[APP][Pro] Ford Vehicle Data - Your Ford's status, always within reach
https://homey.app/a/com.ziglar.fordvehicledata
WHAT DOES THIS APP DO?
Ford Vehicle Data shows your Ford vehicle’s data in Homey: lock status,
doors/windows, location (home/work/away), fuel, oil, tire pressure, 12V
battery, ignition status and warning lights. Use this to build your own
Flows, for example a notification when your car arrives home but isn’t
locked.
WHAT DOES THIS APP NOT DO?
This app CANNOT control your car. No locking/unlocking, no remote start,
no climate control, no charging, no horn or lights. All communication
with Ford is read-only.
WHAT DO YOU NEED?
  • A Homey (Pro).
  • A Ford account with a vehicle that works with FordPass/FordConnect.
  • Your OWN, free Ford Developer account with your own registered
    application (a Client ID + Client Secret). This is required: the app
    never uses a shared key, every installation uses its own Ford
    registration. This is a deliberate, permanent design choice - not a
    temporary limitation.
STEP 1 - CREATE A FORD DEVELOPER APPLICATION
  1. Create an account on the Ford Developer Portal.
  2. Register a new application there for the “FordConnect Query API”.
    ( https://developer.ford.com/developer-eu/application )
  3. Fill in EXACTLY the following as the redirect/callback URL (do not
    change it):
    https://callback.athom.com/oauth2/callback
    Yes, select all 3, somehow thats required even if you have only 1 catergory car.
  4. Save the Client ID and Client Secret you receive from Ford.
  5. It can take up to 2 hours before new Ford credentials become active.
    If it doesn’t work the first time, try again a bit later.
STEP 2 - INSTALL THE APP
  1. Navigate to Ford Vehicle Data | Homey .
  2. Install the app as usual.
  3. Go to: More → Apps → Ford Vehicle Data → settings (gear icon).
  4. Enter your Client ID and Client Secret (from step 1) and click Save.
  5. Restart the app: Apps → Ford Vehicle Data → Restart.
    (Required - new settings don’t take effect without a restart.)
STEP 3 - PAIR YOUR VEHICLE
  1. Go to Devices → + → select Ford Vehicle Data → select “Ford Vehicle”.
  2. You’ll be sent to Ford’s login page. Log in with your non-developer account and select your car.
  3. Click “Allow” at the bottom of the page.
  4. You’ll return to Homey, where you can confirm the vehicle that was found.
  5. One Ford login gives access to exactly one vehicle. If you have
    multiple cars, just repeat the pairing process for each one.
After pairing it might take a few minutes for all available information to show up, give it some time.
WHAT DATA DO YOU GET?
  • Lock status, per-door/window open or closed, hood
  • Location: home / work / away / unknown (never the exact coordinates)
  • Fuel level and remaining range (petrol/diesel vehicles only)
  • Oil life (a Ford-calculated estimate, not a physical measurement)
  • Tire pressure per wheel, plus warnings
  • 12V battery level and voltage
  • Ignition status (off/on/accessory/start)
  • Warning lights (check engine, ABS, airbag, brake, traction control)
    and a general “other notifications” field
  • Whether Ford’s data is up to date, and how old it is
A data point only appears once your specific car actually reports it to
Ford - not every model/trim level provides everything.
IMPORTANT THINGS TO KNOW
  • Ford’s data is not real-time. There’s a delay between what your car
    reports to Ford and what Ford makes available. Homey then reads the
    latest status from Ford every 60 seconds (default, cannot be set lower).
  • If the app can’t reach Ford for a while, the device becomes
    “unavailable” - this recovers automatically once Ford is reachable again.
  • Trying to pair the same vehicle twice gives a clear message - that’s
    not an error.
  • Do NOT try to log in to Ford repeatedly in quick succession if
    something goes wrong during pairing. Ford enforces a limit on login
    attempts; too many attempts in a short time can trigger a temporary
    block. If that happens, wait 30-60 minutes and try again.
PRIVACY
  • Your Client ID/Secret are stored only locally on your own Homey -
    never shared with the developer or other users.
  • Your vehicle’s VIN is masked internally, never logged or shown in
    plain text.
  • Exact GPS coordinates are never shown - only the derived
    home/work/away status.
TROUBLESHOOTING
  • “This Ford vehicle is already paired with Homey”
    → You’re trying to pair a car that’s already paired. Remove the
    existing device first, or select a different car at Ford.
  • Device becomes “unavailable” with a message that you need to log in
    again
    → Ford revoked access. Remove the device and pair again.
  • Device temporarily becomes “unavailable” (“Ford data temporarily
    unreachable”)
    → A temporary issue on Ford’s side. Recovers automatically, no
    action needed.
  • An expected data point is missing
    → Your car apparently doesn’t report that data point to Ford. Not a
    bug.
  • Long, unclear error message from Ford during pairing
    → Check that your Client ID/Secret were entered correctly and that
    you restarted the app after saving the settings (step 2.5).
Looking for a few testers , send me a private message trough this community of you are interested.
I want to test it
I want to test it in the Netherlands as well.
Vrijwilliger !
De installatie ging vlekkeloos dankzij de goede handleiding. Ik mis alleen de gegevens over de rijaccu.
Ik denkdat ik nogmaals bij ford moet inloggen om alle gegevens te krijgen.
Ik wil ook wel testen, voor mij zou ik ook de PHEV/EV accu status willen kunnen uitlezen
The app is now live, you can follow the manual to install the published version.
Update 1.1.1 for EV is now live
Update the app to version 1.1.1
I’ve installed (at least homey did it) the update. I can read the PHEV battery status. All data I can see are correct, compared to the data obtained from my Ford app.
I programmed a quick test to see if my Ford’s presence and plugin is recognised. Excellent.
Now I have to connect My car into the “Slim Laden Thuis & Auto” app.
So far so good.
Gewoon de instructie van Ziglar volgen en het werkt.
