[APP][Pro] Dashboard Studio - A completely free-form dashboard designer
Not sure whether this is useful, but some other dashboard widget apps that allow changing variables (like Widgetkeeper and Custom Dash) use an API key that a user can generate in the web app. The user then needs to indicate which permissions are associated with the API key. One of those is changing variables.
Thanks, I will look into that. It has been a while since I dove into this. I remember finding solutions, but those were Homeyscript based and did not work in actual apps.
Claude skill: build Dashboard Studio dashboards fully automatically
Hi all, and thanks @Satoer for this great app!
I’ve tested the new Dashboards Feature of Claude Claude Dashboards together with MCP AI Bridge and also Homey CLI Skill. It is really amazing of what Claude can do with this.
But data update is pull through the MCP Bridge only which is far from beeing efficient.
So I’ve tried if Claude now with its good knowledge of dashboards would be able to create Dashboards for the Dashboard Studio app, which is by far the most versatile Homey Dashboard system I’ve seen so far. But the Editor could be challenging for beginners (like me).
I’ve written a skill for Claude Desktop (Anthropic’s AI assistant) that designs, tests and saves complete Dashboard Studio dashboards on its own. You describe what you want (“show my Homey’s CPU, RAM and temperature with day and week graphs”), and Claude does the rest. It talks to Homey through the MCP AI Bridge app and works in the Dashboard Studio editor through its built-in browser.
@Satoer: I hope this is ok for you…
What the skill does
  • Fully automated workflow: checks preconditions (MCP AI Bridge running, Dashboard Studio installed, editor URL from your Homey’s IP + port 5050), collects devices/capabilities/insights, generates the dashboard JSON, loads it into your editor with live values, checks it, and saves it to Homey after you confirm the name.
  • Reads the real topic names from the editor’s live data / Data Stream Explorer. Names are never guessed from device names, so no more empty fields because of a wrong slug (umlauts, trailing spaces…).
  • Enables the needed capabilities in Dashboard Studio automatically (enabled_capabilities). It merges with your existing entries and never overwrites them.
  • Browser budget: on LAN addresses, Claude’s built-in browser asks you to approve every single browser action. The skill does everything it can via the bridge and bundles the browser work into ~4 calls: open editor, read topics, one test run with automatic checks (missing values, clipped text, formula errors), save + verify. So you click “allow” a handful of times instead of dozens.
  • Data that isn’t a device capability (system values, insight history for 24 h / 7 days, min/avg/max) is fed in by an auto-created HomeyScript that pushes it as homey/event/... topics.
  • Lots of verified Dashboard Studio know-how baked in: file schema, widget fields, formulas and bindings, graph quirks (maxPoints defaults to 20!), overlaying two graphs with a second scale on the right, gauges, navigation buttons, saving and verifying.
  • Safe by default: nothing is saved, overwritten, or created on Homey without your OK (unless your prompt explicitly allows it, see below).
Requirements / compatibility
  • Claude Desktop with the integrated browser (that’s where I built and tested it), plus the MCP AI Bridge app connected to Claude.
  • Dashboard Studio v2.0.12 on a Homey Pro (2026).
  • I don’t know whether it works in other AI tools like ChatGPT. It relies on Claude’s skill format, the MCP AI Bridge tools and Claude’s built-in browser. Feedback welcome!
Example 1: Homey system monitor, built in one go
This prompt builds the dashboard in the first screenshot without any questions:
Use the dashboard-studio-json skill and the Homey MCP AI Bridge. Build a Dashboard Studio dashboard "Homey System" that monitors my Homey's internals, fully automatically and without asking me questions. You are explicitly allowed to: run test scripts, create one HomeyScript and one Advanced Flow as data feed, and save the dashboard to Homey under a new name (never overwrite an existing dashboard). Use the integrated Claude browser and stick to the skill's browser budget.
Content:
1. Current values as gauges: CPU load %, RAM used %, SoC temperature °C, flash storage used %; below each a short detail line (load 1/5/15 min, RAM used/total MB and swap, temperature range 24 h and 7-day max, free GB).
2. A power tile: undervoltage now (red, blinking) / OK (green), undervoltage max 24 h, undervoltage events since boot, throttling since boot.
3. Combined graph "CPU load & temperature" for 24 h (CPU as filled line) and for 7 days (CPU as hourly bars), temperature as an overlaid line with its own scale on the right; legend with avg/max CPU and temperature range.
