[APP] FlowComments - Simple cards to add comments to flows (v1.3)
FlowComments
This app enables adding comment cards to your flows.
They are just cards with text, no functionality at all
  • Condition cards (And.. section) are always true and do not influence the way your flows runs
  • Action cards (Then.. section) do not contain actions and do not influence the way your flows run
    Use the cards to add comments, notes or remarks in your flows.
2 types of flow cards
  • Comment (Notitie)
    To clarify the flow
  • Fixit (Oplossen)
    To point to flows that needs a better solution
    (Specific type makes it easier to search and find…)
Examples:
Comments to clarify the flow
Specific comment to point to flows that needs a better solution:
Where to find
Find it in the App Store:
https://homey.app/nl-nl/app/nu.fkey.CommentsForFlow/FlowNotities/
Find it on the GitHub Wiki
https://github.com/fkey3/FlowComments
change log
v1.0.0
First release, only published in the community app store for testing
v1.0.1
Released also in Homey app store
  • Changed the appname “comments for Flows” to “FlowComments”, Athom requests short names
  • Removed languages, For quality reasons Athom does not allow translations by google translate
  • Added German language, translation provided by Dirk (fantross)
v1.3.0 (Test)
  • updated the app to SDK3. So it works with a homey pro (2023).
  • fixed some grammar in the German language
Reserved2
Reserved3
Just created my 1st app :slight_smile: I started very simple. But it does fill a need I had.
Hope it is usefull for others too
The App is not published yet. I am still testing it myself and will publish it later
Quite a nice idea. Certainly fills a need Athom has missed to provide a solution for up until now.
Yep. I’m definitely interested
Do you want your app in the Homey Community Store?
https://store.homey.community/
Send Max a massage.
As already suggested, put me on your list for testing.
I say … Finally to this one :wink: Can add me also for testing.
Very nice. I’m really interested too!
Thanks for the nice responses.
Good to hear it fills a need!
Still some work todo. Its seems to work fine. But when pressing the test button in the flows the cards get exclamationmarks (error). Figuring out what goes wrong…
(1st time I create an app, so learning on the job)
Looking forward to test it as soon its going to be available. :love_you_gesture:
TOP and clearly missed so far !!
Great idea, could use something like this as well! I don’t have time for testing, but when the app hits the Homey App store I will download it for sure!
Yeehow, I published my app for testing.
But I do need some help now…
Accoding to the developer guidelines my dashboard should provide a link for testing.
But I do not see a link
Where can I find this link??
Found out the link will be available after 1st screening/approval by athom.
When it is available I will sent a pm to the people in this thread that mentioned they want to test.
Looking forward to that, thanks!
I can test as well if you like
My app is now availble for testing.
You can find it in the homey community store
Be aware:
  • this is not the Athom app store
  • this app is only tested by me, so no other used tested it
  • it is therefore not released in the Athom app store yet
  • Also not reviewed by Athom yet…
    Here’s the link to the app in the store
