[APP][Pro] Blueriiot Blue Connect Local
Hello guys,
This topic can be used for support questions, feature suggestions and bug reports related to the Blueriiot Blue Connect Local app.
In contrary to the other community app, this app does not make use of the Blueriiot API, rather it uses local connectivity. This offers a number of benefits: you are no longer depending on the cloud for your measurements and you can take as many measurements as you want on the times you want.
In the current version the app supports direct BLE connectivity from Homey, as well as the use of an ESPHome Bluetooth Proxy.
The app itself can be found in the Homey store on the following locations:
I’ve developed this app in a full open-source mindset, the source code is available under a GPL-license, meaning that everyone is allowed to use it provided that they release their source code under a GPL-compliant license. You can find the source code of the application in my GitLab repository at:
Any issues which are found in the app, or features which I’m still considering to be adopted, can be found in the GitLab issue tracker at:
Anyone is free to contribute towards the app, you can simply fork the repository on GitLab and create a merge request with your changes, I’ll review them and most likely include them as part of the app.
If you want, you can buy me a beer, or send me a donation using:
I really hope you enjoy the app, and any feedback is always welcome! I try to respond to all requests as soon as possible, but be aware that I have a regular job too, which might imply that sometimes it takes a bit longer then on other times.
Kind regards,
great App.
Very usefull, thanx for your work
Hi, I’m having problems using BlueConnect Local through an ESPHome Bluetooth Proxy.
Setup:
  • Homey Pro Early 2023
  • Blueriiot BlueConnect Local
  • Blue Connect sensor MAC: 00:A0:50:D8:D4:9A
  • ESP32-WROOM / NodeMCU style ESP32
  • ESPHome proxy using the YAML from the project repository
  • ESPHome API encryption enabled
  • ESP32 proxy IP: 192.168.1.91
What works:
  • Direct BLE mode works when the Blue Connect is close to Homey
  • ESPHome proxy connects to Homey successfully
  • Homey discovers the Blue Connect through the ESPHome proxy
  • The device can be added in Homey
What fails:
  • Take a measurement does not populate temperature, pH, ORP or battery
  • All capabilities remain empty/null in Homey
  • ESPHome sees the Blue Connect and attempts to connect, but the BLE/GATT connection fails
Relevant ESPHome log:
Connecting v3 without cache
Timeout waiting for teardown
OPEN_EVT in unexpected state
Connection open failed, status=133
Disconnected, reason=0x08 / 0x85
I first tested ESPHome 2026.9.1, then downgraded to 2026.7.2, but the behavior is the same.
The ESP32 is placed very close to the Blue Connect, so this does not appear to be a range issue.
Is there a known issue with ESPHome proxy mode, or is there a specific ESPHome version / ESP-IDF version / ESP32 board that is known to work reliably? https://www.amazon.se/dp/B0D9BTQRYT
Additional log detail:
@2colors/esphome-native-api 1.3 connects successfully, but ESPHome reports:
using outdated API 0.0, update to 1.14+
BLE still fails with:
ESP_GATTC_OPEN_EVT in DISCONNECTING state (status=133)
Connection open error, status=133
Hey @henqo
I might have found something that could fix your issues. Unsure though that it will work.
Could you try with v0.2.6 which is published towards test and is available from Blueriiot BlueConnect Local | Homey
Thanks!
Thanks! I tested v0.2.6, but unfortunately I still get the same BLE/GATT failure through the ESPHome proxy.
Homey connects to the ESPHome proxy successfully and the Blue Connect is discovered, but the connection still fails with:
The device MAC is still 00:A0:50:D8:D4:9A.
The log also still shows:
@2colors/esphome-native-api 1.3 using outdated API 0.0, update to 1.14+
Direct BLE from Homey works when the Blue Connect is close enough, so the sensor itself seems OK.
