[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
Hey Dino (Love that name!),
What version of DC are you using?
Because in the current Test version, i cannot simulate the issue.
Could you open de browser log (useally on a Windows its the F12 button) and make a print-screen of the console log?
Wait for the next testversion, try it again and send me a diagnostic.
I’ll let you know when it’s in Test.
Actually, looking at your images again, i think you are using a somewhat older version, which had a bug in it.
I tested with the test version and it works correctly! the icon is however very small. Do you have any tips for making it bigger? Thank you very much for your work anyway :slight_smile:
Well just make sure the svg is as much stretched within the “canvas” as possible.
If you open the SVG with an editor at least.
If you edit it with texteditor, its a bit harder, but you have a viewBox.
And the elements need to be as close to the beginning and end of the viewbox.
Beside that, there is not much you can do about it :wink:
(Not yet at least)
<svg height='100px' width='100px'  fill="#000000" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 64 64" x="0px" y="0px"><title>device</title><g><path d="M61,8a1,1,0,0,0,1-1V3a1,1,0,0,0-1-1H57a1,1,0,0,0-1,1V7a.987.987,0,0,0,.82.964L56.057,10H54a1,1,0,0,0-1,1v1H45V11a1,1,0,0,0-1-1H40a.974.974,0,0,0-.46.126L35,5.586V3a1,1,0,0,0-1-1H30a1,1,0,0,0-1,1V5.586l-4.54,4.54A.974.974,0,0,0,24,10H20a1,1,0,0,0-1,1v1H11V11a1,1,0,0,0-1-1H7.943L7.18,7.964A.987.987,0,0,0,8,7V3A1,1,0,0,0,7,2H3A1,1,0,0,0,2,3V7A1,1,0,0,0,3,8H5.057l.763,2.036A.987.987,0,0,0,5,11v4a1,1,0,0,0,1,1h4a1,1,0,0,0,1-1V14h8v1a1,1,0,0,0,1,1h2.7l4.375,7H5a3,3,0,0,0-3,3V50a3,3,0,0,0,3,3H19.534a3.967,3.967,0,0,0,.493,1.039,1.116,1.116,0,0,0,.1.12l7.15,7.529A1,1,0,0,0,28,62H43.994a1,1,0,0,0,.961-.72c.139-.356,1.1-2.465,1.953-4.322A.987.987,0,0,0,47,56.54V53H59a3,3,0,0,0,3-3V26a3,3,0,0,0-3-3H37.929L42.3,16H44a1,1,0,0,0,1-1V14h8v1a1,1,0,0,0,1,1h4a1,1,0,0,0,1-1V11a.987.987,0,0,0-.82-.964L58.943,8ZM4,4H6V6H4ZM9,14H7V12H9ZM33.7,26H31.3L24.792,15.581A.976.976,0,0,0,25,15V12.414l4.54-4.54A.974.974,0,0,0,30,8h4a.974.974,0,0,0,.46-.126L39,12.414V15a.994.994,0,0,0,.952.99ZM31,28h2v2H31ZM31,4h2V6H31ZM21,12h2v2H21ZM4,50V26a1,1,0,0,1,1-1H8V51H5A1,1,0,0,1,4,50Zm41,6.321c-.907,1.969-1.4,3.055-1.673,3.679H28.43l-6.8-7.156a2,2,0,0,1,.555-2.722,2.06,2.06,0,0,1,2.778.506.956.956,0,0,0,.13.153l4.016,3.86.047.072A1,1,0,0,0,31,54.168q0-.042,0-.084T31,54V34.985a1,1,0,0,1,1.715-.681.938.938,0,0,1,.285.681V52a1,1,0,0,0,2,0V44a1,1,0,0,1,1-1,.974.974,0,0,1,.712.306A.957.957,0,0,1,37,44v8a1,1,0,0,0,2,0V45a1,1,0,0,1,1-1,.974.974,0,0,1,.712.306A.957.957,0,0,1,41,45v7a1,1,0,0,0,2,0V46a1,1,0,0,1,1-1,.974.974,0,0,1,.712.306A.957.957,0,0,1,45,46ZM60,26V50a1,1,0,0,1-1,1H58V25h1A1,1,0,0,1,60,26Zm-4-1V51H47V46a2.928,2.928,0,0,0-.874-2.108,3.079,3.079,0,0,0-3.6-.507,2.8,2.8,0,0,0-.4-.493,3.079,3.079,0,0,0-3.6-.507,2.8,2.8,0,0,0-.4-.493A3.058,3.058,0,0,0,35,41.171V34.985a2.906,2.906,0,0,0-.876-2.1A2.949,2.949,0,0,0,32,32a3,3,0,0,0-3,2.985V51.758L26.55,49.4A4,4,0,0,0,19.4,51H10V25H28.321l.887,1.419A.976.976,0,0,0,29,27v1H21a1,1,0,0,0-.868.5L16.42,35H15a1,1,0,0,0-1,1v4a1,1,0,0,0,1,1h4a1,1,0,0,0,1-1V36a1,1,0,0,0-1-1h-.277l2.857-5H29v1a1,1,0,0,0,1,1h4a1,1,0,0,0,1-1V30h7.42l2.857,5H45a1,1,0,0,0-1,1v4a1,1,0,0,0,1,1h4a1,1,0,0,0,1-1V36a1,1,0,0,0-1-1H47.58l-3.712-6.5A1,1,0,0,0,43,28H35v-.531l.1.061L36.679,25ZM18,37v2H16V37Zm28,0h2v2H46ZM43,14H41V12h2ZM58,4h2V6H58ZM57,14H55V12h2Z"></path><rect