[APP][Pro] Dashboard Studio - A completely free-form dashboard designer
This is still a bug that should not happen. As I understand there where binding options attached to the graph data and these where not migrated?
Full graph using DS graph object (no SVG).
To be clear: You are generating this graph data with one of these cards right?:
And not a custom homeyscript.
Can you also check if the time is correct for streaming values? (put some kind of sensor in a new graph and set it to hour, minute,sec)
The last record contains time 2026-11-04T18:47:00.000Z which is 19:47:00 CET winter time
But the actual time is 18:47
Data from this test flow variabele “Test tekst” (graph using the DS card, not the Logic card data):
[{"t":"2026-11-04T17:47:00.000Z","v":675},{"t":"2026-11-04T17:47:15.062Z","v":676},{"t":"2026-11-04T17:47:30.125Z","v":678},{"t":"2026-11-04T17:47:45.188Z","v":679},{"t":"2026-11-04T17:48:00.251Z","v":681},{"t":"2026-11-04T17:48:15.313Z","v":680},{"t":"2026-11-04T17:48:30.376Z","v":684},{"t":"2026-11-04T17:48:45.439Z","v":687},{"t":"2026-11-04T17:49:00.502Z","v":686},{"t":"2026-11-04T17:49:15.564Z","v":684},{"t":"2026-11-04T17:49:30.627Z","v":686},{"t":"2026-11-04T17:49:45.690Z","v":687},{"t":"2026-11-04T17:50:00.753Z","v":685},{"t":"2026-11-04T17:50:15.815Z","v":685},{"t":"2026-11-04T17:50:30.878Z","v":690},{"t":"2026-11-04T17:50:45.941Z","v":689},{"t":"2026-11-04T17:51:01.004Z","v":689},{"t":"2026-11-04T17:51:16.066Z","v":688},{"t":"2026-11-04T17:51:31.129Z","v":690},{"t":"2026-11-04T17:51:46.192Z","v":689},{"t":"2026-11-04T17:52:01.255Z","v":688},{"t":"2026-11-04T17:52:16.317Z","v":687},{"t":"2026-11-04T17:52:31.380Z","v":685},{"t":"2026-11-04T17:52:46.443Z","v":687},{"t":"2026-11-04T17:53:01.506Z","v":686},{"t":"2026-11-04T17:53:16.569Z","v":686},{"t":"2026-11-04T17:53:31.631Z","v":689},{"t":"2026-11-04T17:53:46.694Z","v":688},{"t":"2026-11-04T17:54:01.757Z","v":687},{"t":"2026-11-04T17:54:16.820Z","v":692},{"t":"2026-11-04T17:54:31.882Z","v":692},{"t":"2026-11-04T17:54:46.945Z","v":694},{"t":"2026-11-04T17:55:02.008Z","v":693},{"t":"2026-11-04T17:55:17.071Z","v":693},{"t":"2026-11-04T17:55:32.133Z","v":694},{"t":"2026-11-04T17:55:47.196Z","v":698},{"t":"2026-11-04T17:56:02.259Z","v":697},{"t":"2026-11-04T17:56:17.322Z","v":696},{"t":"2026-11-04T17:56:32.384Z","v":694},{"t":"2026-11-04T17:56:47.447Z","v":695},{"t":"2026-11-04T17:57:02.510Z","v":698},{"t":"2026-11-04T17:57:17.573Z","v":697},{"t":"2026-11-04T17:57:32.635Z","v":696},{"t":"2026-11-04T17:57:47.698Z","v":695},{"t":"2026-11-04T17:58:02.761Z","v":699},{"t":"2026-11-04T17:58:17.824Z","v":694},{"t":"2026-11-04T17:58:32.887Z","v":692},{"t":"2026-11-04T17:58:47.949Z","v":690},{"t":"2026-11-04T17:59:03.012Z","v":690},{"t":"2026-11-04T17:59:18.075Z","v":691},{"t":"2026-11-04T17:59:33.138Z","v":688},{"t":"2026-11-04T17:59:48.200Z","v":686},{"t":"2026-11-04T18:00:03.263Z","v":688},{"t":"2026-11-04T18:00:18.326Z","v":688},{"t":"2026-11-04T18:00:33.389Z","v":687},{"t":"2026-11-04T18:00:48.451Z","v":690},{"t":"2026-11-04T18:01:03.514Z","v":688},{"t":"2026-11-04T18:01:18.577Z","v":689},{"t":"2026-11-04T18:01:33.640Z","v":693},{"t":"2026-11-04T18:01:48.702Z","v":690},{"t":"2026-11-04T18:02:03.765Z","v":692},{"t":"2026-11-04T18:02:18.828Z