Hey @henqo
I’ll have a deeper look during the next days, it should work as I’ve been using it all summer with ESPHome as BLE Proxy, but have to fire up the setup again as my pool is currently closed for winter.
Kind regards,
Thanks, no problem at all.
I’ll leave my setup unchanged for now so we have a stable reference when you get a chance to test it again.
Let me know if you want any additional logs or configuration details from my setup.
Hey,
For me it still looks to work - the message you get is barely a warning, it should not block the reading.
Is there any other output on the ESPHome device? Maybe a complete log could help me to dig deeper into this.
Kind regards,
Thanks — I managed to capture a complete DEBUG log now.
After removing and re-adding the Blue Connect device in Homey, the ESPHome proxy is again receiving the BLE connection requests.
The important part is that I can reproduce the issue consistently. There are several separate connection attempts to:
00:A0:50:D8:D4:9A
Each attempt starts normally with:
Stopping scan to make connection
Promoting client to connect
Connecting
but eventually ends with:
ESP_GATTC_DISCONNECT_EVT, reason 0x100
I also notice that the Homey ESPHome client at 192.168.1.172 disconnects/reconnects around some of these attempts, and the log still shows:
Full log:
[08:43:00.503][C][api:269]: Server:
[08:43:00.503][C][api:269]: Address: bleproxy.local:6053
[08:43:00.503][C][api:269]: Listen backlog: 2
[08:43:00.503][C][api:269]: Max connections: 6
[08:43:00.504][C][api:276]: Noise encryption: YES
[08:43:00.577][C][mdns:259]: mDNS:
[08:43:00.577][C][mdns:259]: Hostname: bleproxy
[08:46:54.877][D][wifi:2474]: Roam scan (-53 dBm, attempt 1/3)
[08:47:37.393][D][api:253]: Accept 192.168.1.172
[08:47:37.490][W][api.connection:1751]: ‘@2colors/esphome-native-api 1.3’ using outdated API 0.0, update to 1.14+
[08:47:37.576][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): connected
[08:47:47.312][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): disconnected
[08:47:47.407][W][api.connection:2532]: @2colors/esphome-native-api 1.3 (192.168.1.172): Reading failed CONNECTION_CLOSED errno=128
[08:47:52.743][D][api:253]: Accept 192.168.1.172
[08:47:52.848][W][api.connection:1751]: ‘@2colors/esphome-native-api 1.3’ using outdated API 0.0, update to 1.14+
[08:47:52.849][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): connected
[08:47:53.773][I][bluetooth_proxy:059]: [0] [00:A0:50:D8:D4:9A] Connecting v3 without cache
[08:47:53.789][D][esp32_ble_tracker:169]: connecting: 0, discovered: 1, disconnecting: 0, active: 0
[08:47:53.789][D][esp32_ble_tracker:909]: Stopping scan to make connection
[08:47:53.790][D][esp32_ble_tracker:917]: Promoting client to connect
[08:47:53.802][D][esp32_ble_tracker:953]: Setting coexistence to Bluetooth to make connection.
