[APP][Pro&Cloud] frient Zigbee App (v2.5.4)
You might want to check the dedicated forum section for Frient devices: [APP][Pro&Cloud] frient Zigbee App (v2.5.4). The first post also contains an overview of specific devices (device/model IDs) supported by the app. Not sure if your devices have the same IDs.
I would also like to know this, as I am in the same situation as you.
did you find a fix for the problem?
I have the same problem.
Do you still have the problem that Frient Han is not showing the produced energy?
With the current version of the app (2.8.1) I have issues with the Intelligent Smoke Alarm. The device states “Invalid version” (see screenshot below).
Bought the devices some weeks ago, and checked whether there are either firmware updates or app updates, but neither are. The whole reason for buying these devices is that Homey can trigger alarms on them. In the Homey app I cannot see the firmware version listed on the device settings.
Any idea on how to fix this?
Tried contacting the Frient support through homey@frient.com and although a first response came in within three days it now is silent for two weeks already. Anyone having the Frient devices controllable through Homey?
Hi everyone! Has anyone else had trouble updating a Frient Motion Sensor Pro through the new Homey app 3.0?
Two of my three sensors updated without any issues, but the third showed “Failed to update” and stopped reporting motion to Homey. The green LED still flashes when it detects movement, but Homey can’t find it anymore, even when I try to repair it right next to the hub. I’ve also tried removing the battery and restarting Homey, but no luck.
I’ve contacted Frient support to ask for help. Just wondering if anyone else has run into the same problem, or found a way to get the sensor working again?
Yeah, since 6 days OTA firmware updates!
Yes, 3 smoke alarms and a plug. Working better after the ota firmware updates.
Since the latest version of the app my two smoke alarms now also properly started working! Not sure whether they had a firmware update though.
If new firmware is available for a device, you have to manually initiate the firmware update yourself.
After the last firmware update, the devices, such as the motion sensor, intrusion sensor, and smoke detector, experienced nothing but problems, as the devices kept disconnecting from the ZigBee network. Only after re-adding all the devices did they work properly.
Can you be a bit more specific, to understand the origen of your problem?
After the last Homey SW update, Frient app update of after updating the device firmware (as released in the latest Frient app)?
Hi @frient and @TedTolboom,
I’m experiencing a recurring Zigbee connectivity problem with two frient motion sensors connected to my Homey Pro (Early 2023).
The affected sensors are installed in two different rooms (pantry and toilet).
Symptoms:
  • Homey repeatedly reports that the sensors have “left the Zigbee network”.
  • The sensors subsequently rejoin the network, sometimes within just a few minutes.
  • This leave/rejoin cycle can repeat frequently, sometimes at approximately five-minute intervals.
  • I have also noticed occasional brief red LED flashes on the sensors.
Troubleshooting performed:
I removed one of the affected sensors (toilet) from Homey and paired it again to investigate whether this would resolve the problem.
I also submitted a diagnostic report through the frient Homey application.
Diagnostic report ID:
50623a6d-0c05-40fd-8569-a15a17ab8ebd
I noticed similar reports from other users following recent frient firmware updates. However, I cannot yet confirm whether my issue is related to a device firmware update, the frient app, or the Homey Zigbee implementation.
Could you please investigate the diagnostic report and advise what might cause these repeated network leave/rejoin events?
Is this a known issue with the current frient firmware or Homey integration?
I’d be happy to provide additional device information or logs if needed.
Thanks in advance for your help!
I have 6 friend devices (smoke alarm and door sensor. According to the Frient app in Homey they are all awaiting a firmware update. However when I try to initiate it through homey I get an error that the device is asleep. I can initiate an alarm from the homey app so it is reachable. But the fw update will not start. What should I do?