","v":692},{"t":"2026-11-04T18:02:33.891Z","v":691},{"t":"2026-11-04T18:02:48.953Z","v":692},{"t":"2026-11-04T18:03:04.016Z","v":694},{"t":"2026-11-04T18:03:19.079Z","v":693},{"t":"2026-11-04T18:03:34.142Z","v":693},{"t":"2026-11-04T18:03:49.205Z","v":693},{"t":"2026-11-04T18:04:04.267Z","v":691},{"t":"2026-11-04T18:04:19.330Z","v":694},{"t":"2026-11-04T18:04:34.393Z","v":692},{"t":"2026-11-04T18:04:49.456Z","v":691},{"t":"2026-11-04T18:05:04.518Z","v":689},{"t":"2026-11-04T18:05:19.581Z","v":687},{"t":"2026-11-04T18:05:34.644Z","v":689},{"t":"2026-11-04T18:05:49.707Z","v":689},{"t":"2026-11-04T18:06:04.769Z","v":689},{"t":"2026-11-04T18:06:19.832Z","v":689},{"t":"2026-11-04T18:06:34.895Z","v":688},{"t":"2026-11-04T18:06:49.958Z","v":692},{"t":"2026-11-04T18:07:05.020Z","v":694},{"t":"2026-11-04T18:07:20.083Z","v":693},{"t":"2026-11-04T18:07:35.146Z","v":691},{"t":"2026-11-04T18:07:50.209Z","v":693},{"t":"2026-11-04T18:08:05.271Z","v":695},{"t":"2026-11-04T18:08:20.334Z","v":697},{"t":"2026-11-04T18:08:35.397Z","v":698},{"t":"2026-11-04T18:08:50.460Z","v":700},{"t":"2026-11-04T18:09:05.523Z","v":698},{"t":"2026-11-04T18:09:20.585Z","v":701},{"t":"2026-11-04T18:09:35.648Z","v":704},{"t":"2026-11-04T18:09:50.711Z","v":704},{"t":"2026-11-04T18:10:05.774Z","v":705},{"t":"2026-11-04T18:10:20.836Z","v":707},{"t":"2026-11-04T18:10:35.899Z","v":711},{"t":"2026-11-04T18:10:50.962Z","v":713},{"t":"2026-11-04T18:11:06.025Z","v":715},{"t":"2026-11-04T18:11:21.087Z","v":715},{"t":"2026-11-04T18:11:36.150Z","v":716},{"t":"2026-11-04T18:11:51.213Z","v":716},{"t":"2026-11-04T18:12:06.276Z","v":714},{"t":"2026-11-04T18:12:21.338Z","v":717},{"t":"2026-11-04T18:12:36.401Z","v":723},{"t":"2026-11-04T18:12:51.464Z","v":723},{"t":"2026-11-04T18:13:06.527Z","v":723},{"t":"2026-11-04T18:13:21.589Z","v":721},{"t":"2026-11-04T18:13:36.652Z","v":720},{"t":"2026-11-04T18:13:51.715Z","v":720},{"t":"2026-11-04T18:14:06.778Z","v":721},{"t":"2026-11-04T18:14:21.841Z","v":719},{"t":"2026-11-04T18:14:36.903Z","v":721},{"t":"2026-11-04T18:14:51.966Z","v":721},{"t":"2026-11-04T18:15:07.029Z","v":723},{"t":"2026-11-04T18:15:22.092Z","v":723},{"t":"2026-11-04T18:15:37.154Z","v":724},{"t":"2026-11-04T18:15:52.217Z","v":717},{"t":"2026-11-04T18:16:07.280Z","v":716},{"t":"2026-11-04T18:16:22.343Z","v":714},{"t":"2026-11-04T18:16:37.405Z","v":710},{"t":"2026-11-04T18:16:52.468Z","v":710},{"t":"2026-11-04T18:17:07.531Z","v":714},{"t":"2026-11-04T18:17:22.594Z","v":714},{"t":"2026-11-04T18:17:37.656Z","v":715},{"t":"2026-11-04T18:17:52.719Z","v":716},{"t":"2026-11-04T18:18:07.782Z","v":716},{"t":"2026-11-04T18:18:22.845Z","v":717},{"t":"2026-11-04T18:18:37.907Z","v":718},{"t":"2026-11-04T18:18:52.970Z","v":718},{"t":"2026-11-04T18:19:08.033Z","v":719},{"t":"2026-11-04T18:19:23.096Z","v":721},{"t":"2026-11-04T18:19:38.158Z","v":721},{"t":"2026-11-04T18:19:53.221Z","v":722},{"t":"2026-11-04T18:20:08.284Z","v":720},{"t":"2026-11-04T18:20:23.347Z","v":720},{"t":"2026-11-04T18:20:38.410Z","v":724},{"t":"2026-11-04T18:20:53.472Z","v":724},{"t":"2026-11-04T18:21:08.535Z","v":722},{"t":"2026-11-04T18:21:23.598Z","v":725},{"t":"2026-11-04T18:21:38.661Z","v":726},{"t":"2026-11-04T18:21:53.723Z","v":730},{"t":"2026-11-04T18:22:08.786Z","v":730},{"t":"