Yes, he finds a device.
When acknowledged. Pop up.
1 router, 1 dhcp, 1 pool ip
SSID inside
SSID outside with cable to router.
Martin
SSID inside
Martin
Ahaa, that is strange. Can you try adding via my.homey.app? I wonder, if this is an Android issue of a sort.
I enchance the logging a little bit show on the diagnostics report what device.data actually contains.
If you could install the test version from Go-e | Homey and do the above process again.
The diagnostics says that no device was found. Please check that your charger is actually discoverable.
Changes include
- FIX: Homeplus local discovery.
Thanks @Martin_Koning that helped.
There is a new version in the test branch. Please install that one and try adding your device.
Done. Got it now. Thanks very much. I wil start changing advanced flows next weekend. I’ve been witjh the go-eCharge Homey-app for 5 years now on my Homey Pro 2019. Integrated it in almost everything. ![]()
This one is quite different from the original app. But has some really easy features to fit Homey’s default logic and capabilities.
Totally different. It works now, but i’m not totally convinced yet. But thats also for what i want it to do. ![]()
I wanted the app “SlimLaden” to be the EMS. Because I’m thinking of buying a plug-in-battery.
For now.
I have SMA solar power inverters which i am dimming with modbus (% inverter-max at Grid) when the netto-price is negative. (EPEX-price €0,02/kwh. I have to pay €0,02/kWh for selling electricity )
Therefore potential solar power dissapears. You can’t now what isn’t produced. It appears in figures when used.
Gridmeter: -200W → Result: The go-eCharger won’t start and also stops very often.
Now I’m tweaking with modbus at SMA inverter. Gridmeter at -4200W when plugged in. Started charging then Gridmeter: -890 (-200-690) then the go-eCharger wil give more power. But the result is not stable yet. Maybe it’s the 10 second delay. Maybe the old Homey2019 is not quick enough.
The target power will not go to 17.250 W (3x25A)
I think the app limit’s it at 11 kW.
I have Version 3 from 2020. It can do 22 kW (3x32A)
