatenatie over het geheel)
svgRegels = [];
svgRegels.push(
"<div style='width:100%; max-width:" + CANVAS_BREEDTE + "px; overflow:hidden;'>",
"<svg width='100%' height='100%' viewBox='0 0 " + CANVAS_BREEDTE + " " + CANVAS_HOOGTE + "' xmlns='http://www.w3.org/2000/svg' style='background-color:transparent; display:block;'>",
" <defs>",
" <style>",
" @import url('https://fonts.googleapis.com/css2?family=Exo+2&display=swap&v=" + cacheBusterId + "');",
" text { font-family: 'Exo 2', sans-serif; }",
" @keyframes groeiBalk_" + cacheBusterId + " { from { transform: scaleY(0); } to { transform: scaleY(1); } }"
// Voor elke balk een eigen CSS-klasse met oplopende vertraging, zodat de
// balken van links naar rechts "groeien"
const maximaleVertraging = TOTALE_ANIMATIETIJD - ANIMATIEDUUR_PER_BALK;
const vertragingStap = aantalRecords > 1 ? maximaleVertraging / (aantalRecords - 1) : 0;
for (let index = 0; index < aantalRecords; index++) {
svgRegels.push(" .balk-" + index + "-" + cacheBusterId + " { animation: groeiBalk_" + cacheBusterId + " " + ANIMATIEDUUR_PER_BALK + "s cubic-bezier(0.1, 0.76, 0.55, 0.94) forwards; animation-delay: " + (index * vertragingStap).toFixed(3) + "s; transform: scaleY(0); }");
svgRegels.push(
" </style>",
" <filter id='glow'><feGaussianBlur stdDeviation='3'/><feMerge><feMergeNode/><feMergeNode in='SourceGraphic'/></feMerge></filter>",
" </defs>"
// --- As-labels ---
const yAsLabelY = MARGE_BOVEN + (grafiekInhoudHoogte / 2);
const xAsEindPositie = CANVAS_BREEDTE - MARGE_RECHTS;
const yAsLabelX = MARGE_LINKS - 95;
svgRegels.push(
" <text x='" + yAsLabelX + "' y='" + yAsLabelY + "' fill='white' font-size='30' transform='rotate(-90, " + yAsLabelX + ", " + yAsLabelY + ")' text-anchor='middle'>Prijs per kWh (cent)</text>",
" <text x='" + (MARGE_LINKS + ((xAsEindPositie - MARGE_LINKS) / 2)) + "' y='" + (nulLijnY + 110) + "' fill='white' font-size='30' text-anchor='middle'>Tijd (uur)</text>"
// --- Rasterlijnen per 2 cent; label en tick-mark per 4 cent ---
for (let prijsWaarde = yAsMinimum; prijsWaarde <= yAsMaximum; prijsWaarde += 2) {
const yLijnPositie = nulLijnY - (((prijsWaarde - yAsMinimum) / prijsBereik) * grafiekInhoudHoogte);
// Horizontale hulplijn
svgRegels.push(" <line x1='" + MARGE_LINKS + "' y1='" + yLijnPositie + "' x2='" + xAsEindPositie + "' y2='" + yLijnPositie + "' stroke='rgba(255,255,255,0.2)' stroke-width='2' />");
if (prijsWaarde % 4 === 0) {
// Tick-mark (streepje) op de Y-as
svgRegels.push(" <line x1='" + (MARGE_LINKS - 12) + "' y1='" + yLijnPositie + "' x2='" + MARGE_LINKS + "' y2='" + yLijnPositie + "' stroke='white' stroke-width='2' />");
// Cijfer naast de tick-mark
svgRegels.push(" <text x='" + (MARGE_LINKS - 20) + "' y='" + (yLijnPositie + 10) + "' fill='white' font-size='30' text-anchor='end' opacity='0.8'>" + prijsWaarde + "</text>");
// --- Balken en tijdlabels ---
// Positie van het huidige kwartier in de lijst (-1 als het er niet in zit)
const indexVanNu = weergaveData.findIndex(
kwartier => kwartier.datum === vandaagDatumSleutel && kwartier.kwartierIndex === huidigeKwartierIndex
const kwartier = weergaveData[index];
const prijs = kwartier.prijs;
const isHeelUur = (kwartier.kwartierIndex % 4) === 0;
const uurLabel = Math.floor(kwartier.kwartierIndex / 4).toString();
const isVerleden = kwartier.datum === vandaagDatumSleutel && kwartier.kwartierIndex < huidigeKwartierIndex;
const isNu = index === indexVanNu;