2026-11-04T18:22:23.849Z","v":730},{"t":"2026-11-04T18:22:38.912Z","v":730},{"t":"2026-11-04T18:22:53.974Z","v":732},{"t":"2026-11-04T18:23:09.037Z","v":729},{"t":"2026-11-04T18:23:24.100Z","v":730},{"t":"2026-11-04T18:23:39.163Z","v":733},{"t":"2026-11-04T18:23:54.225Z","v":733},{"t":"2026-11-04T18:24:09.288Z","v":733},{"t":"2026-11-04T18:24:24.351Z","v":733},{"t":"2026-11-04T18:24:39.414Z","v":734},{"t":"2026-11-04T18:24:54.476Z","v":732},{"t":"2026-11-04T18:25:09.539Z","v":734},{"t":"2026-11-04T18:25:24.602Z","v":733},{"t":"2026-11-04T18:25:39.665Z","v":735},{"t":"2026-11-04T18:25:54.728Z","v":736},{"t":"2026-11-04T18:26:09.790Z","v":737},{"t":"2026-11-04T18:26:24.853Z","v":739},{"t":"2026-11-04T18:26:39.916Z","v":738},{"t":"2026-11-04T18:26:54.979Z","v":734},{"t":"2026-11-04T18:27:10.041Z","v":731},{"t":"2026-11-04T18:27:25.104Z","v":733},{"t":"2026-11-04T18:27:40.167Z","v":735},{"t":"2026-11-04T18:27:55.230Z","v":736},{"t":"2026-11-04T18:28:10.292Z","v":735},{"t":"2026-11-04T18:28:25.355Z","v":735},{"t":"2026-11-04T18:28:40.418Z","v":736},{"t":"2026-11-04T18:28:55.481Z","v":736},{"t":"2026-11-04T18:29:10.543Z","v":735},{"t":"2026-11-04T18:29:25.606Z","v":738},{"t":"2026-11-04T18:29:40.669Z","v":740},{"t":"2026-11-04T18:29:55.732Z","v":735},{"t":"2026-11-04T18:30:10.794Z","v":735},{"t":"2026-11-04T18:30:25.857Z","v":732},{"t":"2026-11-04T18:30:40.920Z","v":733},{"t":"2026-11-04T18:30:55.983Z","v":735},{"t":"2026-11-04T18:31:11.046Z","v":731},{"t":"2026-11-04T18:31:26.108Z","v":732},{"t":"2026-11-04T18:31:41.171Z","v":731},{"t":"2026-11-04T18:31:56.234Z","v":732},{"t":"2026-11-04T18:32:11.297Z","v":732},{"t":"2026-11-04T18:32:26.359Z","v":731},{"t":"2026-11-04T18:32:41.422Z","v":730},{"t":"2026-11-04T18:32:56.485Z","v":733},{"t":"2026-11-04T18:33:11.548Z","v":734},{"t":"2026-11-04T18:33:26.610Z","v":731},{"t":"2026-11-04T18:33:41.673Z","v":734},{"t":"2026-11-04T18:33:56.736Z","v":736},{"t":"2026-11-04T18:34:11.799Z","v":736},{"t":"2026-11-04T18:34:26.861Z","v":738},{"t":"2026-11-04T18:34:41.924Z","v":742},{"t":"2026-11-04T18:34:56.987Z","v":741},{"t":"2026-11-04T18:35:12.050Z","v":743},{"t":"2026-11-04T18:35:27.112Z","v":744},{"t":"2026-11-04T18:35:42.175Z","v":747},{"t":"2026-11-04T18:35:57.238Z","v":748},{"t":"2026-11-04T18:36:12.301Z","v":748},{"t":"2026-11-04T18:36:27.364Z","v":751},{"t":"2026-11-04T18:36:42.426Z","v":754},{"t":"2026-11-04T18:36:57.489Z","v":755},{"t":"2026-11-04T18:37:12.552Z","v":753},{"t":"2026-11-04T18:37:27.615Z","v":753},{"t":"2026-11-04T18:37:42.677Z","v":752},{"t":"2026-11-04T18:37:57.740Z","v":755},{"t":"2026-11-04T18:38:12.803Z","v":753},{"t":"2026-11-04T18:38:27.866Z","v":752},{"t":"2026-11-04T18:38:42.928Z","v":752},{"t":"2026-11-04T18:38:57.991Z","v":753},{"t":"2026-11-04T18:39:13.054Z","v":756},{"t":"2026-11-04T18:39:28.117Z","v":757},{"t":"2026-11-04T18:39:43.179Z","v":753},{"t":"2026-11-04T18:39:58.242Z","v":753},{"t":"2026-11-04T18:40:13.305Z","v":753},{"t":"2026-11-04T18:40:28.368Z","v":753},{"t":"2026-11-04T18:40:43.430Z","v":758},{"t":"2026-11-04T18:40:58.493Z","v":758},{"t":"2026-11-04T18:41:13.556Z","v":761},{"t":"2026-11-04T18:41:28.619Z","v":758},{"t":"2026-11-04T18:41:43.682Z","v":757},{"t":"2026-11-04T18:41:58.744Z","v":759},{"t":"2026-11-04T18:42