Thanks for the big update and also tagging older earlier requests as well! (Mine was from may this year).
I have not been very active lately in this topic, not so much time available to continue building my dashboard. But will definitely proceed soon and try out the improvements!
@Amersfoort@Jean_S I just released V3.3.1.
Hopefully this fixes the issues. I think the main problem was that data wasn’t caching correctly and wasn’t being received by the dashboards in certain circumstances. Also did some performance improvements in some widgets (image and graph) Let me know if the problem is resolved.
edit: I might have a usecase you missed ; I created this graph which shows in green my nett energyusage in green/red (P1 minus solar) and the actual solar in blue behind the first (made from 2 stacked graphs)
Maybe an option to ‘stack’ (bar)graphs (based on the order of the graphs)? Maybe that option is already there but I was not able to find it
And a small bug I think
I set this below graph to -1 value multiplier, but now the positive color is linked to negative values (graphpart below 0), but the negativeline color is also linked to negative values.
So with multiplier 0, positive colors are for positive values, negative for negative. But with a negative multiplier things get bit mixed up it seems
Nope it is not there. I actually stack two graphs together myself (but with different line thicknesses). Each has their own scale though, so it is not compatible anyway with a single graph with multiple data sources.
But I understand the user case, I shall add this feature.
Ah, I added the multiplier to fix values that were in kilos, for example. That way you can combine things like watts and kilowatts in the same graph. It never occurred to me that users could use this to invert values. I’ll fix this bug.
I think I fixed the performance problem in 2.3.1 (current release)
I can’t seem to recreate this. Can you be more specific about the problem? For example, when I open the demo page and press the “core telemetry” button, the telemetry dialog pops up like it should (which is a group teleported from another page). Also, if I make the “page(s)” setting of a widget dynamic and connect it to a button that outputs page numbers in its output settings, the widget gets teleported to the current and other pages.
Yeah, the chart widget was basically fully rewritten. I think I managed to migrate most (all?) the settings from the old graph though. In my testing I only ran into a couple alignment options that were only noticeable because I stacked several graphs on top of each other.
An additional test reveals that the “Hold to activate” option does not work when using Teleportation. However, I think it may also fail to work in other instances.
Test dash dash below: push button Lamp or long click button Lamp and nothing happens. Remove “Hold to activate” from the Lamp button, and click the button: the teleporting page group becomes visible.
EDIT: I have sent the test dashboard separately using your upload feature (file too big for this post).
The test dashboard works fine for me in Firefox and Chrome on desktop and Safari on iPhone. You’re using an image button, so are you sure you’re actually pressing and holding the image?
As long as combined graphs both have positive values only, it works. But when one of the graphs has positive values and the other negative, the negative values are no longer shown (the graph line disappears).
When showing the graph points values and the value of interval is 1 (default value), not all values are shown. When clicking on 1, I can change the value to 0,001 and in that case all values are shown.
When the dashboard is running in background (on Mac, Chrome), values of realtime data are grouping together (see middle of picture). When activating (selecting tab in browser), it’s running as expected again.
Nice to have: Rotation option for graph point values (like also available for axis values in this version).
The ‘show on hover’ function at point values is not always show the value of the pointed bar. In general, on the left side of the graph, the point value of the ‘hovered’ bar is shown correctly, but the more I move to the right side of the graph, the point value 1-5 bars right of the selected bar is shown. The behaviour manifested on a quarter-price (=96 bars) graph. Maybe I missed a setting or it is subject to improvement (I can’t send screenshots, as the cursor disappears when taking).
Nice to have: The colour of point values is same in all stacked graphs, where lines and fills can be set per graph. It should be nice when point values colours can be set per graph.
Yeah, I had to change it to a grid system. Basically, the interval is now the grid size. Each column in the grid has one value. I needed to change this because you can mix different graphs together. Some have a ton of points and others have very few. I had to spread the values out better because the graphs with lots of points were covering everything else up. So I built a grid distribution system. In each column, each graph gets a value. I also try to shift them horizontally so they don’t sit right on top of each other, while still aiming for the high and low spots. I also had to anchor it to the streaming values, otherwise it would flicker constantly. Anyway, it’s a lot of complicated math, but that’s the reason why 1 is not 1 per point. (and that’s why I allowed it to go to 0.001)
Is this a single point? Or are there two points on approx the same time? (looks like it)
The frequency the value points shown differ. Is that expected behaviour? When I put interval to 0.01 (or 0.001) all value points are shown. So, I don’t understand how it works and how to set the frequency (every bar, every two bars, etc.) right.
It was set to ‘Show as negative’. Correct choice?
It was set to Dynamic floor (enabled). Should work?
I will try this (but have to wait till tomorrow to test):
The graph is basically split into sections. It looks for the high and low spots in each section and moves the values there within a certain tolerance. Lowering the interval makes the sections narrower, so you get more values. 0,001 probably sets a value on each node. I did it this way to get an even spread when combining high and low resolution graphs.
But maybe I need to rethink this strategy
No, it should be set to dynamic. I’m not sure what setting I missed that’s hiding the negative values. Can you do this for me:
Wait until there are negative values in the graph
Press the tools menu (hammer) and “Make all dynamic values fixed”
This is solved. The calculation of the data points was removed after the DS update, so it was only showing the grid power (0 is minimum, otherwise it’s returned power). I didn’t check, sorry for that.
I think the gesture control is a good idea. It works in most cases, but not when swiping over buttons or over Markdown tables that have a vertical scrollbar. Interestingly, a horizontal swipe does work for tables with a horizontal scrollbar, though the Markdown horizontal movement is somewhat difficult to use in that case.
The time on the graph’s x-axis is 1 hour ahead of the system/real time (adjusting for UTC does not change this).
Nice-to-haves (there’s always something more to wish for ):
Options to define x- and y-axis titles within the graph configuration.
A setting to toggle (yes/no) the display of leading zeros in the x- and y-axis label values.
Yes, I restricted swipe gestures on active widgets and text widgets that have scrollbars (you want to be able to scroll, and not go to another page) But overall it does not has the finnesse of native iOS swiping (yet?..) Not sure if I need to develop it further or just leave it out. (That’s why I said it is still in beta)
Hmmm it is showing the correct time in my installations. Is this for streaming values or for full graph’s (when sending insight information from Homey)
