Alarm system
Hello Homey’s
I’m looking for a new alarm system and want to connect it to homey, if not i use homey itself.
I know you can use Homey as a alarm system with Heimdall and sensors.
Is there anyone that uses homey for alarm system and do you recommend it?
Pros and Cons?
Hello Andre !
Yes I’m using Homey, Lifx bulb, Sonos and sensors as alarm :slight_smile:
First I’ve “Trigger” flows with motion sensor and “open/close” doors sensor:
When triggered, this flow launch the “Alarm scene” flow. This flow manage flows to activate and disable after x minutes. He also notify me via notification:
Finally I have alarmSound and alarmLight flows:
I’ve also my IP Cam who start recording on my synology when I leave my apartment.
Hope it helps !
Thanks Julien for the quick reply
i already new that is was posseple, but it was cool to here that someone actually use it.
i like the idea that i chose what is happening when the alarm is triggered.
do you only use geofencing for arm / disarm?
Check out the Heimdall app…
All “standard” alarm features build into one fabulous app transforming your Homey into an alarm system
Yes I only use Homey’s geofencing for arm/disarm :slight_smile:
Thank you Ted.
my plan was to use Heimdall, but that fully automated geofencing arm /disarm is actually pretty cool.
i will buy some motion and door/window sensors
Thanks for the help guys.
That can also be easily done with Heimdall
