[APP][Pro] Dashboard Studio - A completely free-form dashboard designer
Just at a quick glance:
This is empty. Link the topic in this dropdown menu and reference it in the formula using the word value.
Only add other topics if you want the outcome of the formula to depend on those values as well.
How stupid of me :roll_eyes:. Thanks.
Nah, it’s not stupid. These conversations help me make the software easier to understand. I’ll probably make the help docs and tooltips clearer based on these talks. I think a lot of users don’t understand something and just don’t use it. Asking these questions helps me see what complications users struggle with, things I never really gave much thought to before.
Hey @Satoer thanks for creating such a great app!
I was just wondering whether the documentation has been taken down, or if you’re currently updating it and that’s why the pages aren’t working.
Nevermind, it works now.
No idea, probably just an outage with the host. But you can view the full documentation also in the app itself (It comes with the app, so it’s not dependent on the online host.):
NEW TEST Version Dashboard Studio v2.4.0/1
Overview
New
  • Countdown Formula Function
  • Countdown Animations, Color Morphing, and Smooth Movement
  • Duration and Time String Math in Formulas
  • Dashboard Regional and Localization Settings
  • Custom Block Callout Colors
  • Interactive Countdown and Mission Control Demo Page
  • Formula 1 Race Tracker and Countdown Help Guides
Improved
  • Empty Bound Topic Warnings and Binding Options Clarity
  • Unified Widget Language, Time, and Date Inheritance
Fixed
  • Responsive Columns Layout on Hidden Widgets
  • Graph Legend Stacking Order
Animations and Countdowns
Okay, this is a great new feature that looks simple at first glance, because it is just a new formula option. It started with exploring how I could bring countdowns to every widget, and the cleanest way was to build it straight into the formula engine. You no longer need to build timer-calculation flows inside Homey just to show a running countdown. You can simply put a date (or duration) into a formula, and it automatically counts down to it in multiple formats. You can even trigger dashboard changes when the countdown finishes, such as showing alerts, switching colors, or hiding widgets.
Building that also opened up a lot of other possibilities that I added along the way, like animations! By attaching timers to values, you can now animate all kinds of properties: move a widget’s X or Y position over a set number of seconds, smoothly morph between colors, create looping or ping-pong animations, apply easing curves (ease-in, ease-out, bounce, etc.), and more.
There are a lot of options, so don’t get intimidated by the long list of possibilities. Also the large list of examples makes this quite a large topic in the documentation. The basic syntax is quite simple, and I have linked the relevant help sections below. I do consider binding formulas a bit of an advanced feature, so please get familiar with the basics of Dashboard Studio before diving into animations.
I have made a demo on the demo page
Integrating these timer functions sadly opened up a whole can of worms, because every region seems to have its own set of date and time rules. That forced me to build a global Regional & Localization section in the main Dashboard Settings. Here you can configure your Language / Locale (with 13 built-in languages), Time Format (Auto, 24-Hour, or 12-Hour), Date Format (Auto, DD-MM-YYYY, MM-DD-YYYY, or YYYY-MM-DD), and First Day of Week (Auto, Monday, or Sunday). If your language is not included, you can even create and save your own custom translations for countdown units, AM/PM labels, weekdays, and months.
Note that these settings only apply to your dashboards and widgets (such as countdowns, Clock, Text calendars, List, and Graph) - the main editor interface itself stays in English.
Another easy trick: any modern AI is really good at writing these formulas once it knows the syntax. Just copy the “Binding Options & Payload Formulas” page from the in-app help (if you hover over the title, a copy button appears), paste it into your AI chat, and ask it to build the formula you want.
Use countdown() in bindings and inline {{countdown(...)}} Text widget Markdown to build real-time timers, progress percentages, and completion triggers (isDone, isRunning) from durations, clock strings, dates, or timestamps across 15 format options, powered by a demand-driven 1-second background heartbeat that ticks only active-page widgets with running timers.
Animate numbers, colors, and widget positions over time using countdown(). Supports numeric countdowns and ranges (such as countdown('30s', 100) or countdown('1m', 60, 150)), 2- and 3-color gradient morphing (#hex, @theme tokens, rgb() / rgba()), easing curves (linear, ease, ease-in, ease-out, ease-in-out, bounce), repeat modes (once, loop, pingpong), discrete steps(n) quantization, and smooth 1-second linear position transitions when bound to a widget’s X or Y coordinates in View mode.
