This option is currently only added for devices that are designed to measure power returned like the Shelly EM/3EM/Pro 3EM/4EM/4 Pro.
I will see if I can create an action card (so not under device settings) allowing to change this.
Thanks!
I have Homey Pro 2023 - I donât seem to be able to install the app?
When will it be available please?
I have tried to read through this community space, but the information is very confusing and hard to find the answer. I canât even see how to start a new post.
@elflord Do you get an error when you try to install the app?
@Phuturist, I use a Shelly1 relay switch to make a smart doorbell out of my dumb doorbell. However, the If-card thatâs triggered by pressing the physical doorbell button switch, no longer seems to exist. The current If-cards do not result in a useful trigger. Are there other ways to get the input switch of the relay switch in Homey?
Read the instructions from the first post. That card has available under the app, not under the device.
Shelly qubino wave 1PM does not cooperate with Homey pro 2023 and Home bridge
(Inserted by moderator)
Do you have a problem with that too? even if sometimes I manage to connect âShelly wave 1PMâ to Homey pro 2023, still it doesnât show consumption and also the switch doesnât work properly
Thanks for your swift reply and great work on the app. Following your instructions, I find the card that I already screenshotted above, correct? The problem with that card is, pushing the doorbell switch is not triggering it. HomeAssistant however does correctly register it:
Any ideas for the root cause of this not showing up in Homey?
Lotâs of ideas, see the first post on how to troubleshoot.
And did you bother to find the answer yourself? The answer is already in the first post. And if it switches only sometimes itâs an issue with Homeyâs Zwave. Not for me to fix as well.
Known issues
Energy measuring for Shelly Wave 1PM/2PM not implemented. The library that Athom maintains for including Zwave devices has not been updated for a while and currently does not support Zwave command class METER V6. Therefor energy capabilities of the Shelly Wave 1PM/2PM have nog been implemented yet.
thank you ![]()
Just to get one thing straight. I can not access devices that are connected to another WiFi network then my Homey? Even if they are in the same house? Itâs a guest network that only reaches a part of my house.
Meaning, the Shelly and homey needs to be in the same WiFi network, right?
Is the networks are completely isolated then itâs not possible. If you create some sort of tunnel with an advanced network setup you might be able to manually pair the device using its IP address. But it wonât be discovered when trying to pair it.
I am having problems with the Shelly Blue door Window. I am getting this one integrated. I also have BLE proxy enabled on the plus devices.
The device detects very reliably when the contact is removed. But when I close this again it is not or rarely detected.
If I include this in the Shelly app then it works very reliably.
Does anyone have any idea what this is due to?
I am grateful for any hints.
This is typical behavior when the BLE proxy isnt working. Homeyâs lousy BLE stack cant handle BLE advertisements sent within a short timeframe causing it to miss the close event. Double check the BLE proxy on your Plus/Pro device(s) making sure BLE is enabled and the script is running (and not other script is running which uses the the devices BLE functionality).
Thank you for the quick reply. Can you tell me what exactly I need to pay attention to? Bluetooth is enabled on the shellys. I only use a script with a shelly. But this has nothing to do with Bluetooth.
Can they describe me in more detail what I have to pay attention to?
Thank you very much.
Follow the instructions from step 6 of the troubleshoot guide in the first post of this thread.
Thank you for pointing this out. I have done this with my 4 plus units. The Shelly Blue is also in close proximity. Unfortunately this has not made any changes.
Are there any other options I can try?
What was the result in the debug log? Do you see the BLE advertisements on the Plus/Pro device?