:13.807Z","v":756},{"t":"2026-11-04T18:42:28.870Z","v":760},{"t":"2026-11-04T18:42:43.933Z","v":757},{"t":"2026-11-04T18:42:58.995Z","v":757},{"t":"2026-11-04T18:43:14.058Z","v":757},{"t":"2026-11-04T18:43:29.121Z","v":759},{"t":"2026-11-04T18:43:44.184Z","v":760},{"t":"2026-11-04T18:43:59.246Z","v":759},{"t":"2026-11-04T18:44:14.309Z","v":760},{"t":"2026-11-04T18:44:29.372Z","v":761},{"t":"2026-11-04T18:44:44.435Z","v":762},{"t":"2026-11-04T18:44:59.497Z","v":762},{"t":"2026-11-04T18:45:14.560Z","v":761},{"t":"2026-11-04T18:45:29.623Z","v":762},{"t":"2026-11-04T18:45:44.686Z","v":765},{"t":"2026-11-04T18:45:59.748Z","v":762},{"t":"2026-11-04T18:46:14.811Z","v":761},{"t":"2026-11-04T18:46:29.874Z","v":763},{"t":"2026-11-04T18:46:44.937Z","v":761},{"t":"2026-11-04T18:47:00.000Z","v":763}]
The streaming graph shows the correct time.
Graph snippet:
  "snippetHeader": "Dashboard Studio Snippet",
  "snippetType": "widget-snippet",
  "snippetFormatVersion": 1,
  "version": "2.3.2",
  "source": {
    "dashboardName": "HomeDashV260",
    "page": 60,
    "createdAt": "2026-11-04T18:00:36.361Z"
  "master": {
    "currentPage": 60
  "widgets": {
    "graph_315741411": {
      "type": "graph",
      "overrides": {
        "x": 270,
        "y": 340,
        "width": 2290,
        "height": 1260,
        "zIndex": 20,
        "page": "60",
        "label": "Stroomnet saldo afgelopen uur",
        "typography": {
          "widgetLabel": {
            "fontFamily": "'Exo 2', sans-serif",
            "fontSize": 50,
            "color": "@text"
          "axisX": {
            "fontSize": 35,
            "color": "@text"
          "pointValues": {
            "fontSize": 35,
            "color": "@text",
            "textAlign": "center",
            "offsetX": 0,
            "offsetY": 0
          "pointValuesBar": {
            "fontSize": 20,
            "offsetY": 0
        "metaName": "Live stroomverbruik",
        "showAxisX": true,
        "showAxisY": true,
        "timeFormat": "HH:mm",
        "headroom": 5,
        "roundingMode": "smart",
        "timezoneConvert": false,
        "gridHTopShow": false,
        "gridHTopW": 2,
        "gridHTopOp": 100,
        "gridHTopCol": "@text",
        "gridHBaseShow": true,
        "gridHBaseCol": "@text",
        "gridHBaseOp": 100,
        "gridHInnerShow": true,
        "showTickX": true,
        "showTickY": false,
        "tickXColor": "@text",
        "tickXThickness": 3,
        "tickXSize": 10,
        "tickXSpacing": 0,
        "showPointValues": true,
        "pointValuesHoverOnly": true,
        "pointValuesAbbreviate": false,
        "axisOffY": 10,
        "axisOffX": 10,
        "axisWidthX": 0,
        "decimals": 1,
        "showPoints": false,
        "type": "bar",
        "useBaseline": true,
        "smoothingAmount": 80,
        "baselineVal": 0,
        "scrollDir": "left",
        "time24h": true,
        "axisWidthY": 0,
        "axisResX": 20,
        "axisResY": 10,
        "gridHBaseW": 2,
        "gridHBotShow": true,
        "gridHInnerCol": "@surface",
        "gridVLeftShow": true,
        "gridVLeftCol": "@text",
        "gridVRightShow": false,
        "gridVLeftOp": 100,
        "gridHInnerSpace": 0,
        "gridVSpace": 0,