[08:47:53.803][I][esp32_ble_client:126]: [0] [00:A0:50:D8:D4:9A] 0x00 Connecting
[08:47:53.803][D][esp32_ble_client:232]: [0] [00:A0:50:D8:D4:9A] fast conn params
[08:47:53.851][D][esp32_ble_tracker:169]: connecting: 1, discovered: 0, disconnecting: 0, active: 0
[08:48:03.302][D][esp-idf:000][BTU_TASK]: W (382407) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:03.803][D][esp32_ble_client:157]: [0] [00:A0:50:D8:D4:9A] Disconnect before connected, disconnect scheduled
[08:48:05.831][D][esp-idf:000][BTU_TASK]: W (384926) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:07.082][D][esp-idf:000][BTU_TASK]: W (386187) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:08.330][D][esp-idf:000][BTU_TASK]: W (387436) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:08.823][D][esp32_ble_client:157]: [0] [00:A0:50:D8:D4:9A] Disconnect before connected, disconnect scheduled
[08:48:09.621][D][esp-idf:000][BTU_TASK]: W (388686) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:10.849][D][esp-idf:000][BTU_TASK]: W (389936) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:12.097][D][esp-idf:000][BTU_TASK]: W (391196) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:13.111][D][esp32_ble_client:380]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_DISCONNECT_EVT, reason 0x100
[08:48:13.111][D][bluetooth_proxy.connection:383]: [0] [00:A0:50:D8:D4:9A] Disconnect, reason=0x100
[08:48:13.114][D][esp32_ble_client:212]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT
[08:48:13.115][E][esp32_ble_client:325]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT in DISCONNECTING state (status=133)
[08:48:13.115][W][esp32_ble_client:224]: [0] [00:A0:50:D8:D4:9A] Connection open error, status=133
[08:48:13.115][D][esp32_ble_tracker:169]: connecting: 0, discovered: 0, disconnecting: 0, active: 0
[08:48:13.116][D][esp32_ble_tracker:957]: Setting coexistence preference to balanced.
[08:48:13.228][W][api.connection:2532]: @2colors/esphome-native-api 1.3 (): Packet write failed SOCKET_WRITE_FAILED errno=128
[08:48:13.228][D][api:253]: Accept 192.168.1.172
[08:48:13.332][W][api.connection:1751]: ‘@2colors/esphome-native-api 1.3’ using outdated API 0.0, update to 1.14+
[08:48:13.336][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): connected
[08:48:14.148][I][bluetooth_proxy:059]: [0] [00:A0:50:D8:D4:9A] Connecting v3 without cache
[08:48:14.163][D][esp32_ble_tracker:169]: connecting: 0, discovered: 1, disconnecting: 0, active: 0
[08:48:14.163][D][esp32_ble_tracker:909]: Stopping scan to make connection
[08:48:14.163][D][esp32_ble_tracker:917]: Promoting client to connect
[08:48:14.175][D][esp32_ble_tracker:953]: Setting coexistence to Bluetooth to make connection.
[08:48:14.237][I][esp32_ble_client:126]: [0] [00:A0:50:D8:D4:9A] 0x00 Connecting
[08:48:14.238][D][esp32_ble_client:232]: [0] [00:A0:50:D8:D4:9A] fast conn params
[08:48:14.241][D][esp32_ble_tracker:169]: connecting: 1, discovered: 0, disconnecting: 0, active: 0
[08:48:24.182][D][esp32_ble_client:157]: [0] [00:A0:50:D8:D4:9A] Disconnect before connected, disconnect scheduled
[08:48:27.162][D][esp-idf:000][BTU_TASK]: W (406267) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:48:29.198][D][esp32_ble_client:157]: [0] [00:A0:50:D8:D4:9A] Disconnect before connected, disconnect scheduled
[08:48:34.197][D][esp32_ble_client:380]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_DISCONNECT_EVT, reason 0x100
[08:48:34.197][D][bluetooth_proxy.connection:383]: [0] [00:A0:50:D8:D4:9A] Disconnect, reason=0x100
[08:48:34.200][D][esp32_ble_client:212]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT
[08:48:34.200][E][esp32_ble_client:325]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT in DISCONNECTING state (status=133)
[08:48:34.200][W][esp32_ble_client:224]: [0] [00:A0:50:D8:D4:9A] Connection open error, status=133
[08:48:34.215][D][esp32_ble_tracker:169]: connecting: 0, discovered: 0, disconnecting: 0, active: 0
[08:48:34.215][D][esp32_ble_tracker:957]: Setting coexistence preference to balanced.