const drempels = drempelsPerDatum[kwartier.datum];
// Verticale positie en hoogte van de balk (negatieve prijzen hangen onder de 0-lijn)
const yPrijsPositie = nulLijnY - (((prijs - yAsMinimum) / prijsBereik) * grafiekInhoudHoogte);
const slotMiddenX = MARGE_LINKS + eersteKolomMarge + (index * tijdSlotBreedte);
const balkY = prijs >= 0 ? yPrijsPositie : yNulPositie;
const balkHoogte = Math.max(2, prijs >= 0 ? yNulPositie - yPrijsPositie : yPrijsPositie - yNulPositie);
// Kleur: verleden = grijs, anders laag/hoog/normaal op basis van de dagdrempels
const kleur = isVerleden
? KLEUR_VERLEDEN
: (prijs <= drempels.laag ? KLEUR_LAAG : (prijs >= drempels.hoog ? KLEUR_HOOG : KLEUR_NORMAAL));
svgRegels.push(
" <g>",
" <rect x='" + (slotMiddenX - (balkBreedte / 2)) + "' y='" + balkY + "' width='" + balkBreedte + "' height='" + balkHoogte + "' fill='" + kleur + "' fill-opacity='" + (isVerleden ? "0.4" : "1.0") + "' filter='url(#glow)' class='balk-" + index + "-" + cacheBusterId + "' style='transform-origin: " + slotMiddenX + "px " + yNulPositie + "px;' />"
// Streepje op de X-as bij elk heel uur
if (isHeelUur) {
svgRegels.push(" <line x1='" + slotMiddenX + "' y1='" + nulLijnY + "' x2='" + slotMiddenX + "' y2='" + (nulLijnY + 12) + "' stroke='white' stroke-width='2' />");
if (isNu) {
// Huidige prijs met een komma in plaats van een punt
const huidigePrijsGeformatteerd = prijs.toFixed(1).replace('.', ',');
// Indicatorlijn, "Nu" en prijs in de kleur van de kolom (inline style i.v.m. dashboard-CSS)
svgRegels.push(
" <line x1='" + slotMiddenX + "' y1='" + nulLijnY + "' x2='" + slotMiddenX + "' y2='" + (nulLijnY + 50) + "' stroke='" + kleur + "' stroke-width='3' />",
" <text x='" + slotMiddenX + "' y='" + (nulLijnY + 75) + "' text-anchor='middle' style='fill: " + kleur + ";' font-size='30'>Nu</text>",
" <text x='" + slotMiddenX + "' y='" + (nulLijnY + 115) + "' text-anchor='middle' style='fill: " + kleur + ";' font-size='30'>" + huidigePrijsGeformatteerd + " cent</text>"
} else if (isHeelUur && (indexVanNu === -1 || Math.abs(index - indexVanNu) > 1)) {
// Uurlabel, behalve direct naast de "Nu"-indicator (anders overlappen ze)
svgRegels.push(" <text x='" + slotMiddenX + "' y='" + (nulLijnY + 45) + "' text-anchor='middle' fill='white' font-size='30'>" + uurLabel + "</text>");
svgRegels.push(" </g>");
// --- Basislijnen: X-as, Y-as en (bij negatieve prijzen) de 0-lijn ---
svgRegels.push(
" <line x1='" + MARGE_LINKS + "' y1='" + nulLijnY + "' x2='" + xAsEindPositie + "' y2='" + nulLijnY + "' stroke='white' stroke-width='3' />",
" <line x1='" + MARGE_LINKS + "' y1='" + MARGE_BOVEN + "' x2='" + MARGE_LINKS + "' y2='" + nulLijnY + "' stroke='white' stroke-width='3' />"
if (minimalePrijs < 0) {
svgRegels.push(" <line x1='" + MARGE_LINKS + "' y1='" + yNulPositie + "' x2='" + xAsEindPositie + "' y2='" + yNulPositie + "' stroke='rgba(255,255,255,0.5)' stroke-width='2' />");
svgRegels.push("</svg>", "</div>");
// Stap 8: samenvoegen en teruggeven
svgTekst = svgRegels.join('\n');
// De waarde van 'return' wordt bepaald vóór 'finally' draait, dus het
// terugzetten op null in 'finally' heeft geen invloed op het resultaat.
return svgTekst;
} finally {
// Wordt altijd uitgevoerd (ook bij een fout of een vroege return):
// alle grote variabelen expliciet vrijgeven voor de garbage collector.
if (svgRegels) svgRegels.length = 0;
svgRegels = null;
svgTekst = null;
eneverJson = null;
apiResponse = null;
Thanks!