4. Graphs of Homey's memory usage for 24 h and 7 days with avg/max.
5. RAM per app (top 5 table) plus Homey core and total apps memory.
6. Header with uptime and time of last update. Dark theme, 1280×870, scale layout.
Data: feed everything via a HomeyScript that sends values with the Dashboard Studio "Send to Dashboard Studio" card (homey/event/... topics): current values every minute, insight histories (system loadavg, temperature, memory, undervoltage ratio; 24 h and 7 days) plus min/avg/max every 5 minutes. Trigger it with an Advanced Flow every minute. Test everything in the editor, fix the layout until there are no missing values or clipped texts, then save, verify, and show me a screenshot.
What gets created on your Homey automatically:
  • HomeyScript “DS SysMon”: reads Homey.system info (load average, RAM, swap, SoC temperature, uptime, undervoltage/throttling flags), memory per app, storage, and the system insights (CPU load, temperature, memory, undervoltage) for 24 h and 7 days. It pushes everything to Dashboard Studio as homey/event/sys_* (current values), h_* (histories) and s_* (min/avg/max) topics. Current values update every run; histories every 5 minutes.
  • Advanced Flow “DS SysMon – every minute”: an every-minute trigger that runs the script. Disable it and the dashboard simply stops updating.
  • The dashboard JSON, saved in Dashboard Studio (as a new file; nothing is overwritten).
Example 2: Energy flow dashboard
My energy dashboard was built with the same skill. It shows three Kostal inverters (with per-string power and daily yield), house consumption, the Tibber Pulse grid meter, the go-e wallbox and today’s totals (PV, consumption, grid import, cost).
  • Animated energy-flow arrows: they only animate while power actually flows, line width scales with the power, and the grid arrow reverses automatically between export and import (based on the meter’s sign convention, which the skill checks first).
  • High-contrast flow styling: a dimmed base line with a bright yellow moving pulse (red for grid import), so even small power flows are easy to see.
  • Glowing icons for active sources.
  • All values are live device capabilities. The skill enabled them in Dashboard Studio automatically and read the exact topic names from the editor; no extra scripts were needed for this one.
The skill file can be found here: github.com/tnsturm/DashboardStudioClaudeSkill. Install it as a skill in Claude, connect the MCP AI Bridge, and try it. Happy to hear how it works for you!
@Torsten_Sturm great work, and thanks for building on the bridge! Two things that might help:
  • Since 5.0 (now on the test channel) the bridge can serve skills itself. On the Home & knowledge tab you can add your own skill, up to 40 KB, and yours is about 30. Every assistant that connects can then read it with skills_list and skills_read, not just Claude Desktop. The browser part still needs Claude’s built-in browser, of course, but the Dashboard Studio know-how would be there for any client.
  • On the pull side: Claude’s own dashboards get their data by calling tools, and the bridge cannot push into them, so for live values Dashboard Studio is the better home, as you found. If you keep a Claude dashboard anyway, switch its key to lean mode (Security tab, Tools on the key): that roughly halves the tokens each refresh costs.
@Satoer sorry for borrowing your topic for a moment, and thanks for an app that makes this possible.
Wow, this is really interesting. I actually tried generating dashboard JSONs with AI, but my results were nowhere near as clean as what you generated.
Sure, totally fine by me. :+1: I would actually be happy to add some native endpoint access in Dashboard Studio so the AI does not have to “hack” its way through the interface like this. (Though I have not studied your documentation yet, how this actually works). If that makes things easier, let me know.
I still need to wrap my head around how all this MCP stuff works first, but I would not mind to help make this run smooth. But, on the other hand, I am also a bit hesitant to recommend regular users to give an AI full admin access to their Homey like that. I really do not want to be the guy responsible when an AI does something destructive to someone’s setup. The top models might handle it fine, but who knows what happens if people try this with a cheaper flash model that starts hallucinating. :sweat_smile:
No problem. I didn’t even knew you guys where working on this.
So if I understand this right :up_arrow: Claude created flows with Dashboard Studio cards to push the data to Dashboard Studio rather than enabling those capabilities directly inside the Dashboard Studio configuration? (I don’t even know if Claude has access to that configuration using the Homey CLI, and it probably doesn’t :sweat_smile:.)