x="5" y="36" width="2" height="4"></rect><rect x="42" y="5" width="2" height="2"></rect><rect x="46" y="5" width="2" height="2"></rect><rect x="44" y="3" width="2" height="2"></rect><rect x="44" y="7" width="2" height="2"></rect><rect x="20" y="5" width="2" height="2"></rect><rect x="16" y="5" width="2" height="2"></rect><rect x="18" y="3" width="2" height="2"></rect><rect x="18" y="7" width="2" height="2"></rect><rect x="29" y="15" width="2" height="2"></rect><rect x="33" y="15" width="2" height="2"></rect><rect x="31" y="13" width="2" height="2"></rect><rect x="31" y="17" width="2" height="2"></rect><rect x="48" y="18" width="2" height="2"></rect><rect x="52" y="18" width="2" height="2"></rect><rect x="50" y="16" width="2" height="2"></rect><rect x="50" y="20" width="2" height="2"></rect><rect x="14" y="18" width="2" height="2"></rect><rect x="10" y="18" width="2" height="2"></rect><rect x="12" y="16" width="2" height="2"></rect><rect x="12" y="20" width="2" height="2"></rect></g></svg>
Thank you for your advice, Keep making us love :slight_smile:
Thanks for the donation Dino!
hello,
it’s me again (the noob!).
I am unable to display additional information on the map as @Peter_Kawa was able to show above.
I show you my configuration, tell me what you think please. I must have done something incoherent.
Uploading: Capture d’écran . 2022-09-20 à 22.20.21.png…
Thanks a lot !
What do you want? A Text Status indicator?
@Peter_Kawa
Perhaps they want a nice Template for that cool AVD of yours :wink: .
Yes, no problem. But which one? Couldn’t figure that out yet :wink:
Yes this image :
IMG_3897
This one?
You need to select the Status indicator in the Homey Mobile app.
Goto device properties on your phone, and select the status indicator.
Ok thank you, it works wonderfully!
Here’s a flow + devices you might like, to import!
https://community.homey.app/t/the-flow-exchange-r-exchange-your-flows-with-others/68981/7?u=peter_kawa
Now in Test:
A very stable, nearly finished version!
Templates can be order, filtered and made favorite.
You can order by Likes, Favorite and creation (date/number).
These templates are accessible from AVD creation, AVD repair and App Settings for Flows:
Device Capabilities 2.6.19 is Live!
With Templates, Import and Export for Advanced Virtual Device - Share Your Device! (optional includes flows):
Also Templates, Import and Export for The Flow Exchange(r) - Exchange Your Flows with Others!
Start share your AVDs and Flows!
New, also in live:
In AVD (and The Flow Export), when you export, there will appear a new button:
When you press the Goto Topic button, there will be a pre-typed message in your clipboard, and you will be send to the bottom of the topic-site, so scroll down a bit and there is your reply button.
Press it, paste your clipboard, alter the header, description and picture and you’re readyto: Post that Flow!
And
Now in Test:
A when Status text/number changed flow card.
And a bit of a messed up App Templates, i was working on that…
Pff, finally got all views on all phones and devices the same and working correct.
Old iPhone settings are also working, only have some issues with the old ios Create Device.
Ill work on it later.