        "maxPoints": 240,
        "tickXOffset": 0,
        "gridHBotCol": "#FFFFFF",
        "gridHBotW": 2,
        "gridHBotOp": 100,
        "gridVShow": false,
        "pointValuesDecimals": 0,
        "graphOffY": 0,
        "padding": 10,
        "tickYSize": 10,
        "tickYThickness": 3,
        "tickYColor": "@text",
        "barGap": 4,
        "barRadius": 0,
        "barOutlineWidth": 0,
        "container": {
          "show": true,
          "background": {
            "startColor": "#0A3575",
            "startOpacity": 20,
            "endColor": "#424242",
            "endOpacity": 20,
            "blur": 20
          "glow": {
            "enabled": true,
            "color": "#000000",
            "radius": 80,
            "opacity": 100
          "border": {
            "color": "@background",
            "width": 3,
            "opacity": 30,
            "cornerRadius": 40
        "series": [
            "id": "s_1",
            "name": "Qingping Air Monitor 2 Measure Co2 (Co2)",
            "nameLocked": false,
            "visible": true,
            "data": "",
            "positiveStartOpacity": 25,
            "positiveEndOpacity": 0,
            "negativeStartOpacity": 25,
            "negativeEndOpacity": 0,
            "positiveColor": "#FF0000",
            "negativeColor": "#57F104",
            "positiveFillColor": "@danger",
            "negativeFillColor": "#57F104",
            "pointColor": "#60a5fa",
            "lineWidth": 3,
            "positiveOutlineColor": "#FF0000",
            "negativeOutlineColor": "#57F104"
        "showLegend": false,
        "bufferMode": "duration",
        "durationPreset": "1h",
        "fixedTimeWindow": true,
        "timelineAdvance": "data",
        "dynamicFloor": true,
        "autoAxisResX": true,
        "autoAxisResY": false,
        "graphAnimation": "morph",
        "graphAnimShimmer": false,
        "graphAnimStaggerBars": false,
        "dynamicCeiling": true,
        "barDirection": "vertical"
      "bindings": {
        "series": [
            "data": "homey/insight/Qingping Air Monitor 2 - measure_co2 (Co2)"
Michel, it seems the frozen display issue is present again in the latest release. The image from my intercom camera is not moving since the update… :thinking::smiling_face_with_tear:
cdt,
G.IEGER
Envoyé de mon smartphone
Maybe (I’m not a developer…), it became very complex because the data points are set on a widget level, not a graph level. So, when the interval (actually, the outcome of the setting is unclear; trial&error) can be set on a graph level (for every graph in the widget), it’s probably less complex and the end user can decide what fits best per graph (e.g 1 graph interval is 1 (every data point) and another graph interval is 3). Same for data point color: not set on a widget, but per graph in the widget. I don’t know if it’s possible from a technical point of few, it’s just a suggestion.
Yes, but not 100% sure (and I don’t know if it’s possible to reproduce).
FYI: it’s not a general issue, in my system time (MacOS) is displayed correctly.
Any recommendations on how to implement a countdown to a certain date. I’m trying to build a dashboard with all the data provided by the F1 Tracker Pro app.