[08:48:35.036][W][api.connection:2532]: ESPHome Logs 2026.7.2 (): Reading failed SOCKET_READ_FAILED errno=128
[08:50:32.927][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): disconnected
[08:50:33.010][W][api.connection:2532]: @2colors/esphome-native-api 1.3 (192.168.1.172): Reading failed CONNECTION_CLOSED errno=128
[08:50:33.010][D][api:253]: Accept 192.168.1.172
[08:50:33.108][W][api.connection:1751]: ‘@2colors/esphome-native-api 1.3’ using outdated API 0.0, update to 1.14+
[08:50:33.194][D][api.connection:2526]: @2colors/esphome-native-api 1.3 (192.168.1.172): connected
[08:50:34.029][I][bluetooth_proxy:059]: [0] [00:A0:50:D8:D4:9A] Connecting v3 without cache
[08:50:34.040][D][esp32_ble_tracker:169]: connecting: 0, discovered: 1, disconnecting: 0, active: 0
[08:50:34.040][D][esp32_ble_tracker:909]: Stopping scan to make connection
[08:50:34.047][D][esp32_ble_tracker:917]: Promoting client to connect
[08:50:34.048][D][esp32_ble_tracker:953]: Setting coexistence to Bluetooth to make connection.
[08:50:34.048][I][esp32_ble_client:126]: [0] [00:A0:50:D8:D4:9A] 0x00 Connecting
[08:50:34.048][D][esp32_ble_client:232]: [0] [00:A0:50:D8:D4:9A] fast conn params
[08:50:34.149][D][esp32_ble_tracker:169]: connecting: 1, discovered: 0, disconnecting: 0, active: 0
[08:50:39.033][D][esp-idf:000][BTU_TASK]: W (538038) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:40.191][D][esp-idf:000][BTU_TASK]: W (539297) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:41.492][D][esp-idf:000][BTU_TASK]: W (540547) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:42.720][D][esp-idf:000][BTU_TASK]: W (541797) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:45.200][D][esp-idf:000][BTU_TASK]: W (544307) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:47.736][D][esp-idf:000][BTU_TASK]: W (546817) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:48.965][D][esp-idf:000][BTU_TASK]: W (548067) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:50.220][D][esp-idf:000][BTU_TASK]: W (549328) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:51.526][D][esp-idf:000][BTU_TASK]: W (550577) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:52.757][D][esp-idf:000][BTU_TASK]: W (551837) BT_HCI: hcif disc complete: hdl 0x0, rsn 0x3e dev_find 1
[08:50:53.780][D][esp32_ble_client:380]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_DISCONNECT_EVT, reason 0x100
[08:50:53.780][D][bluetooth_proxy.connection:383]: [0] [00:A0:50:D8:D4:9A] Disconnect, reason=0x100
[08:50:53.784][D][esp32_ble_client:212]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT
[08:50:53.785][E][esp32_ble_client:325]: [0] [00:A0:50:D8:D4:9A] ESP_GATTC_OPEN_EVT in DISCONNECTING state (status=133)
[08:50:53.785][W][esp32_ble_client:224]: [0] [00:A0:50:D8:D4:9A] Connection open error, status=133
[08:50:53.792][D][esp32_ble_tracker:169]: connecting: 0, discovered: 0, disconnecting: 0, active: 0
[08:50:53.793][D][esp32_ble_tracker:957]: Setting coexistence preference to balanced.
Hey @henqo
At first sight, I don’t get much wiser from the ESPHome log, but after some discussions with AI I came a bit further.
The following suggestions came out of the AI prompts:
  1. The Blue Connect is connected to something else. A phone with the Blue Riot app, or a second proxy, will make it ignore other centrals. The user should force-close the app and turn off Bluetooth on nearby phones.
  2. The sensor is asleep or too far away. The Blue Connect only advertises briefly and has weak radio output. The ESP saw it advertise (discovered: 1) but couldn’t hold a link, which suggests marginal signal. The proxy should sit within a few metres of the sensor, ideally with line of sight.
I’ve also made some further stability improvements to the app in v0.2.7 for ESPHome.
Kind regards,
