[APP][Pro] BLUETTI – Power stations via BLUETTI cloud
Hi Patrick,
Thank you, and thanks for offering to help test. That makes a big difference, since I don’t have an Elite 200 V2 myself.
Version 0.4.8 is now in test and covers most of your wishes:
  • Sleep mode on or off: the Sleep mode button on the device shows the current state. There are also dedicated flow cards: “Turn sleep mode on or off”, “Sleep mode is on/off” (condition) and “Sleep mode was turned on or off” (trigger). They only appear for power stations that support sleep mode. Sleep mode is no longer in the general “Turn output on or off” card, so please replace that card in your flow with the new one after updating.
  • A flow when the cloud goes down: the new trigger “Connection changed to Cloud / Bluetooth / Offline” fires when the connection changes. Unlike “Power station went offline”, it also fires when the BLUETTI servers themselves are unreachable, as you had yesterday evening. There is also a matching condition, “Connection is …”.
  • No more orange warning: while Homey reads your Bluetti over Bluetooth, the Connection sensor shows Bluetooth instead of the orange banner, and Working mode shows “–” (it can’t be read over Bluetooth).
  • Dutch: the app is now in Dutch, as well as German, French, Spanish and Italian.
Sleep mode over Bluetooth: for this I need your help. Under Diagnostics in the device settings there is a new option, “Bluetooth register scan”:
When it’s on, Homey reads the Bluetti’s settings over Bluetooth and logs what changes after you switch something. It only reads and never writes anything to your Bluetti. I tested it on my Elite 30 V2, where it found the DC and ECO switches exactly where expected. Could you:
  1. Close the BLUETTI app on your phone.
  2. Turn on “Bluetooth register scan” and wait about 30 seconds.
  3. Turn sleep mode on from Homey and wait about 30 seconds.
  4. Turn sleep mode off from Homey and wait another 30 seconds.
  5. Send a diagnostic report and post the code here.
  6. Turn the scan off again.
About the warranty: the app doesn’t change the Bluetti’s firmware or software. It sends the same commands as the official BLUETTI app, through the BLUETTI cloud and over Bluetooth. I can’t speak for BLUETTI, of course, but nothing is installed or modified on the power station itself.
Thanks also for the report about yesterday. I’m glad your Bluetti came back without having to set it up again. Did the Connection sensor show Bluetooth or Offline while you had the server problems?
Regards,
Gabriel
Hai Gabriel,
I did everyting that you wrote, here is de code;
9cd47e44-2f12-44ec-bd71-cf6f117ae909
(attachments)
Hi Patrick,
Thanks for running the test! The report shows what went wrong. From about 16:48 your time, BLUETTI’s servers stopped answering Homey’s data requests. Your Bluetti itself was online the whole time (the cloud kept sending live updates). Homey then switched to Bluetooth, which worked fine. But sleep mode can’t be switched over Bluetooth yet, so the command failed with the message about Wi-Fi, which was wrong in this case. So the sleep setting never changed, and the scan had nothing to compare.
Version 0.4.9 is now in test:
  • Sleep mode is now sent through the cloud even while Homey reads your Bluetti over Bluetooth. If the cloud doesn’t answer that either, the error now says so.
  • Every scan now repeats all changes since the scan started, so a short diagnostic report is enough.
Could you try again after updating, at a time when Connection shows Cloud?
  1. Turn off “Detailed logging” in the device settings (it fills the report quickly).
  2. Close the BLUETTI app on your phone.
  3. Turn off “Bluetooth register scan”, then turn it on again and wait about 30 seconds.
  4. Turn sleep mode on from Homey and wait about 30 seconds.
  5. Turn sleep mode off from Homey and wait another 30 seconds.
  6. Send a diagnostic report and post the code here.
  7. Turn the scan off again.
By the way, yesterday’s timeout was at almost the same time (around 16:49 your time). If you notice the cloud problems always start in the late afternoon, please let me know.
If the report still comes back too short, there’s another option: run the app from your computer with homey app run (the steps are in my earlier post), which shows the full log live. The downside is that when you stop it, the development app is removed and you’d have to reinstall BLUETTI and add your Bluetti again, which breaks your flows. So let’s try the report first.