Payload formulas automatically convert duration and clock strings (such as 2m 30s or 01:30) into seconds so you can compare timers against thresholds or use them in calculations.
Added a Regional & Localization section in Master Settings with Language / Locale (13 built-in languages plus custom translation presets), Time Format (Auto, 24-Hour, 12-Hour), Date Format (Auto, DD-MM-YYYY, MM-DD-YYYY, YYYY-MM-DD), and First Day of Week (Auto, Monday, Sunday), along with a Custom Translation Dialog featuring segmented navigation, JSON import/export, and saved presets for duration units, clock indicators, weekdays, and months.
Give a Text callout any theme color or hex code with [block @danger:Alarm] or [block #e11d48:Heat]. Block 1 through Block 4 still use their colors from the Markdown settings.
Added Page 19 to the built-in demo dashboard showcasing all countdown() output formats, interactive timer buttons, live progress sliders and gauges, an animated Mission Control launch sequence, and cosmic event countdowns.
Added a Formula 1 Race Tracker Tips & Tricks guide, added a complete countdown() reference to Binding Options & Payload Formulas, and updated the Timed Countdown Button guide around countdown() and additional output topics.
Improved
Empty msg.topic dropdowns now display a clear amber reminder to pick a topic or unlink, and the Binding Options popup shows a top status banner indicating the bound topic (or explaining how Value and Insert Topic work when no topic is selected), alongside clearer Default Value and Payload Formula guidance.
Consolidated the Clock widget’s flip and text language selectors into a single Language / Locale setting (Auto by default), and added Auto (from Dashboard) and YYYY-MM-DD options across Clock, Text Calendar, List, and Graph widgets so they automatically follow your dashboard’s Regional & Localization settings (with automatic migration for older dashboards).
Fixed
Hiding a widget or group in Responsive Columns mode now immediately rearranges the layout to close empty column gaps without requiring a window resize.
Canvas graph legends now match their graph widget’s own Z-index layer instead of using a fixed z-index: 20, preventing legends from painting over widgets or other graphs placed above them.
I have added an example in the tips section.
This is fixed.
I have not found the source of this problem. Can you tell me what P1 meter you are using (brand / type)
You can now create callouts with any color.
You now can do these timeouts inside dashboard studio. No need for Homey logic anymore.
I have created an full F1 countdown tip based on these new countdown formula logic.
I can’t wait to try out all these new features. I wish a day had 48 hours :slight_smile:. Once again great job.
Working on something in regards to F1. Live view of the active F1 session
Hey guys, if you submit a crash report, please also drop a message here so I know who it’s from, since crash reports are anonymous.
To the user with 70+ battery devices (sending the battery_status / weather_forecast / now_playing updates): your app ran out of memory while changing a large number of capability checkboxes in the app Settings at once. Please check if version 2.4.1 fixes this for you, as Settings changes are now grouped together instead of re-syncing everything on every single click. If it still happens, try pausing a moment between large batches of capability changes and let me know!
Impressive update, this sounds promising. Gonna take a while to figure out how to make use of this - besides dropping my popup-window timer. Seems like you have transformed your can of worms to a can of possibilities - great work!
Lots of new options again, great!
Using the demo dashboard (page 19) as a guide, I’m exploring how the countdown feature works with animations.
For the rocket animation (and other animations as well), I initially only see a hardcoded Y-value.
It’s only after clicking the link icon that the “payload formula” option becomes visible.
Fortunately, the documentation provided the necessary clarification.
However, I’m still wondering exactly when an animation is triggered.
For testing purposes, I’ve applied the following formula to the X-value of an image: countdown("10s", 1000, 2000, "ease-out").
When I open the page containing the image, after restarting the dashboard, there is no movement. Switching to edit mode doesn’t trigger anything either. However, if I click on the image, it immediately jumps to the animation’s end point (testing on Windows 11 PC).
EDIT:
Ever since the introduction of the useful help tooltips, the tooltips for selecting variable names from a dropdown menu in the configuration screen are no longer displayed. Currently only the first part of the variable name is visible, which makes it difficult to select the correct one, especially in the case of binding variables.