I don’t know if the F1 Tracker Pro app provides count down data. But you do not actually need a special app to get this data. A homeyscript can fetch this data and you can create any tag you would like with it. Add a homeyscript with this code:
 // Formula 1 Next Event Countdown & Info Tracker
 // Run every hour via Homey Flow
// 1. Fetch current season race schedule from Jolpica F1 API
const response = await fetch('https://api.jolpi.ca/ergast/f1/current.json');
if (!response.ok) {
  throw new Error(`Failed to fetch F1 calendar: ${response.statusText}`);
const data = await response.json();
const races = data.MRData.RaceTable.Races;
const now = new Date();
// Helper: parse date and time string to Date object
function parseSessionDate(dateStr, timeStr) {
  if (!dateStr) return null;
  const isoTime = timeStr ? (timeStr.endsWith('Z') ? timeStr : timeStr + 'Z') : '00:00:00Z';
  return new Date(`${dateStr}T${isoTime}`);
// Helper: format remaining time as days - hours
function formatCountdown(targetDate) {
  const diffMs = targetDate - now;
  if (diffMs <= 0) return 'Live / Finished';
  const totalHours = Math.floor(diffMs / (1000 * 60 * 60));
  const days = Math.floor(totalHours / 24);
  const hours = totalHours % 24;
  return `${days}d ${hours}h`;
// Helper: format local time readable string (e.g. "Sat 16:00")
function formatLocalTime(date) {
  if (!date) return 'N/A';
  return date.toLocaleString('en-GB', {
    weekday: 'short',
    day: 'numeric',
    month: 'short',
    hour: '2-digit',
    minute: '2-digit'
// 2. Find the upcoming/active race weekend
let nextRace = null;
for (const race of races) {
  const raceDate = parseSessionDate(race.date, race.time);
  // Include race weekend until 4 hours after race start
  if (raceDate && (raceDate.getTime() + 4 * 60 * 60 * 1000) > now.getTime()) {
    nextRace = race;
    break;
if (!nextRace) {
  await tag('F1info-SeasonStatus', 'Season Ended');
  return 'No upcoming races found for the current season.';
// 3. Extract all available sessions for this GP
const sessions = [];
function registerSession(key, label, dateStr, timeStr) {
  const dateObj = parseSessionDate(dateStr, timeStr);
  if (dateObj) {
    sessions.push({ key, label, date: dateObj });
registerSession('FP1', 'Practice 1', nextRace.FirstPractice?.date, nextRace.FirstPractice?.time);
registerSession('FP2', 'Practice 2', nextRace.SecondPractice?.date, nextRace.SecondPractice?.time);
registerSession('FP3', 'Practice 3', nextRace.ThirdPractice?.date, nextRace.ThirdPractice?.time);
registerSession('SprintQuali', 'Sprint Qualifying', nextRace.SprintQualifying?.date, nextRace.SprintQualifying?.time);
registerSession('Sprint', 'Sprint Race', nextRace.Sprint?.date, nextRace.Sprint?.time);
registerSession('Quali', 'Qualifying', nextRace.Qualifying?.date, nextRace.Qualifying?.time);
registerSession('Race', 'Main Race', nextRace.date, nextRace.time);
// 4. Identify the very next immediate session on track
const futureSessions = sessions
  .filter(s => (s.date.getTime() + 2 * 60 * 60 * 1000) > now.getTime())
  .sort((a, b) => a.date - b.date);
const nextSession = futureSessions[0] || null;
// 5. Update Homey tags
// General GP Metadata
await tag('F1info-GPName', nextRace.raceName);
await tag('F1info-Circuit', nextRace.Circuit?.circuitName || 'Unknown');
await tag('F1info-Country', nextRace.Circuit?.Location?.country || 'Unknown');
await tag('F1info-Round', `Round ${nextRace.round}`);
// Next upcoming track session
if (nextSession) {
  await tag('F1info-NextSessionName', nextSession.label);
  await tag('F1info-NextSessionCountdown', formatCountdown(nextSession.date));
  await tag('F1info-NextSessionTime', formatLocalTime(nextSession.date));
} else {
  await tag('F1info-NextSessionName', 'None');
  await tag('F1info-NextSessionCountdown', 'Finished');
  await tag('F1info-NextSessionTime', 'N/A');
// Session-specific countdowns
for (const s of sessions) {
  await tag(`F1info-${s.key}Countdown`, formatCountdown(s.date));
  await tag(`F1info-${s.key}Time`, formatLocalTime(s.date));
return `F1 Tags updated for ${nextRace.raceName}`;
This generates the following tags (these are available in your flows):
Tag Name Example Value Description
F1info-GPName São Paulo Grand Prix Name of the Grand Prix
F1info-Circuit Autódromo José Carlos Pace Track name
F1info-Country Brazil Host country
F1info-Round Round 21 Championship round number
F1info-NextSessionName Practice 1 The immediate next session happening
F1info-NextSessionCountdown 1d 4h Time remaining until next track action
F1info-NextSessionTime Fri 6 Nov, 15:30 Local start time
F1info-RaceCountdown 3d 7h Countdown to Sunday’s Main Race
F1info-RaceTime Sun 8 Nov, 18:00 Race start time
F1info-QualiCountdown 2d 6h Countdown to Qualifying
F1info-SprintCountdown 2d 1h / N/A Countdown to Sprint (if sprint weekend)
F1info-FP1Countdown 1d 4h Countdown to Free Practice 1
F1info-FP2Countdown 1d 7h Countdown to Free Practice 2
F1info-FP3Countdown 2d 2h Countdown to Free Practice 3
You can find these tags when you click the tag icon in homey and search “f1info”:
Create a flow to send the tags you would like to use to Dashboard Studio:
(I named the topics f1-circuit, f1-country etc.)