I asked Claude to explain it nicely: :grin:
Claudes Answer:
There are two ways, depending on where the value comes from:
Type of value Approach How
Device measurement (e.g. an inverter’s measure_power, the weather station’s temperature) Directly in Dashboard Studio’s configuration The app stores enabled values in its enabled_capabilities setting (device ID → list of capabilities). Claude reads the setting via the MCP Bridge, adds the new entries without removing existing ones, and writes it back after your confirmation. From then on the app sends the values as topic <device name>/<capability>.
Anything that is not a device measurement (system data such as Homey’s CPU, RAM and chip temperature; insight histories over 24 h / 7 days; computed values such as min/avg/max) HomeyScript + Flow card These values can’t be enabled in Dashboard Studio. A HomeyScript reads them and sends them as homey/event/<name> using the “Send to Dashboard Studio” card. An Advanced Flow runs the script on a schedule.
Rule of thumb: if a value can be enabled directly in the configuration, that’s the way to go. It’s simpler, needs no flow, and updates instantly on every change. The script-and-flow route is only for values that can’t be enabled directly.
How it worked out in my setup:
  • System monitor: only HomeyScript + Flow. enabled_capabilities wasn’t touched, because none of these values are device measurements.
  • Energy dashboard: the capabilities (Kostal, Solar-Log, Tibber Pulse, go-e) were already enabled from an earlier run. They were read, not changed.
I think it is related to the new beta Dashboards feature of Claude, it does not only include the architecture to create internal Dashboard Artifacs but also a lot of training on how Dashboards look great and the underlying necessary techniques.
That would be great, I think the best path is to talk directly to @weide43 how this could be done best, because I’m not a MCP expert. Easy access for the AI to the complete documentation including the changelog will also help.
People like me who install the MCP AI Bridge should know what they are doing. And the MCP App brings in a lot of control of what an AI Agent is allowed to do: MCP Security Controls.
NEW Dashboard Studio TEST version v2.0.13
2026-10-12
  • New: Edit Homey Variables - Update Homey Logic variables directly from dashboard widgets like edit boxes, switches, and sliders using an optional Personal API Key.
  • New: Direct Flow Starting - Run Standard and Advanced Flows with a single tap from dashboard buttons or switches using an optional Personal API Key.
  • New: Direct Mood Activation - Activate room ambiance and lighting moods directly from dashboard buttons using an optional Personal API Key.
  • New: Calendar Flow Cards - Renamed to “Convert iCal JSON to Markdown” with new view formats (Tomorrow, Yesterday, Next/Previous week, Next weekend, Next/Previous month, and rolling day views).
  • New: Flexible Calendar Range - Load & Filter iCal flow card adds “Previous, current and next month” timeframe so a single download can feed multiple markdown views.
  • Improved: Calendar Memory & Performance - Optimized iCal streaming filter, parsing, and markdown generation to reduce memory and CPU usage on Homey.
  • Improved: Calendar Documentation - Expanded in-app documentation with recommended multi-view patterns and flow advice.
  • Improved: Binding Options - Payload formula edit box automatically expands for multi-line formulas.
  • Improved: Reorganized Editor settings into a more intuitive, logical layout.
  • Improved: Connecting Widgets & Data Documentation - Updated in-app documentation for connecting widgets and live data.
  • Fixed: Disabled Widgets - Disabled widgets reliably block all touch, click, and keyboard interactions now.
  • Fixed: Flow Card Trigger - Switching browser tabs back to Dashboard Studio no longer re-triggers the “Dashboard Loaded / Refreshed” flow card.
  • Fixed: Button Audio - Long-pressing a Switch or Button widget configured with an additional topic now plays audio feedback.
New: Write Homey Variables, Direct Flow Starting, and Direct Mood Activation using an optional Personal API Key.
Homey doesn’t allow apps to change variables directly, but with a personal user API key, this is now possible inside Dashboard Studio.
Everyone thank SunBeech above for giving us the solution to make this possible :partying_face:
This API key also made a few other things directly possible as well. Once you generate and add an API key, you can now directly start “Flows” (and read their enabled or disabled state) and directly start “Moods”. Read how to generate and use the personal API key in the documentation.
Calendar Flow Cards
and @Bert_Onraedt, @SOJI, @Gert_Winther
IMPORTANT!: If you use the iCal cards, please read this because this update might break your existing setups.
I changed how the iCal cards work, though I tried to keep backwards compatibility for those of you parsing the JSON yourself with Homey Script.