Regards,
Gabriel
Hai Gabriel,
Also I notice the cloud problems always start in the late afternoon.
Yesterday, between 5:00 PM and 7:00 PM, the connection in Homey kept switching between Bluetooth and cloud. After that, only the Bluetooth connection remained active for the rest of the evening. Therefore, I was unable to perform the test.
I did the test this morning. Here the code: adf71034-5de8-4748-9e1b-f3218d71f098
Hi Patrick,
Thanks for the test and the report, it answers the main question.
  • Sleep mode can only be switched through the cloud. When you turned sleep on and off this morning, the Bluetooth scan saw no change in any register the unit exposes. So there is nothing Homey can switch over Bluetooth for sleep mode.
  • During the cloud outage, the command itself timed out too. Yesterday evening, when you tried sleep during the outage, the BLUETTI cloud did not answer the command either. That is why it could not work then. Since 0.4.9 the app shows a clear message in that case instead of saying the unit is offline.
  • Bluetooth did its job. While the cloud was down, Homey kept reading your power station over Bluetooth without a single failure, and it switched back to the cloud by itself at 22:48 your time.
  • The outages follow a daily pattern. They seem to start around 16:00 UTC (17:00 your time), which is midnight in China, so it may be maintenance on BLUETTI’s side. I am checking whether it also happens here at the same time.
Version 0.5 will be available as a test version shortly. It adds:
  • “Keep AC/DC output on” options in the device settings;
  • the Bluetooth register scan now turns itself off after 1 hour;
  • the real-time connection reconnects when it stays connected but stops delivering updates.
You can turn the Bluetooth register scan off now; it is no longer needed.
Thanks again for your help!
Gabriel
hai Gabriel,
I’ve created a flow to check when Homey detects a cloud or Bluetooth connection, because I can only switch to sleep mode when there is a cloud connection.
I had created a flow that was supposed to put the Bluetti into sleep mode 60 minutes before sunset. That worked fine, partly because it switched back to Bluetooth afterwards.
Yesterday, however, it didn’t work because the connection switched back to Bluetooth at around 4:00 PM.
I think I’m just unlucky with sleep mode, because whenever I want to use it, the cloud connection seems to be unavailable for a long period of time.
I’ve included a short list showing when the cloud and Bluetooth connections are active. Maybe you can do something with this information. I’m also curious whether you’re experiencing the same thing at around the same times.
Hi Patrick,
Thanks for the update, and you’re not just unlucky: your reports show the same pattern every day. The cloud problems start around 16:00–17:00 your time and can last for hours. That is close to midnight in China, so it may be something on BLUETTI’s side, but I can’t confirm that yet.
The list you mentioned didn’t come through, only your text. Could you post it again, as text or a screenshot? I’d like to compare the times.
To answer your question: I can’t say yet whether it happens here at the same times, because my Homey didn’t keep a connection history until now. To fix that, version 0.5.1 adds a new item in Insights: Connection (2 cloud, 1 Bluetooth, 0 offline). Once you update, your graph will show every switch without needing a list, and I’ll compare it with mine after a few days.
About sleep mode: it can only be switched through the BLUETTI cloud, and during these outages the cloud doesn’t answer the command either, so the app can’t work around it. Until I find something better, you could change your flows so sleep mode doesn’t depend on the sunset moment:
  1. Move it earlier: run your sleep flow before 16:00, while the cloud is usually working.
  2. Catch up when the cloud returns: add a second flow:
    • When: Connection changed to Cloud
    • And: the time is within the period you want sleep mode on, and sleep mode is off
    • Then: Turn sleep mode on
With the second flow, sleep mode may start later than planned, but it will start as soon as the cloud is back.
I’m also looking at a way to retry the command automatically, and at better logging of whether BLUETTI’s regional server is reachable during an outage. I’ll let you know when there’s something to test.
Thanks for all the testing, it really helps!
Gabriel
hai Gabriel,
I have seen the chart. Nice,
see attached file (before the chart)
Regards,
(attachments)