In Dashboard studio you can display these values however you want. For example you can use a text widget and use this markdown:
## :ph-flag-checkered|28|@danger: [color @danger]**FORMULA 1**[/color]
### {{homey/event/f1-round}} · {{homey/event/f1-country}}
:ph-map-pin|16|@accentSecondary: *{{homey/event/f1-circuit}}*
[block1::ph-clock-countdown|18|@danger: **Race Start:** {{homey/event/f1-racetime}}]
| Session | Countdown |
| :ph-timer|16|@iconMuted: **Practice 1** | [color @accentSecondary]**{{homey/event/f1-fp1countdown}}**[/color] |
| :ph-timer|16|@iconMuted: **Practice 2** | [color @accentSecondary]**{{homey/event/f1-fp2countdown}}**[/color] |
| :ph-timer|16|@iconMuted: **Practice 3** | [color @accentSecondary]**{{homey/event/f1-fp3countdown}}**[/color] |
| :ph-stopwatch|16|@danger: **Qualifying** | [color @danger]**{{homey/event/f1-qualicountdown}}**[/color] |
| :ph-flag-checkered|16|@danger: **Grand Prix** | [color @danger]**{{homey/event/f1-racecountdown}}**[/color] |
Looks like this (depending on the theme)
I picked this method because it’s pretty versatile. It’s best to limit how often you fetch API data, so try to get all the data you want in a single fetch. Don’t do this every minute though, like if you want a countdown, or you’ll probably get rate limited. If you know exactly what you want, you could also just make a markdown file with HomeyScript and send the whole thing to the text widget.
Here is a good tutorial how to use AI to generate these scripts.
Note: I also used AI to generate above scripts
Note 2: I’ve seen a few people asking for a countdown timer. I might add it to the clock widget or maybe make a separate one. Any ideas are welcome, but remember it shouldn’t be for a specific use case. It should be universal for any countdown, like sending it a value to count down to or from, or sending it a date and time to count down to. Or maybe I should just make it a binding formula so you can use it anywhere.
Until now, I’ve always used a JSON card to display variables from an API call in Dashboard Studio.
I was curious about how these “tag variables” (like in F1 script) could be created and applied; they look quite powerful.
According to AI, however, there is a downside: these tag variables remain in memory. They persist even after restarting the Homey script app or rebooting the Homey device itself. The only way to clear them is by manually setting these tags to null using a separate Homey script.
What has your experience been with this?
That’s true. But running the script multiple times shouldn’t use more memory than running it once. Tags only become orphans if you delete the script, even after a reboot. Homey doesn’t check which tags are being used. I don’t think it’ll be a problem the way I used it, just a couple of short strings.
It would be a different story if you were filling it with massive svg tables though :sweat_smile:
You can delete old tags with a homeyscript like this:
await tag('F1info-Circut', null);
There is also another solution. You can send topics directly from homeyscript bypassing the tags completely:
const events = [
  { name: 'kitchen_status', value: 'Occupied' },
  { name: 'energy_warning', value: 'High Usage' }
for (const item of events) {
  await Homey.flow.runFlowCardAction({
    args: {
      value: String(item.value)
return true;
@Vincent_Ducate
If you want to do it like that, and send all values to Dashboard Studio topics directly, you can use this homeyscript:
//* Formula 1 Next Event Countdown & Info Tracker
//* Directly sends topics to Dashboard Studio via Homey Web API
// Helper: dispatch directly to Dashboard Studio (topic: homey/event/<name>)
async function sendTopic(name, value) {
    args: {
      value: String(value ?? '')
if (!response.ok) {
// Helper: parse date and time string to UTC Date object
  if (!targetDate) return 'N/A';
    weekday: 'short',
    day: 'numeric',
    month: 'short',
    hour: '2-digit',
    minute: '2-digit'
  // Keep race weekend active until 4 hours after race start
    nextRace = race;
    break;
if (!nextRace) {
  await sendTopic('f1-seasonstatus', 'Season Ended');
  return 'No upcoming races found.';
// 3. Extract all available sessions for this Grand Prix
  if (dateObj) {
registerSession('fp1', 'Practice 1', nextRace.FirstPractice?.date, nextRace.FirstPractice?.time);
registerSession('fp2', 'Practice 2', nextRace.SecondPractice?.date, nextRace.SecondPractice?.time);
registerSession('fp3', 'Practice 3', nextRace.ThirdPractice?.date, nextRace.ThirdPractice?.time);
registerSession('sprintquali', 'Sprint Qualifying', nextRace.SprintQualifying?.date, nextRace.SprintQualifying?.time);