@Satoer just to say a big thank you for your awesome work and app. Family acceptance factor has gone up considerably. I’ve spent the weekend building a one page dashboard, nothing fancy at all, and perhaps a bit way too cluttered, but I’ll work on it.
Thought I would share it here :hugs:
As well as a clock screensaver that comes in after 1min of inactivity.
Some beers will come your way!
Oh nice. That’s a really well-designed dashboard. I like the clock screen too. How did you put that in? I’m assuming this is just the “Startup Landing Page”? But how do you get to the settings page? Did you put a big invisible button over the whole screen to go there?
I’d love to add dashboards like this to the gallery on the website. But I’d really like to see some pictures of it in use. Is it mounted on a wall or something? Would you want to share a real photo of it? No pressure at all of course.
Thanks for the beers that are coming. Really appreciate that! :clinking_beer_mugs: :slightly_smiling_face:
Dashboard Studio 2.3.5 – Homey Logic variables and device status updates missing
Environment: Homey Self-Hosted Server on Synology NAS, Dashboard Studio 2.3.5, HOMEY driver.
Problem
Dashboard Studio can send commands to Homey, but Homey Logic variables are no longer available as data sources and device status feedback is not updating correctly.
Example: nKlimaatWoonkamerSetpoint exists and updates correctly in Homey, but is missing from Dashboard Studio.
Diagnostics
  • HOMEY driver: Connected
  • Bound topics: 168
  • Receiving data: 10
  • Waiting for data: 158
  • Topics in bus memory: 22
  • Ghost topics: 12
  • Total ingested messages: 61, unchanged during a Logic variable test
  • Socket.IO WebSocket: connected (HTTP 101)
  • request_state_sync and state_snapshot observed
  • Snapshot contains 11 values, mainly HMI command topics such as .set
  • Diagnostic report: 7742f58b-439f-4087-8ac9-05dda5c812ca
Already attempted
Repeated app and server restarts, browser reloads, incognito session, and changing State Caching from Full to Disabled. No improvement.
Question
Could you investigate why Dashboard Studio no longer discovers or registers Homey Logic variables and why most device status topics receive no updates?
Is there a safe way to rebuild the internal Homey capability/variable registration without losing app settings, selected capabilities, or dashboard designs?
A summary so I understand this correctly: Basically self-hosted Homey isn’t sending device capability values and Logic Variable Values to Dashboard Studio anymore since you moved to 2.3.5? Was it all working fine before that version?
Can you please check if all capabilities or variables are still checked.
There’s a backup function in the app settings. This saves all the Homey settings part of the Dashboard Studio app. It doesn’t save uploaded images, custom templates, or dashboards you created in Dashboard Studio, so you’d need to export those. After that, you could delete and reinstall Dashboard Studio and put the backup back. But this hasn’t been thoroughly tested, although I haven’t received reports of problems. I wouldn’t advise doing it though. I’d rather just have this problem fixed. I already fixed a couple of problems based on reported anonymous crash logs. Can you try installing the test version to see if that fixed the problem?
Dashboard Studio continued to work correctly after updating to version 2.3.5, including device status updates and Homey Logic variables.
At some point afterwards, these stopped working, but I don’t know exactly when or what triggered it.
Commands from Dashboard Studio to Homey still work correctly. The problem is with receiving status updates and making Homey Logic variables available in Dashboard Studio.
So there is no confirmed connection between the update to 2.3.5 and the problem.
I have edited my original reply with some extra questions. Can you also install the test version to see if this improves things?
Yes they all checked, unchecking and rechecking them doesn’t help. I installed the test version but this does not help either. I might try reinstalling dashboard if nothing else come up. Thanks for doing a great job with Dashboard Studio, I have a great home dashboard and it’s growing every day. Unfortunately it “suddenly” stopped working correctly. It stops updating value’s sometimes but after a while it starts working again, now it isn’t.
No problem, I hope I can get this solved. I don’t have Home SHS so I can not test these problems. Please do not reinstall everyting just yet. Let me first investigate the problem and try to solve this with an update. So it is intermittent. Sometimes it works sometimes it doesn’t without doing anything.
