v4.2.3
New Live version!
Fixed
Device Triggers Working Again: All “… changed” trigger cards of the KNMI device (such as current temperature, wind speed, weather alert, forecasts and weather recaps) were not firing in 4.2.x. All 90 device triggers are registered again and fire whenever the value changes.
Current Temperature Trigger Title Fixed: The Dutch title of the current temperature trigger read “Huidige temperatuureratuur is veranderd” and now correctly reads “Huidige temperatuur is veranderd”.
Flow Card Titles Corrected: Several trigger titles were wrong or identical. The maximum temperature day after tomorrow no longer says “min”, the wind speed (meters per second) day after tomorrow no longer says “kilometers per hour”, and the weather recap triggers for the day after tomorrow, day 4 and day 5 now show which day they belong to.
Server Online/Offline Triggers Fixed: The Server online trigger never fired and Server offline fired every 10 minutes during an outage, with a notification every time. Both now fire once, only when the server status really changes.
Temperature & Wind Speed Conditions Fixed: The conditions for current temperature, feels-like temperature and wind speed now also work with 0 (0 °C used to always be “true”) and with decimal values. Entering 21 matches 20.5 up to 21.4.
Conditions Per Device: All condition cards now check the KNMI device you select in the Flow, so they also work correctly when you have more than one KNMI device.
“Slightly Cloudy or Clear” Condition Fixed: The condition now uses the KNMI weather icon codes and also recognises a clear night, so it works reliably for now and for every forecast day.
Changing the Place Fixed: After changing the place in the device settings, KNMI immediately fetches the weather for the new place instead of the old one.
Safer Trigger Values: On the first update after installing or updating, triggers no longer fail on an empty old value.
Improvement
Consistent Flow Card Titles: All English and Dutch trigger and condition titles have been written out consistently (“Expected maximum temperature tomorrow changed”, “Verwachte windsnelheid (knopen) dag 4 is veranderd”). Existing Flow card IDs are unchanged, so your Flows keep working.
Dutch Titles for Server Triggers: The server online/offline triggers now also have a Dutch title.
Under-the-Hood Enhancements: In this version of KNMI, we’ve improved Flow card registration, condition handling, error handling and logging. We’re continuously working behind the scenes to fine-tune the app for the best possible user experience. Your feedback is invaluable! If you encounter any issues or have suggestions, feel free to reach out through our support channels.
Enjoy the improved KNMI v4.2.3!
Download the new version in the Homey App Store!
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - KNMI - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)Via Homey Webapp:
Settings wheel bottom left - Select KNMI - Click on send diagnostic report
Changelog
Disclaimer ![]()
This app is a labor of love, provided on a best-effort basis. No rights can be derived from its use. Data made possible by weerlive.nl
Apps made by @LRvdLinden
Contribution
If you appreciate this app, fuel future development with a PayPal contribution, buy a round with iDeal or Bunq.me. Your support keeps the magic alive! ![]()
