Ill try and get it added with the fix,
Thanks for your patience.
Would be terrific, thanks Jamie
Great. Thank you very much. Please tell me if I can do anything to support.
Sven
Same issue here unfortunately
Also same here unfortunately.
Worked for quite some time now, but yesterday stopped working with same error, Amazon must have changed something apparently.
Does this work with the Echo Flex?
Version 3.3.4 has been released to the test channel
It has been updated to :
Please note that this will be the last feature release for Homey v4.
Hi Jamie,
when i try to install, i get a ā[incompatible_app_version]ā notification.
Ah, ok, give me a moment, ill update this post when iāve updated the app.
ā This should now work if you reinstall.
Hi Jamie,
how I can access the test channel? Where can I find the new version 3.3.4
The official app shows 3.1.203 with the authentication bug
Thanks
Ingmar
Thanks @Jamie
For any app in beta, you just have to put a ā/testā in the address bar.
Hi @Jamie,
Thanks for fixing the Amazon bug, its working again
Although you did not mention the echo show 8 as supported, i am able to choose/add it. Only it has very limited functionality. (eg. No alexa says, reports, etcā¦).
Just thought i should mention it
Thanks again.
Hey @Ron_van_Muilekom, this is why we have a test channel
Thank you for your feedback, ill have a look and see if I can figure out whats going on, it hopefully wont take long.
It should add the ability to access flows for the new devices. Show5, Show8, Flex and Studio.
It also allows āOtherā Smart devices to be added to home with an on/off capability
Please let me know if there are any issues with any of the flows.
Hi @Jamie,
This new version now disconnects within a couple of seconds instead of minutes.
I really want to use your app: itās capabilities look really awesomeā¦
Another thing I find really strange, is that the app doesnāt connect to amazon after a restart or after a homey reboot. Only when I go through the āConfigure appā wizard it connects to amazon. Previous version then remained connected for several minutes and I was able to configure devices and even have my echo speak to me through an action card. So I know it can work.
Still have no idea where to start troubleshooting this problem. Any suggestions?
Sorry to hear that you have problems with the app.
I can only tell you that the new version is working great for me, restarting app, restarting Homey, both give me no problems and alexa app keeps on working.
Hi Jamie,
Thx for the quick update, for as far as i can see most features on the show 8 work fine.
What does not work (all devices) : play a sound, reports (good night + good news stories)
Could be more, but no time to test this
Working now. Thank you very much. Now I have to test everything. Play music does not seem to work. Could be my fault. First time Iām using the app.