How it worked before:
The [Load & filter iCal] card downloaded a specific date range and decided the starting point, and the [Convert iCal JSON to Markdown] card just converted that exact range to Markdown.
How it works now:
The [Load & filter iCal] card is now meant to grab a broader range (like “Previous, current and next month”), while the [Convert iCal JSON to Markdown] card is always anchored to “today”. Just make sure the date range you want to display in your Markdown is actually included in the range you loaded in the first card, otherwise your table might have missing days. (For instance I you just load the first month and if it’s the first day of the month and your card needs to display “yesterday”, that data won’t be available in the JSON.). I kept all the other filters also (both cards have a big list) to keep as much backwards compatibility as possible.
The big advantage:
If you want to show multiple calendars on your dashboard (like this week, next week, and the whole month), you now only have to download your calendar feed once with the [Load & filter iCal] card. From that single download, you can generate as many Markdown calendar views as you want.
I completely rewrote the code behind these cards to be much faster and use way less memory. Since I am not a heavy calendar user myself, please check if all your events are still showing up properly. Let me know if it works as expected, if you run into any issues, and how the memory usage looks.
Please read for a deeper and better explanation this documentation.
Small fixes / changes:
Switching tabs should not trigger the Dashboard load/refresh card anymore.
This is fixed :+1:
Hue and Saturation is now renamed to Color Tone and Color Intensity.
Hi Satoer,
I’m a new Homey user, but already really appreciate the amazing work involved in creating an app this complex.
I hope you or your colleagues can help me with the calendar functionality.
I have 4 iCal URLs, processing through Advanced Flow, parallel processing in pairs, Marked Down and sent to Dashboard Studio. I have checked the output text, and I can see appointments for all 4 calendars, Blocks1-4.
The App configuration in Homey is set to colour by calendar in ‘Calendar Source Blocking’, and lists the 4 unique IDs
However, in the dashboard, only appointments from two calendars show - Block 1 and Block 3.
I have experimented with various combination pairs, all working perfectly, but any more than 2 calendar sources, the dashboard only shows 2.
Is there a default setting I can change to increase the displayed number of calendars?
Not sure that this is relevant, but from the text file with 4 inputs, the first entries are from Block1 and Block3, entries for the other two blocks dispersed further through the file.
Hi Barry,
Thanks.
Could you first tell me what version of Dashboard Studio you are running? I just released a new version where large portions of the Calendar code were rewritten to be more performant and memory friendly. (and the method of parsing has been changed)
If you are running the stable V1 version or a version prior to V2.0.13 (you can see this at the top of the editor), please upgrade to version v2.0.13. I think most of the V2 bugs are resolved now, and it is actually running more stably than the V1 version.
I’m was running version 1.11.7, installed from the Homey App page.
I’ve upgraded to the Test version now, all calendars showing. Thank you.
Looks Great! Almost ready for the kids to start using :face_with_peeking_eye:
That is great! Please feel free to share a photo of your dashboard in action. Other users are more than welcome to join in too :wink:
I am really hoping to put together a big gallery of real world use cases and examples. We have over 2300 users now, yet only a handful of people have shared a few pictures so far. I am specifically looking for actual photos of the dashboards running on your devices rather than screenshots.
Seeing what everyone is doing with their dashboards also inspires me and triggers ideas for what to add next. Some users are even creating specific SVG controls. For example, I saw someone who made a dashboard with non square shaped containers, and now I have built that right into the native container widget.
Send you some photo’s of my dashboard
At the moment my calendar setup still works.
(download ical today + 7days => combine => parse with own script today & tomorrow )
Hi Satoer,
I will hopefully have something presentable soon.
I have a question regarding button groups (radio buttons). I want to use 3 text containers for ‘Current Month, Current Month+1 and Current Month+2. Picking the appropriate radio button should show the corresponding text container only, the other 2 linked to the other 2 radio buttons.
I cannot seem to be able to figure this out. I was able to replicate switching between two calendars similar to the demo switching from month view to week view. But the practice doesn’t seem to carry where >2 options are desired.
Would you have a simple solution?
Thanks
Okay, to understand this, it is easiest to take it one step at a time:
First, create a text widget, and below that, a button.
In this first example, we just want to hide and show the Text Container by pressing the button on and off.
I selected the switch button and chose the “Button label Inside” preset
to create a button out of it instead of a pill switch.
