I want to challenge myself; easy is no fun. I think you might recognize a bit of yourself in this.
If I had wanted to take the easy route, I would have gone with the standard Homey dashboards. The many options offered by Dashboard Studio are precisely what provide those creative possibilities.
EDIT:
The fly-in and fly-out of an image were not that hard to define:
definition image X-value (on a HD-screen):
if(value==“in”,countdown(“1s”, -1201, 780,“ease-out”),if(value==“out”,countdown(“1s”,780,2800,“ease-in”),-1201))
Thanks, I’m glad you like it. For me it’s quite cluttered but I plan to remove some devices.
The clock isn’t the startup page. It’s simply page 2 of the same dashboard, set as the Inactivity Return Page: after 180 seconds without a touch, the dashboard drops back to page 2. I open the dashboard with &page=1 in the URL, so it always starts on the main page.
That’s right, page 2 has a big invisible push button over the whole screen. It’s a Switch widget with style “invisible” and action “go to page 1”, sitting on top of everything else. There’s also an invisible button over the time in the main page’s header, so tapping the time jumps straight to the clock in case I don’t want to wait 180 seconds.
I’d love to see people posting their work, we all need some inspiration, don’t we?
It is on an iPad 11". One day, it will end up on the wall as I have one of those Kuxiu stands that also charges the iPad once the battery drops under a specific %. For now just sits in the living room, on the Kuxiu stand beside a couch.
Yeah, that was my experience too. When I first made dashboards I wanted to control everything I could, like every single device or light. The reality is I hardly used it. There were so many devices I never actually needed to control. It’s also not user friendly at all to set every individual light. It’s way more convenient to just set a full mood. Even then, I hardly use that. The whole point of home automation is to automate things, so I mostly just use overrides like “Study light” or “Disco”.
I’m noticing with the latest version that button and modus states are no longer refreshed after editing a page. Not even when refreshing. The icons light up for a second after the refresh before going back to their off-state.
by latest you meant 2.5.2 right?
I can’t find anything wrong in the code.
Did you change anything in the Homey settings, especially the stat caching settings?:
There’s a little glitch in your Formula 1 Race Tracker script imo. The time is one hour off. For Las Vegas the script says it start at 4 o’clock but it starts at 5 o’clock. Same with the qualifying this morning.
That’s not good. That’s probably why it didn’t update the values. I think you’re doing too many complex things at once on the Homey side, so it ran out of memory and crashed. Did you created a crash report? If you did, send me the ID here so I can look into it.
Curious how this will work out. Panels indicating green, yellow, red flag, SC and VSC. Similar to the panels along the trackside. Along with Pit entry open/close
New: Markdown Studio
Introducing Markdown Studio, a brand-new full editor for Text widgets with three workspace modes: Blocks (a drag-and-drop builder with starter templates and a live properties panel), Visual (edit directly on the formatted page as it appears on your dashboard and click any icon, image, link, or topic to customize it in place), and Raw (a Markdown source editor with formatting toolbar and table tools). Toggle Split view to keep the live formatted page side by side with a draggable divider, drag blocks directly into table cells and callouts to combine multiple elements, preview real dashboard values with Live Data, and browse Phosphor icons, your Homey Image Gallery, and topic formulas right inside the editor.
FIX: Formula 1 Race Tracker Guide Timezone
Updated the Formula 1 Race Tracker tip so the HomeyScript formats session start times in your Homey’s local timezone instead of UTC, along with safer countdown checks when no session is active.
I liked @Vincent_Ducate’s idea /code and integrated it into the native Markdown editor. It now has a full block editor where you can drag, drop, and edit cards, but it also has a split preview editor. You can still use the RAW editor with split preview. And there’s a new “What you see is what you get” editor built in.
haha that’s insane. Just curious, these are all svg’s and / or markdown tables generated with Homeyscript? These are probably the cause of your crashes. You might need to set this setting to optimized:
They are indeed most markdown tables generated by Homeyscript and svg’s . The F1 Live Timing has been heavily modified to give me all the data. Had to do some tweaks during the race. But all things considered it worked rather well. Here are some screenshots
You will need the modified F1 Live Timing app as well to be able to create it. I will check if I can somehow provide an installation package outside of the Homey app-store. The scripts, flows and dashboard shouldn’t be a problem to share. I’ll take a look at it asap.
Trying to animate the value of a Gauge with the formula below:
if({{homey/event/actievePagina}}==3,countdown(“5s”,{{homey/variables/dsvorigvermogen/value}},value,“linear”,“steps(100)”),0)
The intention is for the value on the gauge to transition (be animated) from the previous value to the current value over a period of 5 seconds, divided into 100 equal steps. In practice, many intermediate values are displayed within a few seconds (well under 5 seconds) after which the gauge jumps to the final, current value.
I would expect this to work (But I did not check the code). Anyway… Don’t bother, This is way too clumsy and too much work by keeping track of all the old values.
I will add a future update have a build in animation section of the gauge to animate between values.