registerSession('sprint', 'Sprint Race', nextRace.Sprint?.date, nextRace.Sprint?.time);
registerSession('quali', 'Qualifying', nextRace.Qualifying?.date, nextRace.Qualifying?.time);
registerSession('race', 'Grand Prix', nextRace.date, nextRace.time);
// 4. Identify the immediate next track session
// 5. Compile all topics
const topics = [
  { name: 'f1-gpname', value: nextRace.raceName },
  { name: 'f1-circuit', value: nextRace.Circuit?.circuitName || 'Unknown' },
  { name: 'f1-country', value: nextRace.Circuit?.Location?.country || 'Unknown' },
  { name: 'f1-round', value: `Round ${nextRace.round}` },
  { name: 'f1-nextsessionname', value: nextSession ? nextSession.label : 'None' },
  { name: 'f1-nextsessioncountdown', value: nextSession ? formatCountdown(nextSession.date) : 'Finished' },
  { name: 'f1-nextsessiontime', value: nextSession ? formatLocalTime(nextSession.date) : 'N/A' }
// Add countdown and local time for each registered session
  topics.push({ name: `f1-${s.key}countdown`, value: formatCountdown(s.date) });
  topics.push({ name: `f1-${s.key}time`, value: formatLocalTime(s.date) });
// 6. Send all topics sequentially to Dashboard Studio
for (const item of topics) {
  await sendTopic(item.name, item.value);
return `Successfully sent ${topics.length} F1 topics for ${nextRace.raceName}`;
Look in the data stream explorer what comes in:
Thx. I will give both methods a try.
Thank you.
I think I prefer this solution. After restarting the DS app, the variables are gone. A JSON map is no longer required following API calls within a script.
Are there any other DS card IDs that can be used in this way, and if so, how do I call them from a script?
I think a date and time to countdown to should be ok. A format like days - hrs - min -sec maybe.
You can basically use all flowcards inside a homey script. I will update the help file for you how to do that.
Hi Michel,
Sorry to keep bringing this up, but do you know when you’ll be releasing a new beta that includes the fix (probably the same one as last time) for refreshing the HTTP display?
I totally get that the current work on the graphics is more exciting…:grin:
Almost ready for release. I try to squash bugs as fast as I can, so that part’s already fixed. But if I’m in the middle of a bigger change, I have to finish that too before I can release it. :sweat_smile:
NEW TEST Release Dashboard Studio V2.3.3
New
  • Setting Tooltips: Added helpful hover explanations for all settings, toolbar buttons, and theme controls across the editor to explain what each option does at a glance. For the Dashboard Studio veterans who might find this annoying… you can disable this in the settings.
  • Graph Local Time & Manual Offset: Added options to convert chart timestamps to local time and apply minute offsets so timeline graphs match your clock accurately.
  • Freeze Live Values in Markdown: The Freeze Dynamic Values tool can now detect and convert live data placeholders and formulas inside Text widgets into fixed text.
Improved
  • Smooth Graph Timeline Scrolling: Real-time streaming charts now scroll more smoothly.
Fixed
  • Live Camera & Web Image Refresh: Resolved an issue where live camera (image refresh) streams and web images could stop refreshing or freeze on older frames.
  • Kiosk Graph Redraw Stability: Prevented unnecessary chart redraws during background display checks on wall-mounted kiosk screens.
This has been fixed
Now you can pick the method. Use time-based or point steps. That’s how it worked before, but it’s less usable for multiple graphs with different point distributions.
Can you check if the problem is fixed? I changed how it works. All values in Homey are stored in UTC. Before, I converted this to local time and then sent the corrected graph to the dashboard. Now I don’t convert it anymore. The graph is sent in native UTC, and it is up to the widget to convert it to local time. I also added an offset option where users can offset the time in minutes. Let me know if it shows the right time when the UTC convert option is enabled. It works in my testing.
Fixed :+1:
Sorry Michel,
But I have the same issue… The image is not refresh :flushed_face:
cdt,
G.IEGER
The demo with the refreshing image did work, but there was a problem with local video snapshots.
Try the latest 2.3.4 Should be working now :sweat_smile:
Great, this enhanced function did the job:
Not needed in my case, but shows the time offset as expected.
I like the new informative tooltips. The readability (contrast) of these with a dark dashboard could use some improvement.