Now scroll down to the Action & Behavior settings. There is an option called “Output Topic”.
I added the topic local/TextContainer1Visible. The word local/ in front of it makes it a local topic. This does not leave the dashboard (it does not get sent to Homey). This is best when you only want to change things on this specific dashboard. The TextContainer1Visible part is just a name I made up myself.
You can see the ON and OFF values below this. These are the values that are sent when turning the button on and off.
Now select the text container. We want to show and hide this based on what the button is sending.
In the widget section, there is an option called “Visibility”. This setting controls whether the widget shows or not. If you hover your mouse over it, a small chainlink icon appears. Click this to make the setting dynamic. In Dashboard Studio, you can make almost any setting dynamic.
Fill in the same topic (local/TextContainer1Visible).
Now the true / false value is sent to this setting, and the text container will show and hide. Exit edit mode or press and hold ` to quickly test this.
If you turn the button on and off, the text widget should show and hide.
That’s the first step complete.
Now we want three buttons and three text widgets. It is fastest if you configure the button completely as a radio button before copying it, but for clarity, we are going to copy the button and text widget first.
Select both the text widget and the button, and press CTRL + D to duplicate them (or copy and paste). Do this again so you have three text widgets and three buttons. It is easiest to put them side by side first, and overlap them later if you wish.
Now each button should show and hide its own container. So:
Change the topics inside the Output Topic of the button and the Visibility setting of the text widget to local/TextContainer2Visible for button and text widget 2, and local/TextContainer3Visible for 3.
Now go test it again. Each of the buttons should control its own text container.
For the next step, we only want one button to be enabled at a time. We can do this by making each button a member of the same “Selection Group ID”.
Select button 1 and fill in TextContainerGroup in the “Selection Group ID” (Action & Behavior) section.
Do the same for buttons 2 and 3. (Once you create your first Selection Group ID, the ID becomes available in the dropdown for easy selecting).
Test it. Great, now only one of the buttons lights up. However, the text containers do not hide when a button turns off… This is because the selection group only disables the button, and does not execute the output topic of that button when another button turns it off. You can fix this by enabling the setting “Send Off When Turned Off by Group”.
When another button turns this button off, the button being turned off will now send its off state to the output topic. Enable this setting for each button widget, and it should work.
Note: If you want the dashboard to open in the same state it was closed in, do not add local/ in front of the topic. When you leave that out, the topic is cached inside Homey and replayed when opening the dashboard.
If multiple text widgets are visible at startup, change the default value of the text widget’s visibility by hovering over the visibility setting and pressing the sliders button (binding options). There you can adjust the default value.
This may look like a massive amount of steps, but it is really just 4 minutes work once you understand how you can do thinks. There are also smarter and quicker ways to do this, but I think this is the most straightforward way for a beginner to understand.
Okay, I have a bit of time and I would like to show you another, maybe simpler solution.
You can also just make multiple pages. Another important thing to understand is that a single widget can live on multiple pages at the same time.
Let’s add a button to a clean canvas page and configure this as a push button as well (quick tip: you can hide the container behind the button if you disable “Show Container” in the container style).
We want this button to live on pages 1 to 3. That way, this button is visible on pages 1, 2, and 3.
In the widget settings, fill in 1-3
Now we want to configure this button to jump to different pages. In the “Action & Behavior” section, select “Go to Page” in the “On click” setting. This will make it jump to a specific page. The neat thing is: if you are already on that target page, the button automatically shows as enabled, and disabled if you are not.
Set the “Target page #” setting to 1
You can rename this button label in the “Text & Typography” section to “Page 1” or something similar.
Great. Now duplicate this button two times (select it and press CTRL + D).
Configure the other buttons to jump to pages 2 and 3.
That is basically it. When you press the buttons, it will jump to that page. Just add a text widget with its own calendar on each page, and you won’t even see the difference between the previous method and this one in usage.
[EDIT] I just did a quick test in case I missed something and noticed a (V2) bug. When the button is configured to jump to a page, it should show as disabled when you are not on that page. That does not seem to be working right now. I will fix this in the next version.
Inspiring work!
Homey made home setup easy. Now this will make the UX just as convenient.
Well done.
Minor remarks v.2.0.13:
  • It appears that the alignment setting for a Label is not being respected. After the ‘Automatic width’ option is disabled and the width is increased, the alignment always remains to the left.
