[APP][Pro] Apple TV & HomePod
Hi Bas, great work, thanks a lot!
Would it be possible to make a card like in the Sonos app? I like to play a Soundboard sound (like when my doorbell rings).
@Joep_Vullings First I want to get the app stable enough, so this isn’t on the todo list anytime soon. That said, I have a proof of concept for this, but that is not ready yet :slight_smile:
@Jonathan_Draper Good to hear! How is the connection of those specific HomePods after pairing?
@Chris86 Hmm, weird. Can you share a diagnostics report on the newest version please? From your last diagnostics report I can see that your HomePods reject the pairing session quite early in the process, the first request to be more specific. There is no information shared at that point… Are your HomePods configured in Apples Home-app at all? :thinking:
@BasMilius Seems stable so far, will keep you posted if anything changes.
Yep all HomePods Are in the Home App in different rooms and they Are working in the Home App? here is the Report: a712d12d-5e75-4c63-b93b-8fed7aacdabb
With last version now it works!!! Thanks! Fantastic app
@Chris86 Still the same issue as far as I can see. I’ve just published v1.0.20, that update just adds some more logging during that process. It won’t work for you, but can you please try it and send another report? I’ll get some more information then :slight_smile:
Hi, here is the new report a370e06e-93cf-495e-b25d-788ff75d6b31
@BasMilius the report I sent you work ? Or was useless information ?
Let me know if you need more info
@Chris86 Thanks! I have more information now, I’ll test some stuff when I’m back from my vacation :slight_smile:
@Casi_22 Somewhat informative, I have the feeling that it’s the retry logic in the app that is causing this…
[err] [ManagerDrivers] [Driver:apple-tv] Error: Device is busy, try again in 85 seconds.
    at Object.bail (file:///app/node_modules/@basmilius/apple-encoding/dist/index.js:458:11)
    at tlv (file:///app/node_modules/@basmilius/apple-common/dist/index.js:1507:10)
    at AccessoryPair.m1 (file:///app/node_modules/@basmilius/apple-common/dist/index.js:1314:18)
    at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
    at async AppleTVPairing.onShowViewAuthenticate (/app/src/apple-tv/pairing.js:93:20)
    at async AppleTVPairing.onShowView (/app/src/apple-tv/pairing.js:68:28)
    at async /app/src/apple-tv/pairing.js:27:62
I have strange behavior. On wifi works smoothly without any issue (sometimes for second there is an error but it comes back quickly to normal) but when i connect to eth. When Apple TV are going to sleep red triangle appears till i do not restart the app.
PS: For those users who cant add HomePods please double check if access is not restricted to home user only. This resolved my issues with paring.
6580f667-f2d4-4a9a-8f79-531112f701a3
App crashes now one of the Homepods refuses to connect. Clicking on the disconnected Homepod crashes the app again
@Nils_Kijkuit Ah the crash is because the app used too much memory and I can see what the issue is in the report. Not something I can fix tonight, but I’ll look at it tomorrow. If I’m able to return home because of the issues at Schiphol Airport :sweat_smile:
The connection issue was not in the report, maybe because it was too much…
@MSario Thanks for the HomePod solution :slight_smile:
The issue I’ll check when I’m back home, I have my Apple TV connected using ethernet, but maybe something different happens here also when I’m connecting to Wifi instead. Let’s hope I have the same behavior, that would make fixing it more easy! :smiley:
Good luck with the travels
A ok thanks for the info
Is there any News about the pairing issue?
Is it possible to send a message to the AppleTV and to get it to display on the screen?
